Question about The Watches
Can't set the hour - The Watches
THIS PRODUCT IS AN EVERFLOURISH TIMER. HOW CAN I ADJUST THE ACTUAL TIME ON THIS TIMER.
I suggest you email them direct for this and also for the manual at
efnb@everflourish.com.cn but it does sound like you have it and look at # 2, after setting the day, you set the time:
2. Time Setting 2.1 After setting the day of the week, hour display flashes to indicate setting time can be started 2.2 Press +Button to increase number of hour, or Button to reduce hour. 2.3 Press +/ Button once will increase or reduce each hour slowly. To press and hold the button, the hour display moves quickly. Release the button until your desired hour shown on the display. Press SET Button to confirm your setting. 2.4 “Minute” display then flashes to indicate setting minute is ready. Repeat the same procedures in setting hour as in #2.2 and #2.3 to set minutes.
manual here:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&sqi=2&ved=0ahUKEwii9O-RtrTMAhVKgiYKHRULDsgQFggjMAE&url=http%3A%2F%2Fproduktinfo.conrad.com%2Fdatenblaetter%2F600000-624999%2F616021-an-01-en-Mini_Zeitschaltuhr_digital.pdf&usg=AFQjCNGYADTAgA9msCpN4otTAxRQ1PJ6dA&bvm=bv.120853415,d.cWw
Apr 29, 2016 | Watches
I need to know how to set my skmei watch 0955
  1. Continue to press the MODE button until the second digits blink.
  2. Click the START button to reset the seconds to zero (00).
  3. Press the RESET button and the minute digits will blink.
  4. Click the START button to set the minutes. Hold down on the button to increase the speed.
  5. Press the RESET button and the hour digits will blink.
  6. Click the START button to set the hours.
  7. You can select between 12-hour and 24-hour display modes. A "P" indicator signifies it to the afternoon 12-hour setting, a "A" indicate in the morning and a "H" means that it is the 24-hour setting.
  8. Continue this pattern to set the day of the month, month, and day of the week, respectively. 9 Press the MODE button to finish and exit.
Feb 20, 2014 | Watches
How do i change my timex wr30m from 24 hour to 12 hour display
Hi cbrichw,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Nov 13, 2010 | Timex 1440 Nylon watch
HOW TO CHANGE THE TIME ON MY DIGITAL WATCH IT HAS 4 BUTTONS ON THE TOP LEFT IS "LIGHT" ON THE LEFT "MODE" ON THE TOP RIGHT "START" AND ON THE RIGHT IS "RESET" THE...
Press "mode" until the hour is flashing,
Now press "start" to change the hour. When hour is correct, press "reset" and minutes should start flashing.
Press "start" to change minutes" then press "mode" again.
Oct 29, 2010 | Watches
I have an aquatech watch and don't know how to set it.
Thank you for contactng FixYa.
Setting the Time and Date
  • To set the time and date on your Aquatech watch, begin by pressing the "Mode" button three times to access the time setting screen. Use the "Lap/Reset" button to set the hour on your watch. Use the "Start/Stop" button to advance the numbers to reach the correct hour. When you've set the hour, use the "Lap/Reset" button to set the minutes, using the "Start/Stop" button to advance to the correct minute. Repeat the procedure to set the seconds, month, date and day of the week on your Aquatech watch.
  • Setting an Alarm
  • To set an alarm on your Aquatech watch, begin by pressing the "Mode" button two times to access the alarm setting screen. Use the "Lap/Reset" button to set the hours place, using the "Start/Stop" button to reach the correct hour. Repeat the same procedure to set the minutes for your alarm. When you have finished setting the alarm, activate it by simultaneously holding the "Lap/Reset" and "Start/Stop" buttons until the alarm icon appears. When the alarm sounds, silence it by pressing the "Lap/Reset" button.
  • Deactivating the Hourly Chime
  • Many Aquatech watch models feature an automatic hourly chime. This can be inappropriate and inconvenient in many situations. To deactivate the hourly chime on an Aquatech watch, simply press and hold the "Lap/Reset" and "Mode" buttons simultaneously. After you have correctly deactivated the hourly chime, the hourly chime indicator icon will disappear from the watch's main screen.
  • Best regards. Jewel
    Sep 18, 2010 | Watches
    How do I switch from 24 hour time to 12 hour time?
    Hi greg780,
    Hope it helps.
    Oct 12, 2009 | Timex 1440 Nylon watch
    Timex 1440 time from 24 hour clock to 12 hour
    Hi bowingman,
    Hope it helps.
    Oct 09, 2009 | Timex 1440 Nylon watch
    Aquatech watch
    press mode button 3 times untill you get into the time set mode - press lap/reset twice until the hours start to blink.
    press start/stop and cycle thru all the modes depending what time you want to set - it will go thru 1, 2, 3, etc thru 24 H then 1, 2, 3, etc thru 12 A then 1, 2, 3, etc thru 12 P - depending on thte time you want to set the A is for AM and the P is for PM
    hope this helps
    jeff
    Jul 23, 2008 | Watches
    Setting time/date on Ironman Triathlon 8 lap
    Press & hold set button the seconds will flash.
    Press split/reset to set seconds to zero
    Press mode to select hours
    Press split reset to advance hour digits go through 12 hours to get to AM/PM
    Press mode to select minutes
    Press split reset to advance minutes
    Keep repeatin the above steps to set month date day and 12/24 hour diplay
    Press set when done.
    Mar 09, 2008 | Timex Sports Ironman Triathlon 50-Lap...
    Watches Logo
    14 people viewed this question
    Top The Watches Experts
    John mullen
    D. E. Hev
     En Sukkert
    En Sukkert
    Level 1 Expert
    Are you a The Watch Expert? Answer questions, earn points and help others
