Question about Poulan Garden
Manufacturer of poulan chain saws
Looking for complete factory service and repair manuals
  • 486 Answers
Husqvarna
Posted on Feb 04, 2017
  • 211 Answers
SOURCE: chain saw starts then dies shortly after
hi
I think you have a carburation problem.Carefully disassembly the carb and clean it.Check the fuel line and filter,the ventil of the gas tank.
regards savumihai71
Posted on Dec 02, 2008
Idaho_Biker
  • 32 Answers
SOURCE: 38 cc Poulan Chain Saw
Since You weren't Model Specific...I assumed you meant a Poulan Pro 38cc, here's a Contact Site for OEM Manuals:
http://www.poulan.com/poulanpro/manualSearchResultsAJAX.do
Posted on Jan 18, 2009
rowdy45176
  • 2176 Answers
SOURCE: locate exploded drawing of poulan chain saw
I tried a couple locations and found a site that might help go to psep.biz and it will direct you to the blowup. It also indicated that it needed a type number so have that handy. If this doesn't help let me know and I will research further.
  • 398 Answers
SOURCE: I NEEN A OWER MANUAL for a poulan chain saw 2150
its pretty easy to do with a file. first make sure you buy the right size file to fit right in the tooth. look closley at the chain and figure how to place the file on it. the point is to sharpen the side and top of the cutting part of the tooth .always file one way away from yourself. hold the file at an 45 DEGREE angle, and push forward. the trick is to push forward and up at the same time, and always go one direction. start on one side and mark your starting point with tape, go down one side then flip the saw and down the other. you dont have to push hard just enough to were you can see tiny metal fall off. lemme know if you have a problem
Posted on Mar 21, 2009
slohry
  • 87 Answers
SOURCE: Owners manual for Craftsman 20 in chain saw, needed
Parts manual, have model # available
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Posted on Apr 09, 2009
The chain keeps falling off my brand new Poulan sixteen inch blade chain saw
It is possible they gave you the wrong chain for the saw. I would take check the manufacture to see which chain you need then check the numbers on your chain. Other thing it could be is the washer on the clutch may be missing. Either way, it is a new saw, I would take it back.
Apr 01, 2013 | Poulan Garden
Chain won't stay tight on my poulan 222 pro. I have the correct chain size. Does the bar need to be replaced?
No, the bar fasteners are not tight enough. If the saw is under warranty, take it to a servicing dealer for repair or instructions to correct what you are doing wrong. Good luck!
Jul 16, 2010 | Poulan Pro Chain Saw 46cc 20"
Where can i find a service center to purhase a chain adjusting assembly for a poulan 2055 chain saw in the tampa area
Poulan Service Locater
http://www.poulan.com/node6604.aspx
An example of an IPL for a "2055 Gas Chain Saw Type 7" follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2055-Gas-Chain-Saw-Type-7/75.2055-Gas-Chain-Saw-Type-7.1.59.1.html
See the "Handle, Bar and Chassis Assembly" print, item 29, $2.53
If not your saw, yours can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type. HTH
Lou
Feb 24, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need an Idle Speed Adjustment Screw for a Poulan ProPP4218 Chain Saw.
Ordertree.com (Poulan authorized parts outlet)
http://www.ordertree.com/cms/contact-us/9790.html
Telephone - For Handheld or Wheeled Products contact us at 1-877-500-7499
I looked at "Gas Chain Saw PP4218 Types 1 & 2" IPLs. there are no carburetor illustrations. I suggest you contact them by phone. Please have your saw and a supply of common hand tools within easy reach before calling. HTH
Lou
There are often multiple carburetor manufacturer's used on the same model. They can easily help you determine what is on your saw.
Dec 14, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have apoulan pro 10 chain saw need to find arepair shop in my area to fix the brake which is completely broken
The saw or your manual should have an 800 number to call to locate a dealer. Or do a google search for poulan repair and you should get enough information to find a dealer.
Sep 13, 2009 | Poulan Garden
Need chain saw fix
I would try Poulanpro.com and look at their user manuals for the adjustment. They are different on most saws. Hope this helps
Mar 11, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Dec 05, 2008 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
259 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
