X:\windows\system32 - Computers & Internet
  • kakima Dec 25, 2016
    Hi edwin solano vasquez, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What is the question?
Registery cannot load hive file/systemroot/system 32/config/software or its log of alternatice is corrupt, absent or unwritable on compaq presario2227US
Solution 1
Requires some tech skills:
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Solution 2 Reinstall Windows Xp
Jan 29, 2014 | HP Compaq Presario CQ60-249US Notebook
Saying:/windows/system32/config/system is missing or corrupted n i dnt now how to fix it wut link exactly do i have to download to my usb to fix it n wut r the steps?
Assuming it is windows XP here are the steps to fix that error:
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line:md tmp
My YouTube Channel
Click Here Live Tech Support
May 03, 2013 | ASUS Eee PC 2G Surf Notebook
So how can I restore my v b script host on my netbook with windows 7 ?
Fix Windows Script Host If you are experiencing script host issues, you might notice error messages such as "Library not registered." Script host issues occur when scripting components do not exist in the Windows registry, according to Microsoft. Your version of Windows determines how the missing scripting components affect your system. You can repair script host problems by using your PC's native features.
Press the "Windows" key. Type "cmd" in the dialog box and press "Enter." This will open the Command Prompt. Type the following commands at the prompt one at a time and press "Enter:" regsvr32 %systemroot%\system32\vbscript.dll regsvr32 %systemroot%\system32\jscript.dll regsvr32 %systemroot%\system32\dispex.dll regsvr32 %systemroot%\system32\scrobj.dll regsvr32 %systemroot%\system32\scrrun.dll regsvr32 %systemroot%\system32\wshext.dll regsvr32 %systemroot%\system32\wshom.ocx Exit the Command Prompt. b> Register Components on 64-bit Systems b> Press the "Windows" key. Type "cmd" in the dialog box and press "Enter." This will open the Command Prompt. Type the following commands at the prompt one at a time and press "Enter:" %systemroot%\system32\regsvr32 %systemroot%\system32\vbscript.dll %systemroot%\system32\regsvr32 %systemroot%\system32\jscript.dll %systemroot%\system32\regsvr32 %systemroot%\system32\dispex.dll %systemroot%\system32\regsvr32 %systemroot%\system32\scrobj.dll %systemroot%\system32\regsvr32 %systemroot%\system32\scrrun.dll %systemroot%\system32\regsvr32 %systemroot%\system32\wshext.dll %systemroot%\system32\regsvr32 %systemroot%\system32\wshom.ocx Exit the Command Prompt.
Enable Windows Script Host b> Windows Script Host is an administration tool by Microsoft that creates an environment for hosting scripts. According to Microsoft, Script Host will manage security and invoke the proper script engine. Script Host comes standard on all Windows operating system versions 98 and later. Therefore, you can easily enable Script Host on your computer. Go to the Windows Desktop. Click on the "Start" button. Select "Run" from the menu of options and icons that opens. Type the word "regedit" into the text box of the Run window and then click "OK." The Registry Editor window will appear. Select "HKEY_CURRENT_USER\Software\Microsoft\Windows Script Host\Settings" from the folders on the left of the Registry Editor window. Double click on "Enabled" in the window pane to the right. Set the Value to 1. Return to the folders list in the Registry Editor. Select the folder "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Script Host\Settings." Again double click on "Enabled" in the window pane to the right and set the value to 1. That's it, you have successfully enabled Windows Script Host.
Jan 15, 2013 | MSI Ge620-021us 15.6in Hd 1080 Led...
Fix my vb script engine on my computer / Windows 7
Jan 15, 2013 | Microsoft Windows 7 Home Premium 64BIT...
SERIAL NUMBER
1) Run wga tool to check - genuinity , type of copy (OEM/Retail)
Link :
http://go.microsoft.com/fwlink/?linkid=52012
Shortlink :
http://downloadwgadiagtool.notlong.com
2) Check date/time
Do the below troubleshooting steps in safe mode
3) Check the "value data" for the following keys under HKEY_CLASSES_ROOT\.htm
1. Default
2. Content Type
3. PerceivedType
- Double click each of the above keys
- check the value data (default value data)
Defaut = htmlfile
Content Type = text/html
PerceivedType = text
- If the value data is different, change it to the above default value
4) Reregister the following dll files
regsvr32 licwmi.dll
regsvr32 regwizc.dll
regsvr32 licdll.dll
regsvr32 jscript.dll
regsvr32 vbscript.dll
regsvr32 msxml.dll
regsvr32 shdocvw.dll
regsvr32 softpub.dll
regsvr32 wintrust.dll
regsvr32 initpki.dll
5) Rename/replace the dll files
rename c:\windows\system32\licwmi.dll licwmi.old
rename c:\windows\system32\regwizc.dll regwizc.old
rename c:\windows\system32\licdll.dll licdll.old
rename c:\windows\system32\wpabaln.exe wpabaln.old
expand d:\i386\licwmi.dl_ c:\windows\system32\licwmi.dll
expand d:\i386\regwizc.dl_ c:\windows\system32\regwizc.dll
expand d:\i386\licdll.dl_ c:\windows\system32\licdll.dll
expand d:\i386\wpabaln.ex_ c:\windows\system32\wpabaln.exe
copy c:\windows\system32\licwmi.dll c:\windows\system32\dllcache
copy c:\windows\system32\regwizc.dll c:\windows\system32\dllcache
copy c:\windows\system32\licdll.dll c:\windows\system32\dllcache
copy c:\windows\system32\wpabaln.exe c:\windows\system32\dllcache
6) Initiate to activation tool
- Create a new dword value under HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows
NT\CurrentVersion\Winlogon
- dword value named : Activation Required
- set the dword value as : 1
(or)
- goto HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\Current
Version\WPAEvents\oobe timer
- change atleast one digit of oobe timer value data
7) Delete RESET5 keys
- start > search tool > search for reset5.* > delete all the files
8) Rename/replace WPA.DBL file
ren c:\windows\system32\WPA.dbl wpadbl.old
MGA Diag : http://go.microsoft.com/fwlink/?linkid=52012
Validation tool : http://www.microsoft.com/genuine/diag/
Regards
Apr 27, 2012 | Microsoft Windows Vista Home Premium with...
Problem with OS. How can I fix? Net book states - Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM Can you help? Thanks Philip
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change C:\Windows to the appropriate windows_folder if it is a different location.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 03, 2010 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
I have toshiba L300 pc laptop, i tried to formati
kindly follow these steps:
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 20, 2010 | Toshiba Satellite Pro L300 Notebook
Acer recovery disk download
i keep getting this on my lap top and cant get ride of it can you help me??
Multi (0)disk(0) rdisk (0) partition (2)\Windows\AppPatch\drvmain.sdb
TRAP 00000006================EXCETION================
multi(0)disk(0)rdisk (0) partition (2) \WINDOWS \system32\DRIVERS\WMILIB.SYS
multi(0)disk(0)rdisk (0) partition (2) \WINDOWS \system32\DRIVERS\pci.sys
tr=0028 cr0=80000013 cr2=00000000 cr3=00039000em32\DRIVERS\isapnp.sys
gdt limit=03FF base=0003F000 idt limit=07FF base=0003F400compbatt.sys
multi(0) disk(0) rdisk(0) partition(2) WINDOWS\system32\DRIVERS\BATTC.SYS
cs:eip=0008:0009F737 ss:esp=0010:000600EC errcode=0000IVERS\pciide.sys
flags=00010012 NoCy NoZr IntDis Down TrapDis ystem32\DRIVERS\PCIIDEX.SYS
eax=00000000 ebx=00000100 ecx=0000BB40 edx=00030715 ds=0010 es=0010sys
edi=00060D4C esi=00000000 ebp=00060E34 cr0=80000013 fs=0030 gs=0000s
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\ACPIEC.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\OPRGHDLR.SYS
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\PartMgr.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\VolSnap.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\atapi.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\disk.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\CLASSPNP.SYS
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\drivers\fltmgr.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\sr.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\KSecDD.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\Ntfs.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\DNIS.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\Mup.sys
Feb 06, 2010 | Acer Aspire 5315 Notebook
When I turn on the 1525 Dell laptop...a screen comes up saying windows could not start because the following file is missing or corrupt.windowssystem32configsystem. The page then suggests attempt to repair...
it is nothing but windows registry error. do one thing in another pc download the Hiren's boot cd from internet, write that file in a cd, try to boot from that cd & repair the registry. otherwise just format the operating system & reload the OS.
Jan 10, 2010 | Dell Inspiron 1525 Notebook
Windows XP Missing configuration?
Sounds like you may have bad RAM. Try removing all of the RAM modules on your motherboard and put only one in the first slot. Start the computer and see if it works.
Jun 17, 2009 | HP L1706 17" LCD Monitor
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
