Question about Echo Garden
Setup echo dot?
Echo dot?
#1 Taper
  • 1040 Answers
SOURCE: my echo will start ,but will not run.
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spraywith carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
Use a Den Tek Brush, (,to clean the small portals in carb. These portals canbecome blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Posted on Jun 25, 2009
  • 2220 Answers
SOURCE: pb1000fuel to oil mix ratio for echo
New Echo manuals say "50:1 for all engines regardless of what is printed in manual."
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Posted on Nov 09, 2009
  • 12 Answers
SOURCE: Hi, i've got an astatic mobile max echo chamber
just replace with same ohms.....replace example--- 100k with 100k 5k with 5k etc......any old C.B. ....stereo...dont matter...what matters is the ohms
Posted on Jan 25, 2010
  • 96 Answers
have you read the dataset in (i.e $row)?
you would require some sort of select statement to read the data frm sql into a dataset before yopu can read and display each record in the dataset.
i gather you may be new to sql statements. the bottom commect $query.... is reading the dataset into $query, the one you have issues with needs code that reads a record into $row
Posted on Feb 06, 2010
  • 5 Answers
SOURCE: i need a carberator for an echo back pack blower
Hey I recently found out that Echo will not sell to public directly.
its on the web site .you can purchase through their authorized dealers
only. I purchased a carburator for $42.71.look out for price mark ups
from diffrent around.Good luck.
Posted on Mar 28, 2010
Need echo dot app with setup instructions
hi Gary.
  1. Turn on Echo Dot. Place your Echo Dot in a central location (at least eight inches from any walls and windows). ...
  2. Connect Echo Dot to a Wi-Fi network. In the Alexa app, follow the instructions to connect Echo Dot to a Wi-Fi network. ...
  3. Talk to Alexa. ...
  4. Optional: Connect Echo Dot to an External Speaker. Help: Set Up Your Echo Dot
if this does not help you out go to this link and read up some more.
echo dot app with setup instructions Google Search
Nov 20, 2017 | Echo Computers & Internet
Setting up echo dot
hi roger.
see if this helps you out.
or if you need more help go to this link.
Setting up echo dot Google Search
Nov 16, 2017 | Echo Computers & Internet
My echo won't turn on, I've tried the fix on my app but the orange light doesn't come on
to restart your Echo device, unplug the power adapter from the back of the device or from the wall outlet. Then, plug the power adapter back in. To reset your Echo Dot that has volume buttons:
  1. Press and hold the Microphone off and Volume down buttons at the same time until the light ring turns orange (about 20 seconds). Then light ring turns blue.
  2. Wait for the light ring to turn off and on again. The light ring then turns orange again, and your Echo Dot enters setup mode.
  3. Open the Alexa app to connect your device to a Wi-Fi network and register it to your Amazon account.
You did not state if it is a dot or not if it is not a dot, there is a reset button that you can press in with a paper clip.
I hope this helps.
Aug 18, 2017 | Orange Computers & Internet
How do I connect conventional speakers to Alexa?
  1. Set your Echo Dot and external speaker at least three feet apart. When Echo Dot is close to external speakers, it may be more difficult for Alexa to hear the wake word and other requests.
  2. Turn your external speaker on.
  3. Plug one end of an audio cable into your speaker and the other end into Echo Dot. All audio from Echo Dot now streams through your external speaker.
May 21, 2017 | Computers & Internet
How do we set up echo to our home Internet?
to setup the Amazon Echo you need its Amazon echo app from the google playstore app normally the echo will tell you how to do so on its own if it is your first time setting the device up
Jan 08, 2017 | Miscellaneous
I bought 2 echo dots i was able to connect one but the 2nd one wont connect
Check and make sure you follow all the steps it took to connect the first echo dot
1. If the setup process does not automatically start, press and hold the Action button on Echo Dot for five seconds. Then, open the Alexa app, and go to Settings > Set up a new device.
2. If Echo Dot doesn't connect to your Wi-Fi network, restart Echo Dot by unplugging and plugging the device in again
Nov 26, 2016 | Office Equipment & Supplies
Open Questions:
Garden Logo
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Are you an Echo Garden Expert? Answer questions, earn points and help others
