Question about Vivitar DVR Video Cameras
Dvr 788hd not on setup cd? - DVR Vivitar Video Cameras
Sannce DVR-DH81NK1T i am lock out need code or password
Connect dvr to local network
boot up the dvr
connect to local network with a computer (eg Mac)
login into admin screen of your router to identify the assigned ip address of the router
start a terminal session
telnet to the ip address
default user name : root
default password : xc3511
mbaad@MBAADs-MacBook-Air:~$ telnet 192.168.0.3
Trying 192.168.0.3...
Connected to 192.168.0.3.
Escape character is '^]'.
YourCCTVDVR login: root
Password:
BusyBox v1.16.1 (2014-12-24 15:47:14 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
Welcome to Monitor Tech.
[root@YourCCTVDVR /]$ cd /
[root@YourCCTVDVR /]$ ls
bin etc linuxrc proc share usr
boot home mnt root slv var
dev lib opt sbin sys
[root@YourCCTVDVR /]$ cd mnt
[root@YourCCTVDVR /mnt]$ ls
custom dvs logo mtd usb web
[root@YourCCTVDVR /mnt]$ cd mtd
[root@YourCCTVDVR mtd]$ ls
Config Log
[root@YourCCTVDVR mtd]$ cd Config
[root@YourCCTVDVR Config]$ ls
Account1 StorageCfg network
HvrMode SysComs ppp
Json SysTime resolv.conf
RT2870STA.dat dhcp.cfg uboot_env_lang_video
There will be an Account## file for each account you have set up
Remove all of these files
[root@YourCCTVDVR Config]$ rm Account1
Reboot your dvr box and it is at the first setup screen
Here are the commands - note you can't send password as part of the telnet command
telnet 192.168.0.XX
root
xc3511
cd /mnt/mtd/Config
rm Account*
exit
CCTV Networking Technical Support
Apr 10, 2017 | Home Security
What do I put on the app for android phone in space DVR title.server port and do I use my email for user name?
DVR title you can use DVR
server port you can find at dvr setup menu in network category
user name can use admin
Mar 04, 2015 | SWANN H264 4 Channel Dvr 4 Ccd Cameras...
I'm trying to transfer video from my Swann DVR4-1000 to my laptop using a USB transfer cable. When I plug the cable in, the laptop doesn't seem to 'find' the DVR. What am I missing? Thanks...
Did the system come with a setup CD? If so, unplug the DVR from your system, insert and run the setup CD then plug in the DVR and it should recognized.
May 28, 2011 | Computers & Internet
How do you connect an 4ch h.264 dvr security camera system to a LAN or ADSL
add camera to the router that is allow it in the setup. the devices will need to be allow either by MAC address or device name.
check your user manual for correct setup procedure.
usually found on the CD that came with the router.
Aug 07, 2010 | Computers & Internet
I do not have the sofware to make work on my computer i broke the disk by mistake
You will need to "install" the software on your PC. Run the "setup.exe" program from your CD to do this.
You will also need to connect your camera with an USB cable to your PC to transfer pictures to and from PC.
Here´s a manual and software download site for DVR-550 . Send them a request.
Oct 05, 2009 | Vivitar DVR-550 DV Camcorder
Cant access lorex DVR from the internet
u need a public ip with an open port, and portforward the port with the ip of ur dvr
Mar 15, 2009 | Home Security
Cyberhome DVR 1600, where can I get the firmware update
Hi there
The best bet now the company has gone bust is trawl through the forums to see in anyone has a firmware upgrade saved and available for download. Here is a good start.
http://www.avforums.com/forums/index.php
Good luck and thanks for using Fixya!!
Feb 19, 2009 | Cyberhome DVD Recorder - DVR1600
Need to get video off dvr
From the user manual page 71:
5.2 Quick Archive to CD
Archive to CD on the Disk Analysis Screen by selecting the time and date and pressing the record
button. The QuickWave Setup must be set to ON from the Archive Setup → Quick Wave Setup menu
(see section 3.15). The Archive Incident menu should appear.
1. Use the Jog to modify the time parameters and use the
Shuttle to move between the Start and Stop fields.
2. Press the Record button on the front panel when satisfied.
3. The CD Writer will open the CD tray when completed.
The video may now be viewed on any PC equipped with a CD-ROM.
You can download the complete user manual here:
http://www.gesecurity.com/portal/site/GESecurity/menuitem.f76d98ccce4cabed5efa421766030730?selectedID=1965&seriesyn=true
Dec 24, 2008 | GE Security DVMRe-16CT-600 16-CHANNEL...
"HDD REPLACEMENT IS NOT VALID..." error message
Go to http://support.dell.com/support/edocs/systems/latd630/en/AMT/MEBX.htm
You have to disable Intel ME State Control , and you do not get any pop up masages any more.
I hawe that problem with secundary HDD.
Regardes.
Oct 12, 2008 | Pioneer DVR-213LS DVD±R Dual Layer Burner
Video Cameras Logo
77 people viewed this question
Top Vivitar Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Vivitar Video Camera Expert? Answer questions, earn points and help others
