Question about Apple - iPhone 6 Plus 16GB
I forgot my passcode to my iPhone 6 plus - Apple - iPhone 6 Plus 16GB
  • 20 Answers
SOURCE: I forgot my passcode to unlock my iphone
It depends on the severity and the settings you have given the iPhone and whether you have the computer that you synced your iPhone with... Here's the full explanation. I would recommend reading the second paragraph first, but the solution if you really forgot your password is in the first paragraph.
==If you have the computer you synced your iPhone with==
If you cannot remember the passcode, you will need to restore your device on the computer that was used to originally sync the iPhone or iPod touch so that you can reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced to the iPhone or iPod touch, you will be able to unlock the device for use and remove the passcode but your data will not be present. Refer to "Updating and restoring iPhone and iPod touch software."
"If you enter the wrong passcode too many times, you'll see a message that says "iPhone is disabled" and to try again later. If you repeatedly enter the wrong passcode, iPhone or iPod touch will be disabled for longer intervals, before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect to the computer you normally sync with. Note that starting with iPhone 2.1 software, there is a setting to cause the device to erase itself after 10 consecutive incorrect password attempts. This setting is off by default. It  can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode."
The full article can be found here: http://support.apple.com/kb/HT1212
==If you don't have the computer you synced your iPhone with==
If you don't have the original computer the iPhone synced with, the only solution is to force your iPod Touch into recovery mode and then restore it. You will lost all the data on the iPod Touch, but after this method is done, everything will work. You can find the steps to solving this problem here:
http://support.apple.com/kb/HT1808?viewlocale=en_US
Posted on Feb 13, 2009
SOURCE: i forgot my passcode and now my iphone is disabled.....
how do i find out what my passcode is
Posted on Sep 11, 2009
SOURCE: Forgot passcode unlock on iphone 2g
f u c k t h i s w e b s i t e
Posted on Feb 03, 2010
  • 192 Answers
SOURCE: i forgot my apple iphone
Try the Restore procedure from iTunes If you have problems. But first try the recovery procedure.
1.
Disconnect your iPhone cable but leave connected the other USB end to the computer.
2.
Turn off your iPhone holding the Sleep/Wake button. The red slider bar appears. Slide the bar and wait until the iPhone turns off. Or you could hold the Sleep/Wake and Home buttons at the same time until the iPhone turns off.
3.
While pressing and holding the Home button connect the USB cable to your iPhone. It should power on. Hold the Home button until you see the "Connect to iTunes" message. Open iTunes if necessary. You should see the "iTunes detected an iPhone in recovery mode..." alert screen.
Choose " Restore"
Posted on Feb 21, 2011
mobil master
  • 14641 Answers
SOURCE: iphone new passcode I forgot my passcode
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Sep 27, 2012
I need to reset my phone amd i forgot my passcode
Hello Karabo, what kind of phone do you have?
If you're an iPhone user and forget your passcode, you will have to factory reset it without Apple ID. To do this you need first put the phone into DFU mode and connect it to iTunes. Your iTunes will help you to reset your iPhone without entering Apple ID easily. Restoring iPhone to factory settings with this method will result in wiping all the data. The following steps will show you how to do that.
1. Open iTunes on your computer and connect your iPhone to the computer with a USB cable.
2. After that, turn off you device. Press and hold the Home button for 3 seconds.
3. Put your iPhone into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPhone into DFU mode.
4. When iTunes detects that your iPhone is in recovery mode, you can restore it now.
5. Click on Restore iPhone. Then you will be notified after the reset and your iPhone will take a restart.
After factory resetting iPhone, you will get all the data swept from iPhone 6 Plus, and you can restore the files from your iPhone, iTunes backup or iCloud backup.
How to Restore iPhone 6 Plus to Factory Settings
Jan 19, 2017 | Cell Phones
How do i disable the passcode on a iPhone 6 plus with IOS 10.0.2.
You can't unless you do a factory reset, this wipes the phones memory clean along with the password or code.
Oct 06, 2016 | Cell Phones
My iPhone has disabled how do I unlock it
If you forgot the passcode for your iPhone, iPad, or iPod ...
https://support.apple.com/en-us/HT204306
Apple Inc.Nov 2, 2015 - If you enter the wrong passcode in to an iOS device six times in a row, you'll be locked out and a message will say that your device is disabled. ... If you're signed in to iCloud and Find My iPhone is enabled, use iCloud. If you don't use iCloud and you can't ... If it doesn't, learn what to do. Once the sync and ...
How to remove/reset any disabled or Password locked ...
? 5:31
https://www.youtube.com/watch?v=csLUmaDTHl4
Oct 30, 2014 - Uploaded by Karlos Corner
iTunes will alert you that it has detected a device in recovery mode. 6. .... easy and fast to activate/unlock/jailbreak/bypass every iphone from 5s to 6s without having any problems. use "newunlockiphone,net". .... +Clair Glen My iPhone is disabledfor 23,760,796 minutes. ... Do you need an ITUNES account?.
Top Ways To Unlock iPhone Disabled - YouTube
? 2:35
https://www.youtube.com/watch?v=KiWp28QTToQ
Jan 1, 2014 - Uploaded by CocTubes
How to Unlock Your iPhone When Its Disabled .... me use myfingerprints like it normally does. of anyone has anyway of helping.... What to do?
Dec 16, 2015 | Apple iPhone 4 Black Smartphone
Forgot id and password
If you forgot the passcode for your iPhone, iPad, or iPod touch, or your device is disabled Follow these steps if you've forgotten your passcode, or if a message says that your device is disabled.
Forgot passcode for your iPhone iPad or iPod touch or your device is...
Sep 21, 2015 | Apple iPad Mini
How to open my iphone if i forgot the passcode.?
If you can't remember your passcode, you'll need to erase your device using iTunes, Find My iPhone, or recovery mode. Then use a backup to put your data and settings back on your device. You can try plugging it into iTunes to see if it reboots itself
May 07, 2013 | Apple Iphone A1303 16gb
Iphone new passcode I forgot my passcode
Sep 26, 2012 | Apple iPhone 3G
Apple - iPhone 6 Plus 16GB Logo
55 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
