Question about Radio Communications
I got a new tv. I am trying to connect by bluetooth. My tv can't find it. How do I put th frisby in pairing mode?
jsinex2421
  • 62 Answers
SOURCE: pairing mode for headset with PS3
On your PS3 XMB menu. Go to settings. Scroll down to accesories. Then click on manage bluetooth devices. There you will find the autodetect for the bluetooth headset. While the bluetooth headset is off, press and hold th on button until the LED stays on. The quickly use the PS3 to detect the blue tooth. It will ask for a pin to pair the units up. The pin is four zero's.
Posted on Jan 10, 2009
  • 13 Answers
SOURCE: need plantronics 320 pairing code
it's either OOOO or 0000.
Posted on Feb 18, 2009
SOURCE: Trying to pair omnitech 2.0 bluetooth headset without manual
before attempting to pair your headset with another device, be sure that the bluetooth headset is in the off position
  • press and hold MFB until indicator light flashes blue and red. The headset will also beep twice
  • to pair your device to the bluetooth headset use the bluetooth pairing instructions from you device's instrucition manual.
  • input ID code 0000 when requested by the device
  • the headset and device are paired correctly when the blue and red indicator light flashes blue only.
Any questions email: shyrosi@yahoo.com Subject: omnitech bluetooth
Posted on Mar 09, 2009
SOURCE: how do you put in pairing mode?
Here's how to get the LG HBM-710 Bluetooth headset into pairing mode:
While the headset is OFF, press and HOLD the power button. CONTINUE to do so even after it has powered up. About 3-4 seconds after the startup beeps there will be one more beep. Then, the red light will go solid.
You are now in pairing mode! Hooray!
Go through the necessary 'Add a Device' steps on your cell or whatever and you should be G2G!
Posted on Mar 25, 2009
SOURCE: how can i pair my samsung bluetooth headset to
turn off the head set then press and hold the on button until the blue light stays solid blue.
search for device on your new phone and add device code is 0000
Posted on Apr 12, 2009
The Bluetooth headset Jwin JB - TH 130 is not discovered by my Dell Streak Mobile
Have you tried to put your headset in pairing mode first? Anyway, in order to do it, starting with it turned off, press and hold the answer/end button for some 8 seconds, until the indicator light is flashing alternately in red and blue. It is in pairing mode now. Then, on your Android device, go to 'Settings > Wireless & networks > Bluetooth Settings', and, if your device's bluetooth radio is turned off, turn it on, by ticking the 'Turn on Bluetooth' checkbox. Then, on that same settings page, click 'Scan for devices'. After a little while, your headset should appear on-screen (most probably at the end of the list). By clicking over it, the pairing process should be automatically done. Otherwise, if a pairing mode (or PIN, or passkey) is requeseted, enter '0000' (four zeros). You'll see an inidication on that settings page that your headset is connected for phone calls.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Please, let me know if you need further informations.
Regards, Carlos
Mar 05, 2011 | Jwin BLUETOOTH HEADSET Wireless Headset
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
E52 i want pair with my pc i do not know what is the pair password how to do it please clear
Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Feb 13, 2011 | Nokia BH-104 Bluetooth Headset
I broke my mobile (Blackbarry) where i had my Sennheiser VMX100 connected. I have now got a new mobile but cant get is connected via bluetooth. Can you offer any help?
You must put your headset in pairing mode, prior to trying to pair with a new phone. Press and hold any one of the volume buttons whilst opening the microphone boom. The indicator light should be flashing alternately in red and blue, thus indicating it is in pairing mode. Release the volume key. Only then, make your phone search for new devices. After a while, the VMX100 should appear on its screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode (the indicator light flashes slowly in blue).
Regards, Carlos
Nov 05, 2010 | Sennheiser VMX100 Bluetooth Headset...
I paired my H710 with my lg Chocolate touch and the phone recognized it and it seemed to be connected. I haven't used it for a while and when I try to connect it says that communication failed. I have been...
To put your headset again in pairing mode, you must assure that your phone's bluetooth radio is turned off. Only then, open your headset's boom. After it is in pairing mode, turn your phone's bluetooth radio on, and make it search for new devices.
Hope it works for you.
Regards, Carlos
Jul 03, 2010 | Motorola Mobility H710 Bluetooth Headset
How to connect lg hbm-730 bluetooth to dv4 laptop
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Feb 12, 2010 | LG HBM 730 Bluetooth Headset Wireless...
Sony ericsson bluetooth headset tryin yo connect
Nov 18, 2009 | Sony Ericsson Mobile Bluetooth Car Kit...
New phone need to connect with bluetooth
Sep 07, 2009 | Plantronics Voyager PRO Bluetooth Headset
Pairing mode for headset with PS3
Jan 09, 2009 | Ubi Soft Entertainment Tom Clancy''s...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
