Surburban furnace upgrade from agnolog to digital LCD new board on furnace new relay box air conditioner works fine but furnace only cycles once then won't start by itself. Furnace cleaned looks ok ?
SOURCE: Carrier air conditioner problem
My Carrier unit did the same thing. It was low on refrigerant (Puron in my unit). I am worried I have a leak somewhere. Hopefully, it is not in the coil. The service call wasn't cheap either. Puron runs around $10-15 a pound and mine took several pounds to replenish.
Posted on Aug 03, 2008
SOURCE: my gas forced air furnace is shutting itself off after 2-3 cycles
there is a thermo-sensor switch next to the circuit board that tells the fan switch to turn on when the plenum is hot enough. this needs to be replaced.
Posted on Dec 16, 2008
  • 359 Answers
SOURCE: Furnace is not working, digital thermostat does not register
sounds as if your low voltage transformer might have bit the bullet will need replacing all of the devices you mention are powered by this one low voltage t-stat
Posted on Jan 01, 2009
  • 92 Answers
SOURCE: Ruud achiever 90 plus won`t start at times
sounds like you have a heat pump heat pumps dont work below 30* temps you should have some type of backup heat
Posted on Feb 05, 2009
  • 1515 Answers
SOURCE: Bryant-Carrier Furnace Fan Stays On
Hi, you have replaced the stat several times, and adjusted the anticipator so its not the stat.This is a split gas/elect unit, and working on these for many years and looking at some of the solutions given, they are right.You need to be looking at the Furnace fan control.Units of that age they do tend to stick open and run constantly.I doubt its the fan relay, maybe if you were in the cooling mode.Fan controls are not that expensive. You probably have a Honeywell 7" to 11" Probe, with the auto/manual button, with a temp dial to set you're on off temps. I would inspect the heat exchanger for any signs of cracks or bulging being its that old. If you find any, you are looking at carbon monoxided and should be thinking about an upgrade soon.Also flame roll out.I am thinking of you're safety is all.If you do have this type of fan control, there is a tab that has to be cut before you install for 24v. control.It comes set for 120v. and will burn out all of your 24v. componants.Those old Bryants will run for years. Good Luck!
Posted on Nov 14, 2009
Can not get fan on to turn on. All else fine. heat only furnace. No air conditioning...only air circulation.I used to set it on "Cool" and "Fan On"and get air to circulate. Do I need new thermostat?
Since you have two thermostats that operate the heating unit and the fan, and the fact that neither will turn the blower on, I would suspect the furnace/ air handler. Turn the thermostat to heat and see if the heat and the fan comes on, if it does operate normally in heat, the fan relay or the high speed on the blower is most likely the culprit. (If the furnace is equipped with a circuit board, the fan relay is integral to the board, if it an older furnace it has a separate fan relay). If it does not operate normally in the heating mode, verify power to the furnace, see if the flame comes on, if it does: the fan motor, circuit board or the fan relay are most likely the cause. hope this helps!
Jul 20, 2015 | Heating & Cooling
RV. when furnace is turned on , fan on rooftop AC unit runs continually
i would say its the relay board or communication cabl between stat and board.
Jun 18, 2014 | Dometic Rooftop RV Air Conditioner
Furnace starts but fan does not start then furnace shuts off. also fan does not turn on in cool setting either. I tested the motor directly, works fine
More than likely, you have a bad fan relay. This relay may be separate or soldered onto the printed circuit board.
Nov 01, 2013 | Heating & Cooling
Air Conditioner was working fine last summer but outside fna not working. Not hearing any sound at all. I can move the fan amanually and it seems fine. There is an electrical box next to the main...
There is a relay in the outside unit. Check for 24 volts a/c at the two wires coming from the furnace. also there may be a mouse nest in the control comartment where the relay is and they tend to chew up wiring insulation and sometimes wires get disconnected .
May 13, 2011 | Carrier 38CKC042 Air Conditioner
Blower motor relay switch problem I have a weather maker 8000, everything works fine but blower motor wont come on, just a click, and after it does not come on the the furnace stops, is this a blower...
Hello, if this is a electronic ignition Furnace the relay is located on the intergrated control board. The only problem is that you cannot replace only the relay on those boards, the whole board must be replaced.
Mar 07, 2011 | Heating & Cooling
Its the Relay on the circuit board trust it a 58SX????.....very common...
Oct 17, 2009 | Heating & Cooling
I have a DuoTherm BriskAIr 13.5K BTU. The Dometic thermostat also controls my HydroFlame 8531-IV furnace. This morning, the furnace would not come on. I checked the wiring and there is no voltage at the...
If you look at control box at roof unit, they usually use a separate set of wires for furnace. See what colors they are attached to at harness to thermostat. Some just follow other harness, and come out at thermostat. (bypass control box) Once you've determined which 2 they are, join them together & see if furnace starts, as it should. If it does, thermostat is faulty. If not, pull outside cover off & check voltages at furnace. I'm guessing by furnace model that your unit is approx 30 ft , but if it's a park model, you may have 24 volt system on furnace or 12 volt. Another way of confirming is to go to back of furnace where air intake grille is inside your unit, and locate 2 blue wires going to furnace & remove whatever wires are attached to them & connect them together. Furnace should start up.
Jul 08, 2009 | Dometic Rooftop RV Air Conditioner
Furnace completes cycle but the (24volts)wont keep the gas valve on.
Depending on which model you have there is a fan limit switch or a fan control or pc board that will bring the fan on once the furnace warms up some so that it doesn't blow cool air. This could be malfunctioning or the blower it;s self is malfunctioning which could be a fan relay, compasitor, or the blower motor it's self.
Sep 29, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
