Question about Onkyo Audio Players & Recorders
Onkyo receiver will not respond to Onkyo remote
  • Official Brand Answer
  • 333 Answers
Hi Thomas, I am not aware of your model but try pressing the receiver button in the remote mode section or RCV on top depending on your receiver model. Thank you, Onkyo USA
Posted on Dec 27, 2016
Model DR-S2.0. Why doesn't it respond to remotes?
If your receiver does not respond to the original remote, the remote may have failed.
If your receiver does not respond to your Harmony remote, the remote may not have been programmed or may have "forgotten" what to do.
Another possibility is that the infrared receiver has failed
Feb 16, 2016 | Onkyo Audio Players & Recorders
Not responding to remotes
I've owned an Onkyo DS696 receiver for 5+years. Every once in a while (when it was on for a long time?) the receiver would not respond to the remote. At first it could be "fixed" by a simple power cycle. It got worse over the years, and finally the unit would not respond to the remote at all. After reading a post here that made perfect sense, my husband and I opened the unit up, and (even thought the solder at the IR connection LOOKED fine, we resoldered it. (He knows how to do these things expertly). We screwed the unit back together and VOILA! it works perfectly now. Even if you don't know how to solder, if you brought it to a repair shop and told them exactly what the issue was and how to fix it - you can save your sanity and the unit. The solder joint I'm talking about is directly behind the IR on the front daughter board.
on Jun 28, 2007 | Onkyo TX-DS696 Receiver
Onkyo receiver txds787 doesn't respond to remote
Pull the batteries out from the remote control, and leave it out until step-4
Press and release each and every button, one at a time on the remote control, until every button has been pressed and released at least once.
If the remote control have slide switches; move the switch to each position, then repeat the button pushing as in step-2. {When you've done, be sure to put the slide switch in the correct position to operate the unit the remote came with.}
Put the batteries back.
Try the remote.
If it do not help you:
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
Jul 10, 2015 | Onkyo TX-DS787 Receiver
Hi. my original remote for my onkyo tx ds575 all of a sudden is not working anymore. the red light on the remore still lights up when i press a button but the receiver is not picking it up. hopefully you...
The red light on the remote just means the battery is good and the remote is responding when you press a button. It doesn't mean the control is actually sending out a signal. Many retail stores have a tester that will tell you if the remote is transmitting. Another possibility is that the remote sensor in the receiver has gone bad, and that the remote is fine. A universal remote (One-4-All URC6131, for example) that can work home theater receivers can be used to test the receiver. It may not work all the functions, but if it turns the receiver on and off you'll know the remote is at fault and not the receiver. Then you'll be able to replace the remote or have the receiver serviced as needed.
Mar 21, 2011 | Onkyo TX-DS575 Receiver
How to program remote control?
Your Onkyo TX-SR304 receivers remote (RC-645S) is not capable of controlling devices by other manufacturers. It controls only Onkyo devices.
Other Onkyo remotes do have universal remote functionality and you can download Onkyo remote codes here.
I hope that helps.
Download Onkyo TX-SR304 users manual here.
Mar 26, 2010 | Onkyo TX-SR304 Receiver
I need the remote control code (for onkyo receiver
Philips Blu-Ray player codes for Onkyo universal remotes are: 33007, & 33016.
You can download Onkyo universal remote codes with instructions here.
I hope that helps.
Jan 23, 2010 | Onkyo TX-SR605 Receiver
Unit does not respond to remote control
I had this same problem with the Onkyo TX-SR706 this evening, and finally found the solution in the "Controlling Other Components" section of the manual: Resetting the remote control did the trick. (P.S. This problem started after I spent many hours today trying to get my new Acer laptop equipped with a Hauppauge TV tuner stick to correctly display its image on my Samsung HDTV, with sound. I tried connecting the laptop via HDMI first to the Onkyo receiver and then directly to the TV, neither of which worked as it should. I assume that somehow, in all those hours of much plugging and unplugging and fiddling around, I screwed up the remote sensor -- thank goodness I eventually found the "Resetting the Remote Controller" solution a little while ago -- I was approaching the point of ripping everything apart and throwing it out the window!)
Jul 06, 2009 | Onkyo TX-DS575 Receiver
Receiver doesn't respond on remote signals
Low batteries can cause a symptom like this. Have you tried to replace them yet?...accordianman
Oct 04, 2007 | Onkyo TX-DS595 Receiver
66 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
