Question about Cell Phones
How to delete widgets from home screen. - Cell Phones
rootbeer001
  • 352 Answers
SOURCE: How do I remove and manage widgets from my home
To remove widgets from your screen, long hold the widget, and drag to the Remove button at the bottom of the screen.
To move a widget around, long hold and drag the widget to a different part of the screen. If you want to drag it to a different screen, use your track ball while long holding the widget.
To add a widget, press on the (+) button and the select HTC Widget or Android Widget.
To remove music and wallpapers (which are stored on your SD card), you first need to connect your phone to the computer via a USB cord. On your phone, go to your notifications screen (swipe down from the top of your screen). Select "Mount" and your computer will now recognize your phone as an external storage device.
The music files are in the Music directory, and the graphics are located in the Wallpapers directory.
Remember to Turn off USB Storage by going through the notification screen again.
Hope this helps and good luck.
Posted on Jan 15, 2010
supernova278
  • 1932 Answers
SOURCE: how do I delete widgets off home screen if I have
Just tap and hold the widget you need to remove.Then you will get a remove option below the screen ,drag the widget and put in remove.This will remove the widgt you need to remove.
Thank You
Posted on Jan 05, 2011
guru_fixya
  • 944 Answers
SOURCE: Hi. My memo widget
Check page 38 does it help?
www.cellphones.ca/upload/manuals/lg-xenon-gr500-manual.pdf
Still problem persist then go for.
Reset:
Goto settings and select phone, then select reset settings and master reset . This will make all ofyour setting go back to default but it wont delete anything
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Feb 07, 2011
  • 6702 Answers
SOURCE: How can I delete widgets from my screen?
Because you forgot to give details about your tablet, I do have to do some guessing here.
Realise some brands and some providers o add apps to the phone and tablet, but they don't allow you to remove them. Samsung could be very bad, putting more than 8 Gbyte of extra apps on the device. So perhaps some of the apps you try to remove you can't remove, unless you can root the device. Be aware you only can root with the correct boot rom, special for your device. No other image must be used, or you will brick your device.
Posted on Feb 05, 2015
txslim55
  • 1103 Answers
SOURCE: How do I remove widgets from home screen?
Closing and Deleting Apps on the iPad
Posted on Sep 20, 2015
Howto delete widgets
Widgets can be removed from your home screen by long pressing the widget and dragging it to the top, or bottom (depending on your launcher) until it turns red, and then letting go of it, or dropping in trash can.
Nov 15, 2016 | Cell Phones
How do I delete widgets off Huawei H881C?
Should be the same as deleting an app shortcut - hold down on the widget until it starts to float, then drag it to the delete icon that will appear either at the top or bottom of your screen.
Aug 15, 2014 | Huawei Cell Phones
Widget Removal
Hi if you want delete anything from your home screen press and hold it for few seconds and you should see depends from your os bin or remove sign at the top or bottom of screen then drag it there and it's done.
Apr 14, 2014 | LG Xpression MobiPhone - Red at&t
Removing duplicate widget from Android tablet homescreen
Keep your finger on the widget until it changes colour then drag it to the waste bin on the screen and let go. Depending on tablet,software etc waste bin could be centre top of screen, taskbar bottom of screen or at the side but it will be there.:-)
HTH
Jan 09, 2014 | Mach Speed Trio Stealth Pro 9.7cm 4.0 Trio...
HOW CAN I REMOVE WIDGET FROM MY SAMSUNG GT C6712 ON SCREEN
I think the Widget in the Home screen is in-built.
Just click the widgets button, you can see the bottom, available widgets appears... just drag and Drop widgets to keep in screen and remove from screen.
Jul 23, 2011 | Samsung B5722 Cell Phone
How do you add people to call on your htc cell phone
  1. Go to a part of the Home screen where there's space to add a new widget.
  2. Tap howtoimage.aspx?id=4415 or press and hold on the Home screen. The Add to Home options menu is displayed.
  3. Tap Widget > People.
  4. Choose the widget style, and then tap Select.
  5. Select the group you want to add as a widget.
  6. Drag the widget to a blank space on a Home screen, and then release. or visit this linkhttp://www.htc.com/uk/howto.aspx?id=3350&type=1&p_id=316 thanks
Jul 01, 2011 | HTC Wildfire Cell Phone
I accidentally removed the clock/weather widget from my home screen trying to pull down my notifications bar, and now I can't find it! How do I get it back?
It's actually a pretty simple way to add widgets back to your home screen.
Long press a blank area of your home screen. A dialog box to Add to Home will appear. Select Widget, and then select Clock [HTC]. You will be able to select from 12 different HTC Clock widgets. Select the one you like, and then press the Select button. It will appear on your home screen as long as there is enough room for it. You can move the widget around by long pressing on the widget and sliding your finger to the desired location on the screen.
Good luck.
Feb 01, 2011 | HTC Hero Smartphone
How do I delete widgets off home screen if I have put them on by mistake
Thank You
Jan 05, 2011 | HTC Wildfire Cell Phone
How do I remove and manage widgets from my home screen? Also, how do I delete the photos and music that is already on my phone?
Jan 13, 2010 | HTC Hero Smartphone
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
