Question about Furniture
My Temper-pedic is less than a year old and last night it stopped going up and down. The massage button still works. We checked the batteries and connections underneath the bed. What do I do?
SOURCE: remote won't work
Hi I had the same problem last night, so I took the batterys out  and left it for a Day, have just put them back and its working for the moment, hope that it keeps on working !!! good luck with yours.
Posted on Feb 20, 2009
SOURCE: tempur-pedic remote control does not
If the solution posted by Susan R. (below) fails to work, locate the black power down box under the bed. Check the battery compartment and remove all batteries. If batteries are installed they will prevent a full reset of the box. Unplug the power cord, wait 45 seconds and plug the power cord back in to reset the electronic components. Replace batteries. Now that the error has been wiped from the box's memory, you can now synchronize your remote with the power down box using Susan's instructions below. - Mike V., Antioch, CA
"Locate the power down box for the bed and press the "learn button" for 1 second and release (Black box under the bed). On the hand control, simultaneously press and hold the position 1 and off buttons. The transmission indicator light will flash slowly and then flash rapidly. Continue to hold for 5 seconds and then release the buttons. It should now work! Enjoy. Susan R., Paducah, KY"
For further assistance, refer to the user manual that came with your TEMPUR® Advanced Ergo System™ or you can download it here.
For phone assistance please contact a Leggett and Platt representative at 800-888-3078. Leggett and Platt is the manufacturer of the adjustable bed and remote components for Tempurpedic.
Posted on May 18, 2009
SOURCE: When volume button is pressed it does not stop going up or down
You can also use the cancel button on the SC-BT100 remote to keep the sound volume from accellerating up or down if you don't want to take the time to unplug for the 5 minutes, if your watching something and don't want to miss it.
Posted on May 19, 2009
SOURCE: whirlpool upright freezer making buzzing noise and not working
I had a similar problem yesterday. I woke up and the freezer was not working anymore. It would make a buzzing noise and then it would click and shut off. I looked online for some possible solutions. Here is what I did:
I unplugged the fridge. I pulled it out and took off the cardboard backing. I used an air compressor to blow out all of the dust and dirt that had accumulated on the condenser coils. A shop-vac just wasn't powerful enough to pull out all of the dust/dirt. After that, I plugged it back in....and the same thing was happening. It would buzz, and then it would click off. I figured out that the "click" was coming from a starter relay (a small plastic piece attached to the big black compressor). I detached the plug from the relay and then detached the relay from the compressor. The relay was burned out. It turns out this is a common problem with the relay. I replaced the relay for $50 (from an appliance parts store) and put the whole thing back together in about 10 minutes.
I plugged the fridge back in and the compressor started, and now the freezer works better than other. I saved about $400 doing it myself, all in about one hour. And better yet, my wife was very impressed. Not bad for a doctor.
Posted on Jul 04, 2009
  • 1033 Answers
SOURCE: fluctuating voltage meter
Alternator maybe charging , but not enough to keep the battery charged which is causing the battery to drop charge. Most likely it's the voltage regulator inside the alternator. but regardless the whole alternator will have to be replaced. This will eventually cause the new battery cells to go bad.
Posted on Jan 06, 2012
Have craftmatic bed with wireless remote. It stopped working....
while setting ours up last night I noticed that the 3 plugs that go into the moter unit do not like to stay in. have you check to make sure they have not come loose?
Jan 27, 2010 | Health & Beauty
New batteries in Smart UPS 700 only lasts 2 minutes at 30% load
If you blistered your older batteries a good chance your inverter is going or will go bad. The heat alone can do damage to your components. Time to replace the unit and remember next time not to wait so long to replace your batteries. Replacement of batteries every three to approaching four years is a good idea.
Oct 16, 2009 | APC Smart-UPS 700VA UPS System
My compaq presario c500 doesn't respond to the start button
try to turn on the laptop without the battery and only the power cord plug in.
if your laptop works with this you need new battery or update bios ( there might be fix for battery monitor)
if not, call service support, might be motherboard issue
let me know an update
Apr 03, 2009 | HP Compaq Presario C500t Notebook
Need a battery replacement battery for cordless theraspa turbo.
Has anyone been able to find out if these Brookstone massagers can have the old batteries removed & replaced?
They stopped selling this model a while ago.
Feb 26, 2009 | Brookstone Theraspa Turbo Massager
Remote won't work
Feb 18, 2009 | Samsung TV Remote Control
1998 Chevy Astro Van has no electrical power
Check the battery contacts for tightness and deposition. Make sure polarity is fine.
Also check the ignition switch
Let me know if you need more info
Good Luck
Feb 09, 2009 | 1998 Chevrolet Astro
Jobri Dolphin 2 yrs old, starts, than intermitant, than stops. Wait few minutes, starts up, does the same
Hello xthus, I suggest first call Jobri LLC at 800-432-2225 ask for Michelle of quality control. If she can't replace the unit ask for any or all technical information. With this info repair is possible with my guidance. Let me know of the outcome. Good Luck!
Oct 02, 2008 | Jobri Health & Beauty
My haier window air conditioner
I have a haier unit and last night the led went crazy it has totally stop working now and the LED just shows E1 I have tried unplugging it and resetting the button on the plug and nothing has helped this unit is less than a year old. Please help if you can....
May 18, 2008 | Whirlwind FH-778 Air Conditioner
Furniture Logo
135 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
