Question about LG enV VX9900 Cellular Phone
Front Screen is black: I've broken the front screen before and last time a crack appeared and would light up whenever I turned it on, a call or text came in etc. but I got it fixed with a new screen. The other day, I dropped the phone on the battery side, with it open - it never fell on the front. The rest of the phone is fine except the front, which is all black yet when I press on any of the front keys, the short cut keys or the clr button, something appears like lightly colored lines across the front and will keep moving when i press the keys. My brother thinks it might be a connection problem with the front screen?
Toshiba Satellite A505 - Most of the time when I turn it on the screen is grey, with no text.
This sounds like a bad display on the laptop. Hook up an external monitor to the vga port on the laptop. You may need to toggle the display to output to the external monitor. This is generally accomplished by pressing the "FN" key + one of the F# keys. Look for an icon that resembles a monitor or it may say LCD. If the graphics display correctly on the external monitor, then you will need to replace the computer screen.
Dec 29, 2012 | Toshiba Computers & Internet
Broken screen
it seems like you broken the lcd display in your phone change it, phone will work
Sep 27, 2009 | Motorola Mobility A630
My env2 is like broken.
the black screen with the rainbow is a clear indicator that you've cracked the internal screen.
Not fixable unless you replace the screen.
Jul 24, 2009 | Verizon Communications enV2 Cellular Phone
EnV front screen has a black stripe
Its manufacturing fault which can be caused at any time while using or if it get hurts .. you can calaim its warranty or take it to near by mobile shop to get it fix .. they might change screen or the serial wire of screen
Jun 25, 2009 | LG enV VX9900 Cellular Phone
My front screen wont show up
you need to replace the screen take the phone to a mobile repair shop to have it done.
Jun 04, 2009 | LG VOYAGER VX10000 Cellular Phone
My son threw a ball and hit the screen cracks all over can this be fixed with a new screen or is it junk now really bright light shows through all the crack marks
The front glass is just a protector for the LCD screen. If your TV turns on and the picture looks ok (may be a little color variation around the crack if front glass is pushing on it, variation OK black Bad) If the picture looks within the range described then replace the glass. It is just a piece of standard glass and a pretty easy diy job. If the LCD screen is broken the repair will be more than the replacement cost. Sad fact US TV repairmen make a living wage while the workers that assembled you TV wouldn't be able to buy lunch here with what they made putting it together.
Jun 02, 2009 | Toshiba 42HL67 42 in. LCD Television
Samsung tocco 480 screen is cracked/broken
The screen should keep working with the LCD cracked. i.e you should be able to receive calls.
You can find replacement LCD screens for Samsung F480 in this link:
http://www.pantallas.biz/epages/wwwpantallasbiz.sf/en_GB/?ObjectPath=/Shops/160419/Products/F480
I hope it helps.
Ignacio del Olmo
May 26, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Black box on screen
go into menu find
cc settings and
change setting to off
(make note of the one thats
causing the problem)
Dec 02, 2007 | Sansui DTV2760 27" TV
Black bar on screen
The text mode in the closed caption is turned on.Turn off the closed caption. I don't have the schematic in front of me, so, I will wing it. There may be a button on the remote that says CC, if so then use that button to turn it off, if not then go to the service menu and you may have to search a bit. Either way it's an easy fix and you can do it yourself. If you can't find it, then, reply and I will give better instructions when I get into my shop next week.
Sep 10, 2007 | Samsung TX-R2735 27" TV
LG enV VX9900 Cellular Phone Logo
124 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
