Question about Coffee Makers & Espresso Machines
Brand new K15 worked six times - now the brew light won't turn on
3 Suggested Answers
SOURCE: 2nd time using this brand new machine and it won't brew.
try unplugging the unit for 1 1/2 hours to reset the electronics...I just called them and that was their advice...we shall see..worth a try
Posted on Aug 16, 2008
EsWorld
  • 1618 Answers
SOURCE: Brew light blinking
It is telling you that the temp on the machine is too low. It is possible that one of the thermostats on the boiler is damaged.
Posted on Sep 17, 2009
Brand new Cuisinart SS-10 single seven coffeemaker was set up to brew and when brew button was pushed it turned off and won’t turn on again.
As long as you read the instructions from cover to cover twice, if it doesn't work, pack it up and take it back.
Jan 23, 2018 | Cuisinart Coffee Makers & Espresso...
Brand new. Trying to rinse coffee maker before use. Water is not going thru coffee maker. Buttons light up, coffee maker makes noise but no water comes out.
If it is brand new and does not work, don't waste your time, take it back and get it replaced. All consumers should demand better service from suppliers and sellers.
Dec 26, 2014 | DeLonghi Nescafe Dolce Gusto EDG455T...
Keurig Mini B 30 won't work.
Time for a new unit....it is past its prime now.
Jan 05, 2013 | Keurig B30 Mini Coffee Maker
My 2008 Harley Davidson 1200 custom won't start because the red lock light will not turn off. I just replaced the battery and this problem was not there before.
Hope this works for you.Instructions
    • 1
      Turn the key to the ignition position. Quickly press both turn signal indicators, until a light on the dash flashes.
    • 2
      Enter the first digit of your 5-digit security PIN by pressing in the left-turn switch the same number of times. So if your PIN is 76543, you should press the left-turn switch six times.
    • 3
      Press the right-turn switch once to store the number and move to the next digit in your PIN code. Press the left turn signal six times to continue, until you get to the end. At the end of the process, the alarm will disarm and the light on the dash will stop blinking. You can now start the bike as normal
Oct 31, 2012 | Harley Davidson Motorcycles
Interior light not turning on. Temperature not showing up either. Brand new out of the box. Plugged in and it lit up, then turned off. Now won't turn on (light won't turn on) Unit turns on and
Sounds like a poor connection in the control or a faulty control module, I would return it as faulty for a new one. They seal those units up pretty good so we can't fiddle with them. Everyone gets a lemon sometimes.
Sep 06, 2012 | Whynter (WC16S) Wine Cooler
Excessive water comes out the drain when brewing a expresso
Hi
Your 3 way valve is dirty or bad. Have you ever done a back flush with a detergent?
About every 3 months it is a good idea to do a backflush your machine with a blind filter basket. When backflusing you should only use a good espresso machine cleaner designed for an espresso machine's brew system. DO NOT USE a decalcification cleaner. First, clean the screen and dispersion plate plus the brew head and reassemble, which will prepare you for backflusing. Then, insert the blind filter basket into the portafilter with a ½ teaspoon of cleaner in the basket. Next, place the portafilter into the brew head and tighten. When the machine is hot turn on the brew button for about 10 seconds and then turn off. Then, wait 30 seconds to a minute. Next, turn the brew button on again this time for only about 3 to 5 seconds and then turn off. Wait 30 seconds to a minute. Repeat these last two steps six to eight times. After you have completed the backflushing remove your portafilter and rinse the blind basket with fresh water. Next, you turn on the brew switch to rinse the plumbing. Then, reinsert the portafilter into brew head and turn on the brew button for about 10 seconds and then turn off. Next, turn on the brew button for approximately 3 to 5 seconds and then turn off. Repeat about 4 to 5 times. Always remember backflushing is hard on electric 3 way solenoid valves, so it is not recommended do this no more than four times a year for a machine used in home application. You will find more good is done to your machine be properly cleaning the brew head.
Apr 23, 2011 | Pasquini Livia 90 Espresso Machine
Brew light blinking
Sep 13, 2009 | Saeco Vienna Espresso Machine
Can't Prime Water Circuit
Hi You need to switch Steam ON so it heats up and then turn Steam button OFF (no light) and then turn steamer knob counter clockwise you will hear the pump start up and then water will stream out. This is when it's primed. Turn steamer clock wise to close. You must do this everytime you use the steamer.
Dec 06, 2008 | Saeco VIA Venezia
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
