Question about GE Ovens
Avantium. 120 The display does not display anything.
How do I turn off demo mode for KitchenAid Model KEBS179BSS00
The following is from your Users Manual:
Demo Mode IMPORTANT: This feature is intended for use on the sales floor with 120 V power connection and permits the control features to be demonstrated without heating elements or burners turning on. If this feature is activated, the oven will not work.
1. Press OPTIONS until "DEMO MODE" is displayed.
2. The current setting will be displayed.
3. Press the "1" keypad to adjust the setting.
4. Press START to save the setting.
5. Press OFF to exit and display the time of day http://www.kitchenaid.com/digitalassets/KERS306BSS/Use%20and%20Care_EN.pdf
Feb 19, 2015 | KitchenAid Ovens
Oven ignitor
no.120 works both ways. did you wear gloves when installing. oil from hands can make if fry. remove leads and test for continuity. need to see 0. anything above that its bad.
Nov 10, 2013 | Frigidaire FGB24S5A Gas Single Oven
My Frigidaire electric range wont work (burners and oven)
The clock display works on 120 volts but the burners and oven require 240 volts. I would check the breaker or the receptacle to see if they're bad.They may be supplying only 120 volts. One more less common problem could be the terminal block on the range where the power comes in. Very rarely they will melt. BE SURE TO UNPLUG THE RANGE if you have to check the terminal block. Hope this helps.
Feb 12, 2013 | Frigidaire Ovens
My oven is dead - no display, no nothing. Circuit breakers are fine. Turned them off overnight, still nothing on oven this morning. This happened about a year ago but oven came on again ten minutes...
What you need to check is for power at the clock.TURN OFF BREAKER gain access to clock and use volt meter. One the clock will be wires maked L1 & N on those 2 wires when breaker is turned back on their should be 120 vac. IF 120 vac at those 2 wires,replace the clock, if not 120 vac into clock check for burnt/broken wires
Aug 20, 2011 | Jenn-Air Electric Single Oven
Display Panel Not Working
Only thing is check to make sure clock control is getting 120 volts into the l1 connector on the board. If it is make sure the ribbon cable is plugged into the board properly. If it is replace board.
Mar 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My oven won't light but I don't get the orange glow .
Make sure you have 120 volts to the oven wiring terminal. Could be a completely broken ignitor this time. Disconnect the ignitor wires and attach a volt meter to the incoming ignitor wires. Turn the oven on. If you read 120 volts the ignitor is bad. If you read no voltage the oven control is bad.
Jul 22, 2009 | Ovens
Had a f3 code. changed the oven sensor. now, nothing comes on.
If you have an electric meter check the power input to L1 on the board to the neutral on the board. if you are getting 120 there then the board should light up. if it is not lighting up and you have no response from the keys on the board then you need a new board. if you are getting a response from the keys then set the bake and make sure you are getting 120 off the bake terminal (usually a yellow wire) if you are getting 120 volts out of the board and the oven wont heat you may need a new element. make sure to check all wiring and if you need assistance locating or following wires i can help in the online chat help. if you have your model number i can tell you where to check for exact voltages.
Dec 04, 2008 | Frigidaire Ovens
Ge profile advantium 120, scb1001 oven, display panel out
My GE Profile Advantium120 interior lighting it out .What do i do to replace these bulbs.
Jun 29, 2008 | GE ZSC2001FSS Advantium Electric Single...
LED Display is very dim
Unfortunately this is a bad display, and the kit to fix it (comes with new display board and power/relay board) is about $270 for the parts, and if you cant put it in yourself expect to pay an additional $120-$220 depending on rates in your area. Wish I had better news, but I see these (and Dacors) do this frequently. Hope this helps.
Nov 10, 2006 | Thermador SC272T Electric Double Oven
Ovens Logo
27 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
