Question about Home
Austroflamm pellet stove 2004 doesn't stay on turn switch on n off led red light blinks ones n I push fuse until stay on
Wrong fuse , bad sensor I check connections or bad switch ?
wyoed1
  • 211 Answers
SOURCE: Screen went black
I am working on one right now with a similiar problem. The power supply is bad in the one I am working on, and sadly, the part is not made anymore. I hope you have better luck than I am finding the bad component in yours. Sorry for the negitive answer.
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
SOURCE: hdtv won't turn on
have westinghouse 52" TX-52F480S won't turn on???
Posted on Apr 09, 2009
  • 436 Answers
SOURCE: 2004 monte carlo. turn signals dont work. the
try pressing the hazards on and off if they still don,t work replace the flasher unit. it is built into the hazard switch( all one unit ) change this and all will be good.
Posted on Aug 30, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Posted on Sep 14, 2009
Testimonial: "You are on the right track even with my poor explanation. Thank you"
MECP Guy
  • 344 Answers
SOURCE: astra remote car starter problem
your remote starter is in valet mode, the door lock will still work but no remote start, try pressing the trunk button 3 times, if that doesn't work turn the ignition switch on and off 5 times
Posted on Jan 09, 2010
How do I deactivate my aps57c mobile audiovox alarm
  • Locate the push-button LED switch on the alarm box under the driver's side dash. The small red or black button is used to manually disable the alarm.
  • Put the key in the ignition and turn it to the "on" position. This activates your vehicle's battery, but doesn't start the engine. Press and hold the push-button LED until the LED light stops blinking. Once the LED stops blinking the alarm is disabled until you manually reset the alarm.
  • Start the car. Then, press and release the push-button LED switch once, to reset the alarm.
Apr 01, 2017 | Audiovox Vehicle Parts & Accessories
Harman pellet stove blower not coming on. All lights are on and not blinking.
well im not sure why a pellet stove question is here in the pool section , but I do own a pellet stove (and a few pools too) SO I can offer one thing to look for , there is a small switch on the side of your burn chamber (soup can looking thing) this switch is what controls your fan to come on . it works by sensing heat from burn chamber and then turning power on to fan , its possible this isn't passing any power on yours ?
Oct 04, 2016 | Home
I replaced the power board on my Scott TV LCT37SHA. when I press the power button the red light blinks as I push it. if I hold down the power button it just blinks until I let it go. please help!!
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jan 18, 2015 | Scott Televison & Video
My S107G is fully charged, I turn on and off transmitter on different frequencies, turn the heli on and off according to my instruction manuel, but the lights on the heli are on,the circuit board red led...
I have similar problem with my LS-208 heli.
Helicopter leds are blinking red/green, front white led is on, and tail leds are blinking too.
Remote controller red led is on as should be but helicopter doesn't respond to controller at all.
I followed instructions above with no success.
Anyone has a suggestion?
Regards, Yaron.
Jun 12, 2012 | SYMA Toys industrial New Syma S107 Radio...
Sony trinitron kv-es29m80 tv has no led light
The blinks are fault indication. If the standby light blinks 10 times and the set shuts down after that;
Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board
Apr 12, 2012 | Televison & Video
Quadra Fire Pellet stove-will not ignite
I own a Quadrafire pellet stove. I have had this thing for 10 yrs. It seems every year at the start of the season I have some kind of problem. I clean it at the end of the season completely. First couple of burns are fine then get a good cold day and it doesn't work. All the gaskets, the exhaust blower, ignitor, glass front, and exhaust piping have had to be replaced. Now I have a blinking red light in the control box and cannot find anything on line to help. Does anyone know why this red light blinks 3 times every 10 seconds inside the control box? It's not the call for heat light. Think I may change to a wood burning stove to many headaches.
Oct 20, 2011 | Napoleon Auburn Pellet Stove Heater
Trying to hook up a RTH2310B thermostat to a wood pellet stove with only two wires.. How do I know where to connect them too?
Hey Brad432, this is what i did with the same RTH2310B thermostat and my harmon stove. You must have the heat sensor that plugs in the back of the stove to start with. Take your new wire from the stove to your thermostat, red to rh, white to one side of your sensor then other side of sensor to W on your thermostat. On your stove side set your room temp as high as it will go and let your programmable thermostat set the room temp. Works good for mine. Good Luck
Nov 01, 2010 | Honeywell Focus 6300B 5-2 Days...
Astra remote car starter problem
Jan 03, 2010 | Astra Car Alarm And Remote Starter,...
Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Apr 01, 2008 | Brother HL 1440 Laser Printer
Screen went black
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Televison & Video
Home Logo
23 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
