Question about Garden
How do I install new line on my Vornado leaf eater
2 Suggested Answers
SOURCE: replaced starter spring on Poulan/weed eater FL1500LE leaf blowe.
you may have wound the spring backwards, try winding the othe way.
Posted on Jun 28, 2010
Hello, can you send me the order for taking apart a Weed Eater bv200 blower vac, I need to install new fuel lines
Check on U-tube. There is a bunch of excellent videos on gas line routing.
Dec 21, 2015 | Garden
Poulan blower fuel lines
I would guess the fuel line you installed is kinked somewhere.
Jan 12, 2014 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Powerpro 17" McCollich weed eater
hey harry the float inside the carb is stuck i would suggest rebuilding the carb
Jun 27, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
No Spark, plug is good
Hi
If you have a good plug in still no spark you will need to install a new coil.
Sam
Jan 07, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Weed Eater Lightweight 1500 Leaf Blower Fuel Line Repair. There is something in my gas tank, which I assume is a filter of some sort and I need help getting one replaced and onto which fuel line it should...
there are two lines going into the tank one is short which just goes in the for pressure from the primer bulb the other line goes to the filter which goes to the carburator
Itsman
Nov 03, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
How do you intall the cutting string on a Flowtron leaf eater?
I have an electric weedwacker which may be different. In the leaf wacker there are four small holes very near the center screw on the revolving shaft. These holes form two small tunnels. cut two pieces of line (10-12 inches) and stick one through each tunnel. Center each line, put the two ends together and poke them out through the small hole on the edge of the rotating shaft. You end up with two sets of plastic line facing out from the central shaft. Flowtron may be different. Good luck.
Mar 23, 2009 | Flowtron LE-800 Electric Leaf Shredder
WEED EATER BLOWER BV 1800 FUEL FILER REMOVAL AND REPLACEMENT
According to the Weed Eater Instriction Manual, page 8:
REPLACE FUEL FILTER: To replace fuel filter, drain unit by
running in dry of fuel, then remove the fuel cap/retainer assembly
from the tank. Pull filter from tank and remove it from the the
fuel line. Install a new fuel filter on fuel line; reinstall parts.
Tip: Sears outlets have a big selection of tune-up items for
blowers, etc. Try them for needed parts.
Mar 21, 2009 | Garden
Gas line connections
The thicker of the two lines goes on top nearest to the primer ball
Mar 21, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Reload cord.
I just replaced my Flowtron cutting string. That screw in the middle comes off if you turn it hard enough. Then the spool lifted off. I took it to the hardware store to get the right gage string, and installed it like the old. It was curly though, and got caught under the spool when I used it. Then the motor quit and won't start. So I just posted that problem. ~ CarolK
Nov 13, 2008 | Flowtron LE-900 Leaf-Eater Mulcher
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
