Question about Blenders
Bamix blender suddenly lit up while in use.
Inside I mean. Motor is running, sound is normal but when the button both high and low speed is pressed and the motor runs, a light lights up inside.... sparks or something? What is going on??
  • 145 Answers
SOURCE: I have a Kitchenaid blender
When the lights are flashing, this does indicate that an electronic part has failed. This blender is no longer manufactured, so finding replacement parts for it may not come easily. Repair centers are available. I would recommend calling Kitchenaid Customer Service to see what they can recommend for you.
Their toll-free number is 1-800-541-6390.
Posted on Jul 07, 2009
  • 21 Answers
SOURCE: I have a Bamix Immersion Blender, but it stopped
Sounds like the motor shaft has broken from the impeller. If I had it I would crack the case and see if that were true.(You might see screws holding the case together- If not, they might be hidden under the cosmetic label. If it is true, you need factory help. You better call Customer Service for Bamix.
THis is from http://www.bamix-usa.com/:
The drive shaft is frozen i.e. no longer rotates although the motor still hums: place the operative part of the appliance for 5 to 10 minutes in a jug of hot water, then switch it on. In general the appliance will then work again - if not just try to free the shaft very carefully with pliers
It can happen that the attachments fall off the shaft as they have in time become loose. In this case simply press the spring blades lightly together with a pair of pliers Processor/Dry Grinder: Discoloration of the bowl (i.e. carrots) can be cleaned with a cloth impregnated with salad oil.
Posted on Oct 23, 2009
pappapumpdaf
  • 635 Answers
SOURCE: how to make a smoothie with my bamix handheld blender
That wonderful little stick is all you need, I sure love mine! Make sure your Mixing cup is larger than the one supplied and remember to pump up and down vigorously as you blend. Keep swirling the bottom to make sure everything got picked up and blended. You can also make powdered salt,(great for french fries) powdered sugar, Dried garlic can be made into your own freshest garlic powder (great for spaghetti and pizza). peanut butter, apple butter and Whipped cream. I also use mine to make a crazy Jello only treat that tastes like sherbet, ice cream and Jello just by blending Jello and Ice cubes. Then I chill right away after pouring it into small 3 inch glasses.
Posted on Mar 13, 2010
EwingElect
  • 276 Answers
SOURCE: I have a bamix M200 hand blender & the shaft d...
After a period of time food residue will migrate up through the seal on the "foot" and lodge in the shaft. Once this is gummer up the motor will go but the shaft will not be able to rotate.
The machine will need to be disassembled and the shaft cleaned out. I recommend that you find your local Bamix Service Centre to do this as there are fragile parts in the stick mixer.
Posted on May 24, 2010
SOURCE: ksb 560 mco 5 speed blender lights flicker a as soon as switched
My Blender Model number KSB560MCO does not run. When try to blend all of red lights come one and they blink and move around. Any suggestions what could be wrong? Appreciate any help.
Thanks
Posted on Mar 28, 2011
How can I find a new Bamix old model spice blender/chopper
Bar mix products made millions for world wide sales
kitchen aids that change design so often
they cant support a large parts division
(R&D is geared to sell the next better barmix product )
if you cannot find a new old part
or super ceeded shaft from the next model up
or used drive shaft for sale online
look for a complete used bar mix spice blender/chopper
some people collect barmix units for a hobby or collection
and sell double ups
when you say old model
if the shaft is plastic ....... its .unfix able
its a heat molded construction process
Vintage Bamix M122 2-Speed Hand Held Food Blender Mixer-Chopper
Sep 16, 2016 | Bamix Blenders
Bamix needs service. Bought in 1977 with lifelong guarantee. Where do I send it to?
Pearl, link below to Bamix customer service and support.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.bamix.com/en/home
Feb 24, 2016 | Bamix Deluxe Handheld Blender
Looking for black and decker 550w 5 speed blender owners manuel
Try Googling (Black & Decker)(550w)(manual) without parens.
Jun 22, 2017 | Blenders
I have a bamix M200 hand blender & the shaft does not turn although the motor is working can you help?
May 21, 2010 | Bamix Deluxe Handheld Blender
How to make a smoothie with my bamix handheld blender
Mar 13, 2010 | Bamix Mono Single-Speed Handheld Blender
I am unable to remove the blade, what can I do
the blade is a screw fit on the shaft of the blender,, if you only use one blade just rince the blade under the tap and dry it off before putting it away, the only way to un-screw the blade if its stuck is give it a sudden jolt on the side of the blade with a soft hammer in the same way as it turns,,this may shake it lose,,,not to hard though,,,
Nov 15, 2009 | Bamix Mono Hand Blender - Black...
I have a Bamix Immersion Blender, but it stopped working. Press it on and it makes a humming sound but does not move. Where (in Canada) can it be repaired or replaced?
Oct 23, 2009 | Bamix Immersion Handheld Blender
The motor on the Bamix hand mixer is working properly yet the spindle will not spin. It appears as if it is not engaging. The spindle is not jammed.
there is a rubber connetion between the motor spline and the spindle which holds the screw that connects to the spindle, this has broken
Jun 09, 2009 | Bamix Immersion Handheld Blender
Whisk blade on BAMIX hand-held blender is frozen!
try to gently twist the blade up and around the shaft with a pair of pliers. I've loosened mine by pushing and pulling on the blade with the pliers. be sure to use caution so as not to wreck the blade.
Mar 17, 2009 | Bamix Mono Single-Speed Handheld Blender
Bamix hand blender 2 speed
I found this rubber drive coupling on mendshed which were helpfull enough to place it on their ebay site for shipping outside of the US. Check if it looks like yours first. One end the tapered end screws into the drive shaft the other end just fits in the rectangular shaft of the motor.
Sep 08, 2008 | Bamix Blenders
Blenders Logo
125 people viewed this question
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
