Speakers get power from the amp if your system has one or from the radio , if the tweeters work it's not a fuse problem . You like listen to your stereo loud . Blew a channel in the radio or amp ?
Take it and have it checked for DTC'S - diagnostic trouble codes
DTC B1025 01: Audio Output 1 Left Front Circuit Short to Battery
DTC B1025 02: Audio Output 1 Left Front Circuit Short to Ground
DTC B1035 01: Audio Output 2 Right Front Circuit Short to Battery
DTC B1035 02: Audio Output 2 Right Front Circuit Short to Ground
DTC B1045 01: Audio Output 3 Left Rear Circuit Short to Battery
DTC B1045 02: Audio Output 3 Left Rear Circuit Short to Ground
DTC B1055 01: Audio Output 4 Right Rear Circuit Short to Battery
DTC B1055 02: Audio Output 4 Right Rear Circuit Short to Ground
Each of the audio output channel circuits (+) and (-), at the radio and audio amplifier (if equipped) have a DC bias voltage that is one half of the battery voltage. When using a DMM, each of the audio output channel circuits will measure approximately 6.5 V DC. The audio being played on the system is produced by a varying AC voltage that is centered around the DC bias voltage on the same circuit. The AC voltage is what causes the speaker cone to move and produce sound. This voltage will vary depending on what type of audio is being listened to, talk or music, and type of music, as well as the volume setting of the system. Low volume and talk settings will measure around 1V AC and less, where constant music may measure 3 V AC and slightly higher.
Do you know how to do DC voltage testing ?
Without Amplifier without UK6
Ignition OFF, disconnect the harness connector at the appropriate speaker.
Radio ON, test for 5.0-7.5 V between the signal circuit terminal A and ground.
? If less than the specified range, test the signal circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the radio.
? If greater than the specified range, test the signal circuit for a short to voltage. If the circuit tests normal, replace the radio.
Test for 5.0-7.5 V between the signal circuit terminal B and ground.
If all circuits test normal, replace the speaker.
SOURCE: want to replace bulb in headlight in 2007 saturn outlook how hard is it"
I agree with the other fae90. Tried to remove the light assy, then I read his post and did it inside 20 minutes. Took me longer to put it all back again
SOURCE: How do I change battery
No matter who does the job you will have to reprogram everything. Some parts stores sell a product that uses a 9 volt battery and plugs into the cigarette lighter, but in my experience they almost never work.
SOURCE: replaced stock clutch master cylinder
The basic steps are to start at the rear most wheel and move your way towards the master, Having someone on the pedal, pump it up and hold it, break the bleeder open, get a small hose on the nipple there and pump it into a can, do not let go of the pedal till the bleeder is tight, then do it again, you should see some air come out, keep checking the reservoir, and go round the car. One time should do it. The bleeder can be broken 10 times if it needs it, seeing it was an empty master when you started. If it doesn't work, do it again. Hope this helps.
SOURCE: my battery is good. but when I try to start the
Check relays,check all eletrical connections
check and see if you have current to starter soleinoid
SOURCE: My radio clock stoped working in my 2007 saturn ion. Checked the fuses all are good.
get the exact replacement with guaratees for 95 bucks, 2007 Saturn ION Radio CD Player GPS OEM Radio CD Player GPS Used
or go to a junk yard for 50 bucks no guaratee,or buy an aftermarket player and buy wiring kit and mount kit for over 100 bucks
