Question about Zephyr Savona ZSA-M90S Kitchen Hood
Zephyr ZMI-M90S stopped working
Was changing bulb on Zephyr ZMI-M90S when there was a spark and a short which set off the circuit breaker in my basement. After that, no fan or lights. Is there a fuse in the unit somewhere?
  • fbm2k May 02, 2009
    The lights work but the exhaust doesn't>
  • 833 Answers
The company doesn't list such a part. Probably, you have a bad connection in the unit. With the power off, remove the motor housing. Find the connection box and fix up the connections.
Posted on Dec 09, 2007
My Zephyr hood model zto-m79s lights don't work. The unit was installed in 2007. Sometimes they sputter, flashing briefly, then nothing. Do I need a service call or can I fix it myself? Nancy
Try taking out the bulbs and wiping with a clean dry cloth. Sometimes when bulbs get hot the connection loosens, when you screw them back in do not over tighten.
Dec 13, 2009 | Zephyr Savona ZSA-M90S Kitchen Hood
How do I change light bulbs on a Zephyr Milano hood?
Hi elenara, try applying slight upward pressure as you turn the bulb. Remember righty tighty, lefty loosy. This worked for us, now if I could only find a replacement bulb. Good luck!
Feb 14, 2009 | Zephyr Milano-S ZMI-M90S Kitchen Hood
Light blub burnt out
The easiest way to remove the light bulb is to wear a rubber glove, use your palm to press against the bulb, and turn counter-clockwise.
The suction created by the rubber glove should allow you to remove the light bulb easily.
Jan 12, 2009 | Zephyr Savona ZSA-M90S Kitchen Hood
Need to change lightbulb of Zephyr Savona Zsa-m90s
I'm not sure if my Savona is the same one, but on mine, just remove the filter and you can see the base of the light bulb up above the fan base. You can see where the bulb screws into the fixture. Grab the ceramic portion of the bulb, and turn that part. You may want to steady the socket with your other hand because it is very flimsy.
Dec 12, 2008 | Zephyr Savona ZSA-M90S Kitchen Hood
Can't figure out how to get bulbs out of hood to replace on Zephyr Milano-G ZMI-M90G Kitchen Hood
just use an adjustable pliers wide enough to grip the outer small edges. Grip, turn counter clock wise and remove. The other way to do this is unscrew the panel behind the filters and you should be able to reach the neck of the bulbs.
Nov 30, 2008 | Zephyr Milano-G ZMI-M90G Kitchen Hood
Neither lights nor fans work
don't know model but they are all much the same.
there will be a pcb behind the control buttons and you will find some of the track burnt out causedd by the bulb blowing. do a soldered wire link across the burnt section of the track
Sep 25, 2008 | Zephyr Typhoon AK2100 Kitchen Hood
Zephyr Milano hood fan and lights stop working. Power is on.
Hi ronio,
I'm Harvey the Master Plumber.
Your problem is: After the power went out your Zephyr hood lights and fan don't work at all. There is a faint glow on the digital display but the fan and lights don't respond to pressing the control buttons.
First check the circuit breaker. If OK then check the transformer in the unit. It's next to the fan motor. If no power on the high side then you have a loose or broken connection. If you have no power on the low side the you have a bad transformer. If OK then you have a bad control board.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Sep 22, 2008 | Zephyr Milano-S ZMI-M90S Kitchen Hood
Zephyr Savona ZSA-M90S Kitchen Hood Logo
829 people viewed this question
Top Zephyr Kitchen Ranges Experts
Tom Chichester
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
