The display panel lights up but no settIngs such as time and temp show on display. I cannot choose low or high or any length of time or temp on any function. It's just a blank grey screen.
  • 297 Answers
SOURCE: Audi A4 2.5 V6 TDI - Creamy grey coolant in expansion tank
Sounds like blown head gasket (or worse) still to me.
Remove oil filler cap and look for grey oil.
Never use water these days but special coolant. Water makes vapour spots and cause block cracks, worse then blown gaskets!!!
vapour does not cool very well.
Look like you have cracks already.
Take a compression test if possible. But might not show op at that temperature.
The gauge indication troubles me.
Posted on Apr 14, 2009
  • 4 Answers
SOURCE: nikon d90 lcd screen
clearly not good! bring it to a repair shop is the only thing to do I guess.. good luck with it!
Posted on Oct 29, 2009
lscf150
  • 443 Answers
SOURCE: Electronic function pad keeps quitting. It blanks
Sounds like a control board failure,which is a microprocessor,printed circuitboard, typically those are not repaired but replaced.That is a module that can be located behind the control panel, unplugged and the new one plugged in and should get you up and going again. Good luck !
Posted on Nov 26, 2009
  • 572 Answers
SOURCE: Frigidare oven model ples389ecc displays error
i think the clock is bad
Posted on Feb 06, 2010
SOURCE: instrument panel lights don't work
please advice, have you solved the problem? I have the same one on my Sebring. Many thanks.
Posted on Apr 06, 2010
Why is all lights flashing on display but wont respond by pushing buttons.. keeps beeping??
Unplug it, wait 15min replug and start again..the lights should indicate the high and low temp long or short time , and then of course warmer ..sometime high and low as well
Good luck
Aug 14, 2014 | Crock Pots & Slow Cookers
Climate control on rover 45 diesel 2004
normally the climate control unit itself which is part of the display panel inside
Jan 14, 2014 | Cars & Trucks
How do we operate and turn on it i have no manual
The left button under the temperature display lets you toggle between the heat output (high, medium and low) settings. Press the left or right side of the buttons. The center button sets the timer; press the left side of the button repeatedly to increase the run time. Press the right side to lower the length of time before the heater shuts off. The right hand button sets the desired final temp. Again it's an up/down toggle on the left and right sides of the button. Once you get to the desired temperature (in 1 degree increments), the display will return to showing the current temperature three seconds after you release the button.
Home Depot has the Use and Care manual on their product site: http://www.homedepot.com/buy/honeywell-1-500-watt-oil-filled-convection-portable-heater-hz-709.html#.UMp5GTmk5G8 . The direct link is http://www.homedepot.com/catalog/pdfimages/79/79058e0a-291f-48e8-8667-ff500b3d7bb7.pdf?cm_mmc=seo'altruik'202804472 . You will need Adobe Reader or a similar program to view the document.
I hope this helps.
Dec 14, 2012 | Honeywell HZ-709 Oil Filled Radiator...
How do i set the time on w westinghouse pgn659s wall oven?
Instructions below.
  1. 1 Fill the insert of the Corningware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  2. 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  3. 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
thank for visit.
Oct 09, 2010 | Ovens
The display works (clock, mode, etc) I can push
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Apr 27, 2010 | Whirlpool GH9176XM Microwave Oven
Drying manually
Select speed dry. The time button changes time (20,30,40,50,60 minutes) and you can use the small silver buttons on either side of the display to add or subtract individual minutes, so you could set for 43 minutes or 67 minutes for example. Remember to select the temp you desire also.
Oct 15, 2008 | LG DLE5977 Electric Dryer
Logiteck quickcam communicate
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Troubleshooting: Image Quality for Cameras trnsp.gif Detailed Description This article covers some standard troubleshooting for issues such as fuzzy, grainy, out-of-focus or off-color camera images. trnsp.gif Answer The information in this article applies to the following software
QuickCam 9.x and below
ImageStudio 7.x and below
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens. This will allow you to focus the camera image on objects at different distances. Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video. Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed. Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds. If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
Changing Display Adapter Settings:
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter. For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher. To change the color palette please perform the following steps:
  1. Click on "Start," "Settings," and "Control Panel."
  2. Double-click on the Display icon.
  3. Click on the tab labeled Settings.
  4. In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
  5. Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost." If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software. To do this:
  1. Open the QuickCam software.
  2. At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
  3. Choose "Advanced Camera Settings".
  4. Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
  5. If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
  6. Click OK when your are done.
Mar 05, 2008 | Logitech QuickCam Communicate STX Personal...
Logitech web cam
Connection Issues:
Low Light Boost:
Feb 27, 2008 | Logitech Quickcam Chat Webcam
Shows Dark
Connection Issues:
Low Light Boost:
Jan 13, 2008 | Logitech Quickcam Chat Webcam
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
