Question about Aluratek Computers & Internet
Aluratek awdmp110f how to set photos for continuous play
Unit has limited ram type memory, frequently freezing or resetting itself. Appears to have a default towards Cloud Storage especially when WIFI is activated. If you are not using cloud memory for photo storage you will find things work better if you turn wifi off. To delete or export photos, tap the small photo But do not remove your finger until the photo starts to change shades, then select the action bar desired. Multiple selections are simple as you just tap the light circle on the photo. Just do not select over 25 photos in one batch of the unit will again freeze and reopen at the start of the entire sequence and you will have to deselect the same photos. Remember to select the location of your stored photos each time you restart the unit or it will try the cloud and freeze there.
SOURCE: My adesso cybertablet 6400 tablet
I would recommend turning the Power Saving features OFF in the Device Manager for your tablet. On your computer click on Start, Control Panel, System, then the Hardware tab, then Device Manager. Now find the CyberTablet 6400, right click and select Properties. Click on Power Management and be sure that "Allow the computer to turn off this device to save power" is UNCHECKED. This way the computer will not shut it down when you haven't used it fo a while. Hope this helps. Good luck.
Posted on Jul 27, 2007
  • 118 Answers
SOURCE: n770
Please check this manual
Posted on Jan 26, 2008
SOURCE: Classic Pen Woes
Hi , Mnemosyne , i'm the Guest who had the exact same of your problem , i contacted WACOM and there solution was as follow : " This problem is, although uncommon, usually easily fixable. The first and fastest solution is to simply press the eraser a few times to release it from binding on the side of the pen. If that does not work, pull the white plastic nib, and take a fingernail file (LIGHTLY) to the back end of the nib, making sure to remove any burs or flaring from the nib. I have seen this problem myself, albeit uncommon " , they also suggested if all fails then change the nib ( and thats exactly what i did , i changed the plastic nib with the felt nib - i like it better anyways thats why i didn't bother filing the plastic nib - and WALA my problem was solved and the pen is working like a charm , hope this helps .
Posted on Jul 01, 2008
  • 4 Answers
SOURCE: Sony CDX-GT720 No Memory!
OK. Here's the deal. There are two "power" input lines. A RED and a YELLOW. RED should be connected to your vehicles' ignition or key switch. YELLOW should be connected to a "constant" power supply directly from the battery.
If you have a test light, you should be able to find both at the fuse box. Just clip the alligator clip to the frame somewhere or to the edge of the cigarette lighter and probe the fuse box turning the switch off and on respectively. (test lights are very inexpensive, about 4 or 5 bucks at the auto parts store).
Hope this helps.
Posted on Jul 05, 2008
SOURCE: My HTC Touch suddenly turn off, and Is hard to start it again.
the solution to the problem is explained in detail here
Posted on Oct 31, 2008
How do i delete storage
Hey Edward. What kind of phone do you have? Is it an iPhone or android phone?
If you're an iPhone user and wanna free up space on it, please feel free to read this guide.
How to Free up Storage Space on iPhone 6 6s SE
Jan 12, 2017 | Cell Phones
My sandisk 260r frequently freezes up
format the player once and reload the songs again and try...
Feb 05, 2008 | SanDisk Sansa e260 MP3 Player
IPhone 6 or iPhone 6s suddenly ran out of free storage space? How can I fix it?
I am not completely sure about this but contact apple. You may be able to purchase cloud space.
Mar 09, 2016 | BUYINSOON Anti-Lost GSM Touch Screen...
How do I upgrade?
In general, SSD drives are faster but smaller than rotating drives. If you need a little more storage, replace your existing drive with a bigger one. If you need a LOT more storage, and don't need it to be internal, then something like a WD "My Cloud" plugs right in and offers a lot of storage
WD My Cloud 2TB Personal Cloud Storage WDBCTL0020HWT NESN
Most laptops have limited sound quality built in, especially if you're using headphones. There are a vast selection of external sound cards and DACs available at price points from $20 to thousands, depending on what you're willing to spend. If you're using headphones, make sure you get one rated to drive headphones, not one rated to just drive electronics. I have this one:
Turtle Beach Corporation
and feel it's a good value for the money.
Jun 16, 2015 | Lenovo G585 Laptop
Vizio downloads firmware every time it is turned on
Firmware corrupted. A reinstallation is necessary. Contact any service technician.
Mar 04, 2017 | Vizio XVT553SV 55 in. LCD TV
How do I reset my router password, normal one doesn't seem to work anymore.
There should be a small reset button on router which will reset to default,u will need. A pencil or similar to press it, the default username is usually admin and password is. Admin
Oct 17, 2012 | D-Link DIR-615 Wireless Router
Enquiries on maximum supported hard disk capacity and memory
Dell Optiplex 760 Vista
Max CPU Intel Q9550
Largest HDD Shipped 1TB (Will likely Support 2TB)
Optiplex GX260
Max Intel Northwood 2.53 GHz - 533
Largest HDD Shipped was 200GB (Will likely support 500GB)
Dell Dimension XPS D300
Max CPU 333 Pentium II
Max RAM 384MB
Largest HDD Shipped 16GB (Will likely Support up to 80GB)
Dell Dimension XPS M
Max CPU 166S
Max RAM 64 MB
Largest HDD Shipped 4.3 GB (Max HDD likely 20GB)
Feb 09, 2010 | Dell OptiPlex GX260 PC Desktop
Food freezing in refrigerator storage bins
produce has more water in it to freeze. Try turning down the temp in the fridge part of the unit you may try putting a termometer in there to gauge where it should be adjusted to, about 38-41 degrees is a safe temp for keeping food.
May 27, 2009 | Refrigerators
What is upgrad & how upgrad in HTC Touch P3450?
u cannot upgrade storage memory that is called RAM and ROM but u can always upgrade ur Storage card that is used for the storage of programs and files I understand ur problem u are feeling short of memory in Program and storage that RAM and ROM u cannot upgrade but u can do something about it i can help u in this
option 1
u can always reset the device for a new start and then try installing all ur programs to ur memory card when it ask for location where to install select storage card there and ur ROM will not be used to store those programs plus ur device will be fast in performance.
always programs in storage card
2.never install in ROM or ur device memory
3.Always close programs from the Task Manager a small arrow up on right side of screen select all programs and close them after u are done with them u will never be short of RAM.
4. Set ur History and cache folder of ur browser IE or OPERA to Storage card if u cant find the link to do this just google SKTOOLS for Windows Mobile download and install this software will let u configure where to keep ur history and cache files
5.When u recieve files from bluetooth they by default comes in the Device/MyDocuments folder and this will use ur device storage which is limited offcourse so u can google OBEX INBOX install and set the folder of recieving files thru bluetooth to memory card directly this is a very imp tool u will never find it easily i bet.
Feb 27, 2009 | HTC Touch P3450 Smartphone
Computers & Internet Logo
69 people viewed this question
Top Aluratek Computers & Internet Experts
Don Hart
Are you an Aluratek Computer and Internet Expert? Answer questions, earn points and help others
