Question about American Standard Heating & Cooling
I have an American Standard unit showing error 91
3 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: American Standard Air conditioning unit Model 2AGB0036A1000AB
Hi I am sure this model number is correct and it is a 3 Ton unit.Normally when the breaker trips as soon as you reset it, the compressor is compromised. Happened to me yesterday on a 5 ton heat-pump. When this happens, what you can do if you are a handy type of man, is to prove this. I don't know if the is is a split system or a all in one package unit, doesn't matter. Get to the compressor compartment. Of course the power will be off.If you can see the run capacitor, take a screw driver and short across the terminals to discharge it, as it could have a small amount of juice in it, I doubt it. Anyway, remove the plastic cover to expose the terminals. They can be hard to remove sometimes, just use a screw driver to push the clips in. Wire colors should be black for common, yellow for start, and blue for run. Write down the order they were in. To be safe, tape the metal connectors so they wont touch metal when you turn the power back on. After you have done this, turn everything back on. If the breaker holds and everything else is on, fan and so on, this proves the compressor is probably shorted to ground. If this a/c is rather new, I would replace the compressor. If it is old, I would think about getting prices on a new unit. Just food for thought. Please let me know on the out come of this test, please. When a compressor shorts out, or locks up, it draws what is called locked rotor amps/LRA which could be from 49 on up, and your breaker can be 25, 30, 35 to 40 amps so it will trip. Keep me posted and do this test, it is very easy to do.
Sincerely,
Shastalaker7
Posted on Apr 18, 2010
SOURCE: I have error codes flashing
Error codes from American Standard Pub 18-HD32D2-8, which is a one-sheet document that came with my American Standard air-conditioner:
29 = not listed
129 = not listed
80 = HPCO Fault - problem is in outdoor unit - Desscription: High Pressure Monitor Fault (hard lock out, cycle power to reset)
91 = Communication Inactive Fault - problem is in air handler - Descriptions - COMM Bit Master Clock Error, COMM Heat/Cool Demand Error, Serial Motor Communication Inactive Error
91 = Communication Fault - problem is in furnace - Descriptions: Blower motor no COMM response, Inducer motor no COMM response, Loss of heat/cool demand, Loss of clock signal
91 = Communication Fault - problem is in outdoor unit - Descriptions: Loss of Heat/Cool Demand Message (COMM), Loss of Bit Master (Clock Signal)
91 = Communication Fault - Description: Comm line is dead and no bits have been received.
By the way, I do not recommend American Standard. I've had mine 14 months and it just blew up - the entire control panel blew. My advice to you - think about a different brand.
Nancy
Scottsdale, Arizona
Posted on Sep 21, 2010
Where can I find an instruction manual for a n american standard remote for a trane split heating and ac unit?
AccuLink Remote Control - American Standard
https://www.americanstandardair.com/.../acculink-remote-control.html
Find more information on the AccuLink Remote Thermostat available from ... terms for your AccuLinkTM Remote Thermostat, please refer to your owner's manual ...
Thermostat Controls - American Standard
https://www.americanstandardair.com/products/thermostat-controls.html
Discover thermostats and get a digital thermostat for your home with American Standard. ... 7-day programmable comfort; Remote monitoring and programming ...
Free American Standard Thermostat User Manuals ...
homeappliance.manualsonline.com/manuals/.../american_standard/ameri...
Products 1 - 34 of 34 - Find the user manual you need for your home appliance products and ... American Standard Central Thermostat Installation Instructions.
Free American Standard Air Conditioner User Manuals ...
Feb 03, 2016 | American Standard Heating & Cooling
American standard error code 158
thermostat error codes for an american standard ... - AllExperts
en.allexperts.com > ... > Heating, Air Conditioning, Fridge, HVAC
Aug 22, 2010 - programmable thermostat, error codes, american standard: James, I am not familiar with that stat set up,short of goggle/yahoo the codes may ...
Jul 24, 2015 | American Standard 5000 Heat Pump Unit
My american standard model 4040 faucet is leaking at the base of the spout.
I checked online at www.plumbingwarehouse.com/american-standard-kitchen-faucet-hamilton-4040. There is a diagram that shows a seal kit that probably needs to be replaced. The diagram is really good and shows a complete breakdown of your faucet. I hope this helps.
Apr 10, 2015 | American Standard Plumbing
Noise very bad at outside unit new american standard ac
should not be that noisy. fan bracket loose or blade out of balance.
Sep 13, 2012 | American Standard Heating & Cooling
I have an error code on my american standard model # ACONT900AC43UA communicating,programmable comfort control. Says to find the Error codes from American Standard Pub 18-HD32D2-8 but I don't have...
I am experiencing the same error code on my American Standard AC and according to Public. #18-HD32D2-8, error code 126 is in the Equipment Change Alert Group and the description says "Equipment does not match value stored at startup." Then, in a footnote, it says "A device has changed since Auto Discovery (See Installer Guide *S& 0706 to reset)."
This is all Greek to me so I'm calling my AC guy. I can tell you this, however. I bought an American Standard AC brand new just two years ago and one year ago exactly, it blew up. American Standard replaced it. Now, one year later, more problems.
I question the quality of American Standard and would not be inclined to buy this brand again.
Jul 22, 2011 | Heating & Cooling
Is the American Standard G50T 2-3-6 a good water heater? I have trying to find stuff about them on Google but I keep getting results for american water heaters not american Standard and the reviews are not...
Generally, they are a your normal low end hot water heater. I have seen American Standard units last up to 20 years (like mine) with not problems, and I have seen them not last three years before the tank ruptured.
We have more calls on the Rheem and Brandford Whites than American Standards as far an minor problems.
Pros: Cheap; reasonably reliable; parts readily available.
Cons: Not energy efficient; tank quality - flexible.
When mine goes would I replace it with another American Standard? No, I would install the Bosch tankless water heater.
Jun 24, 2011 | American Standard AMERICAN STD 100 Prop...
We are a small school that has about 14 students taking a shower after PE. We have had a 100 gallon 270,000 BTU water heater. Do you have a price quote for that heater American Standard Commercial Model...
Hi Kathlene.
Typical American Standard sell sheet for 100 270 AS also shows contact information for company with phone numbers
http://www.waterheating.com/pdf/100270.pdf
One seller shows this product for $3000 + shipping
http://shop.waterheatermaninc.com/product.sc?categoryId=2&productId=10
Rheem builds commercial gas water heaters under their name and under other brand names.
http://www.rheem.com/product.aspx?id=FC6D548B-54EC-46C9-9DC0-79DEC29198D7
Contact Rheem:
http://www.rheem.com/Contact.aspx
For example Rheem GP100-250(A) meets same delivery as American standard product
http://globalimageserver.com/fetchDocument.aspx?id=d26ba16f-c16f-4c45-90a8-d1f5d5f97020
One company sells product for $3900
http://bostonheatingsupply.com/ventmaster.aspx
For example model GD100-250(A) meets same delivery as American standard product
http://globalimageserver.com/fetchDocument.aspx?id=276b892c-1fb8-40f1-8238-51d4a7d84846
This product might sell for $6900
Mar 31, 2011 | American Standard AMERICAN STD 100 Prop...
I have error codes flashing on my thermostat..it is an american standard model the manual for the therm. has ACOT900AC43UA on front..says to find addedum 18-HD32D2-1/69-2009 for codes i cannot find it...
29 = not listed
129 = not listed
Nancy
Scottsdale, Arizona
Aug 22, 2010 | American Standard Heating & Cooling
Need schematic for an American Standard A/C Model number 7A0030A1
American Standard and Trane are the same thing. The diagram you want is not complicated at all. Just straight cool unit. American Standard does not put low or high pressure controls on unit. You can get diagram on line At American Standard.com. Just what do you need to know? Very basic unit.
Jun 11, 2009 | Heating & Cooling
Heating & Cooling Logo
173 people viewed this question
Top American Standard Heating & Cooling Experts
Tim Whalen
Mack Baxter
ROCKIT957
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
