Question about Aluratek Computers & Internet
How to have photos loop on aluratek dmpf110f - Aluratek Computers & Internet
My aluratek 10" frame - photos in calendar are all stretched. How do I fix that?
Use software to resize your photos to the same dimensions as frame screen, both width and height, surrounding the picture with blank space if necessary.
Feb 14, 2017 | Photography
I can rotate pictures on my Aluratek digital photo frame but cannot get the rotation to save. How can I do this on the photo frame?
after u rotate the photo if you select the next photo in line , it should delay for a moment and say :updating: this it saving your rotation in its memory , or why not just rotate in in camera or computer , then save it to frame alllready rotated !!
Oct 20, 2016 | Photography
Want to know how transfer photos from a Nokia Lumia 521 to the Aluratek Digital Photo Frame
You can either transfer your photos and videos to your computer first (See your NOKIA Lumia 521 Users Manual), and then transfer them from your computer to a MicroSd card that is used with your 8" Aluratek Digital Photo Frame
OR
Your NOKIA Lumia 521 phone supports a MicroSD memory card with a capacity of up to 64 GB. When you take photos and videos using your phone, store them to the Memory Card directly. You can then simply take the memory card out of the camera and insert it into the Aluratek Digital Photo Frame for viewing.
May 14, 2014 | Photography
Just want to know how to transfer photos from a NOKIA Lumia 521 to the 8" Aluratek Digital Photo Frame
Try sending the photos to a cloud service on the web, then transfer to a memory card that could be inserted into the Photo Frame. If the phone has a memory card you can get an adapter to upload to a PC then back to a memory card for the Photo Frame.
How do I music onto my Aluratek ereader?
First hook your Aluratek to the computer with the USB cord that came with your Aluratek. Then make sure your Aluratek is on. Go to start menu on your computer. Open the computer file it should list your Aluratek along with your computer hard drive. Left click on your Aluratek drive. It should say open. Open it then click on the file that says the type of files you want to move. Books, pictures, mp3's. Now drag and drop the files to your open file. You can also do the same with the SD card rather than the internal memory both will show up as separate devices.
Jul 07, 2011 | Aluratek Libre eBook Reader PRO Black
How do i download things to the aluratek libre?
Jun 25, 2011 | Aluratek Libre eBook Reader PRO Black
I loaded a book on my sd card then put it in my reader then it tells me that it is incompactable I can not figure out how to read it off the sd card or how todownload it from the computer to the sd card...
First make sure your SD card is formatted for your Aluratek. You do that by hooking your Aluratek up to your computer. Turn your Aluratek on with the SD card inside the Aluratek. Go to start menu. Open file named computer. There should be your computer drive your Aluratek and the SD they will be lettered left click on the one for your SD card. It should list format. Click format. Use safe to remove hardware remove your Aluratek and SD card. Now press the reset button on your Aluratek with a paper clip or needle do not use a ball point pen. Now it should be ready to load with anything you want on it. To do that you hook up your Aluratek to your computer open the drive as stated before in your SD or your Aluratek. Now drag and drop your files into the drive you have open. It should now be compatible. I know this works I had the same issue with some of my mp3's.
Jun 15, 2011 | Aluratek Libre eBook Reader PRO Black
Need a new manual
Go to the Aluratek site: http://aluratek.com/products/ebook-readers and select your model.
There is a link to the manual just before the Overview section. The direct link for the Libre Pro is http://aluratek.com/media/uploads/AEBK01FS-AEBK01WFS_Manual.pdf (for the model that comes without the SD card).
I hope this helps.
Jan 29, 2011 | Aluratek Libre eBook Reader Pro
Computers & Internet Logo
61 people viewed this question
Top Aluratek Computers & Internet Experts
Don Hart
Marcin
Are you an Aluratek Computer and Internet Expert? Answer questions, earn points and help others
