Hi,We have a Pyramid Gold Series PS-26k that won't
Hi,We have a Pyramid Gold Series Power Supply transformer PS-26k that won't quit beeping when we turn it on and it won't leave protection mode.
Not sure if it needs repaired or replaced or can be fixed?Any ideas?
  • Kevin Gierlach
    Kevin Gierlach Jul 23, 2009
    The Pyramid Gold Series Power Supply transformer PS-26k starts beeping and blinking the red warning light on the panel as soon as it is powered-on even when it's not connected to anything, like a battery.
  • rara May 30, 2013
    Did ya see the part where he said " that won't quit beeping when we turn it on and it won't leave protection mode." Kinda changes the question for you now, Huh, genious???
    Master:
    Sergeant:
  • 226 Answers
Try changing the battery out
Posted on Jul 21, 2009
  • rara May 30, 2013
    It's a power supply Einstein, when does it take a battery????
TV HAS RED LIGHT SHOWING WILL NOT SWITCH ON
Hi, The red light shows there is power connected to the set. The fact that it won't power up is due to a problem with the power supply circuit in the set. or a problem with the switch circuit or the mains power transformer. Regards John Ps don't know why they're giving me these questions, I answer questions on auto's
Feb 12, 2012 | Wharfedale Televison & Video
What i have to do if protection light is on/
One of your power transistors might have gone short circuit, You will have to have them repaced.
Sep 27, 2009 | Pyramid PS-7KX Regulated 12V 5Amp Power...
Was talking on cb and power supply went to beeping and will not quit. Unplugged it and plugged it back in and still does it. I have a Galaxy DX98VHP hooked up to it in a scale house. Took cb off and it...
THE BEEPS INDICATE THAT THE OVERVOLTAGE PROTECTION IS ACTIVATED,DO NOT HOOK UP ANY THING TO THAT POWER SUPPLY!!!OR THE FULL UNREGULATED VOLTAGE (20-30 VOLTS)WILL PASS FROM THE SHORTED REGULATOR TRANSISTORS TRHU YOUR GALAXY AND FRY IT.GET IT TESTED BY A PRO,USUALLY THE REPLACEMENT PARTS FOR POWER SUPPLY ARE DIRT CHEAP.
GOOD LUCK.
Sep 11, 2009 | Pyramid (PS36KX) 600-Watt Power Supply
Sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Jul 31, 2009 | Sharp Aquos LC-22SV6U 22 in. LCD EDTV
Green and red light are on my pyramid amp and its not working
It could be even simpler than that, yes an improper impedance rating on an amp will cause it to overheat, but should function temporarily until it reaches peak temp. If the outputs were blown the protect light should not light up being that they would need to work to cause the protect light to come on. I would double check all of your connections, one small little crossed wire would cause an amp to immediately go into a protect mode.
May 29, 2009 | Pyramid PB1217X Car Audio Amplifier
Re: Pyramid PS-36kx power supply buzzer sounded,red light came on
Hi! I saw your question, and maybe this will help. I also have a Texas Star 100w amp, and this same power supply. Even though the nominal draw for your equipment is way below the rated amp flow of the power supply, when you key up, and the output on the amp is at max, you are drawing the limit of your power supply! Try running this setup at a lower linear output. You don't need the full 100 watts to get out! 60-80 watts is aplenty! You should start at a low output, and slowly increase the output(while keyed up), untill the power supply starts to complain.(buzzer/light). This is what your limit will be. The only other cure, is a MUCH bigger power supply. Unfortunately, I cannot afford a 60-90 amp supply, so this is what I am forced to do to use the one we have. Also,keep your cb's output very low when using the linear amp. These amps are supposed to get a low signal from your radio, or the linear amp is overdriven. (noisy and unstable. Hope this helps you! 73's to you! jimsjinx
Apr 30, 2009 | Pyramid (PS36KX) 600-Watt Power Supply
Computers & Internet Logo
497 people viewed this question
David Payne
David Payne
