Brushes for shredcare omo4692
Brushers are worn on the auto motor where can i get replacement brushers? model omo4692
b0sslady2001
  • 357 Answers
SOURCE: Motor is making blue sparks.
It's the brushes for sure!!! My switch repair guide will get you down to the carbon brushes easily...
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
marci
Posted on Jul 31, 2008
dontbother10
  • 2220 Answers
SOURCE: Need brushes for 111409-1 motor
Remington has ceased production. Parts availability is limited to what is on hand. Probably time to purchase a new pole saw. Purchase the cheapest product on the shelf and in 5 years they will be out of business too. Poulan and McCulloch (electric) have been in business for a very long time, I expect they will continue to provide a quality product with service after the sale for many years to come. HTH
Lou
Posted on Oct 12, 2009
SOURCE: how do I replace the carbon brushes?
Go to the link below there is a video How To..
http://www.videojug.com/webvideo/how-to-replace-hotpoint-carbon-brushes-in-your-washing-machine
Posted on Mar 10, 2010
  • 4894 Answers
SOURCE: I think the carbon brushes
Here are useful sites for DC14 maintenance (plus DC07 which is similar)
http://www.sparesaver.com/vacuum-spares/help-and-support/dyson-section/dyson-technical-advice-450/dyson-dc14-technical-advice-474/
http://www.espares.co.uk/advice/vacuum-cleaners/a/4/1312/how-to-replace-a-motor-on-a-dyson-dc07.html
Follow the instructions for removing the motor.
Replace the carbon brushes in the motor then reassemble.
Posted on Jan 17, 2011
  • 153 Answers
SOURCE: I have a KitchenAid mixer
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
You may have to remove the Motor Housing and use a small screwdiver
to completely remove the brushes or all portions of them if they are broken.
Posted on Jul 31, 2011
I need brushers for my table saw model no. PF250TS
The brushes are part of the motor. There should be a plate on the motor that will identify the voltage Model number and part number of the motor, and manufacturer.
Granger may be able to order the brushes based on the physical dimensions and design.
Most motor repair shops should have the brushes. They will need the motor plate information.
Hope that helps.
Oct 02, 2017 | Saws
Tunturi t7 showing error 20.
Try to RUN the sotware calibration for diagnostics.
This means user is heavy standing in the drive belt.
Causes: drive belt is worn, brusher motor faulty, motor faulty, motor controller board faulty
Remedies: use AC. clamp for drawn currente entering to the treadmill. Repair brusher and motor. Replace motor controller board.
God bless you.
see the block diagram
Oct 11, 2012 | Tunturi T70 Treadmill
Machine not spinning although draining
hi does your machine turn on wash cycle if not your motor brushers need to be looked they may have worn down and are not connecting with the armature or they may be stuck remove the motor and you will see two plastic brush holders each side of the armature undue the two screws on each one they then pop off ythey should be about 25 mm long and not soter thah 5mm and shinny on the ends try this first any more help let me no you can buy new brushes on line euro spares just type in your make model no
Nov 12, 2011 | Washing Machines
Model 417.29042992 pumps out water but wont spin
it could be your motor brushers the only way to check is remove the motor and you will see two plasic holders on each side of the motor armature undue the 2 screws and the brushers will come out they should be 1.5 inches long and shinny on the ends also sometimes they can get stuck in they might pull out a bit to get you going if not replace them you can get them on line from euro spares just type in your make model and motor brushers if i can help more let me know
Nov 10, 2011 | Kenmore Front Load Washer
How do i fit new carbon brushers to dyson dc14
It will be a pointless exercise Ron. By the time the brushes on a YDK DC14 motor have gone, so has the armature. You need to replace the motor. You can get a new motor here: Dyson DC14 new motor.
Also, be sure you change the filters; one of which is washable.
Nov 12, 2010 | Dyson DC14 All floors Bagless Upright...
Drain light is flashing
Check the motor for worn brushes and or noisy bearings while it is removed for service. Any auto mechanic should have experience replacing brushes and bearings. Much cheaper than ordering a new motor. New brushes and bearings should cost around $30.
Thanks
Oct 20, 2009 | Kenmore 73952 Gas Dryer
Fixing the springs to the carbon brushers to a 24v battery bosch drill
The brushes come as an assembly with the spring and brush in one unit. If your springs are bad you can order a set of brushes. The part number is 2607034901 and they run around $6.50. If your springs are melted looking there may be an underlying problem with the motor, mainly that there is a short in the motor or even switch. If the brushes are just worn and not touching the commutator bars then it is safe to just replace the brush set and you should be ok. Any questions please post back.
Oct 12, 2009 | Bosch 13624 24V Cordless Hammer Drills
Shredcare model # TQ100B
shredcare is the worst company ever. they sell crappy merchandise and then when it breaks, they dont sell replacement parts. My machine was out of warranty and the motor spindle sheered the teeth from the 1st cog wheel. this is probably an $0.11 part, but shredcare says my only option is to just buy a whole new unit and send this one off to the land fill, even though its so easily repaired.
i will never do business with shredcare again, and recommend everyone else stay away from them as well.
Feb 18, 2009 | OfficeMax 0M96431 Shredder
Bosch wfr2460
hi Many universal motor malfunctions are caused by wearing down of the carbon brushes, the soft blocks of carbon that complete the electrical contact to the motor's commutator. When these brushes become worn, the motor will spark, and electrical contact may be incomplete.try this
Step 1: To sight-check the carbon brushes, remove the screws that hold the brushes and brush springs into the brush holders at the sides of the commutator. The screws will pop out of the screw holes; turn the motor over to tap out the brushes. The ends of the brushes should be curved to fit the commutator; if they're worn down, new brushes are needed.
Step 2: To check carbon brushes with a continuity tester, remove the motor lead wires from the circuit. Tag the wires as you disconnect them so that you'll be able to reconnect them properly. Hook the tester clip to one motor lead and touch the probe to the other lead; the tester should light or buzz. Slowly rotate the motor shaft, keeping the tester in position. If the tester doesn't light or buzz, or if it flickers or stutters when you turn the motor shaft, the brushes should be replaced. If the springs behind the brushes are damaged, they should be replaced as well.
Step 3: Replace worn carbon brushes and damaged springs with new ones made specifically for the motor. The model information (number and make) is stamped on a metal plate fastened to the motor, or embossed on the metal housing of the motor. If you can't find the model information, take the worn brushes and springs with you to an appliance-parts store to make sure you get the right kind. Insert the new springs and brushes in the brush holders, replace the brush assemblies, and secure the new brushes with the mounting screws that held the old brushes.
Sep 13, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
How can I change the Carbon Brushers
Thanks a lot, but unfortunately it's the small European model and they use Carbon Brusher (see link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5110159) it's part number 16. I knocked on them and now the drum is spinning again. That's a sign that they are almost done. The stupid thing is, that I have to take out the motor to replace them and I can't get this done. Thx! Olav
Jul 24, 2007 | Bosch Axxis+ WFR 2460 Front Load Washer
62 people viewed this question
jasbo
jasbo
