I replaced the lamp but it still won't fire up. This is the 3rd time we have replaced the lamp, but this time it won't turn on. We did have problems getting this last lamp to fit properly.
  • kakima Dec 25, 2016
    Hi Lori Keller, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Replaced the lamp on what make and model?
    Top Expert:
  • Televison & ... Master
  • 12,962 Answers
Could be the ballast that has gone bad. It generates the high voltage necessary for the gas filled bulb to ignite and give off light.
Make sure that the bulb is in properly before suspecting the ballast since it is not cheap.
Posted on Dec 25, 2016
New lamp worked for 2 weeks, last night would not turn in so removed lamp thinking it was burnt to send back under warranty. Lamp appeared fine so reinserted and tv surprisinly turned on. this morning...
Edwin, sounds like you might be having a problem with your Ballast. The Ballast is what fires up lamp. Typically if this is an older unit, when you replace the bulb, you will have to replace your ballast as well. It is harder to fire up a new bulb, then it is to fire up an old bulb. That's why you wouldn't notice the problem until you changed your bulb.
Mar 01, 2014 | Panasonic Televison & Video
Replaced XD300U projector lamp. Need to know how to reset lamp timer. Won,t turn on because lamp timer has expired to 0. Needs to be reset. Lost our manual. Please help.
"Reset the lamp counter
i. Press and hold Exit on the projector
for 3 seconds to display the total used
lamp time.
ii. Press Menu on the projector or on
the remote control to access the lamp
hour timer. An adjustment message
will appear.
iii. Press or to reset lamp hours
and press EXIT to leave."
Apr 21, 2008 | Televison & Video
Blown fuse for brake light
is this question? do ask a questions
how come
like that.
ill try to guess.
my brake lamp fuse keeps blowing, why?
answer, the brake lamps circuit is shorted. the fuse saved the fire.
first replace both brake lamps or all 3 if 3rd lamp bs.
most brass based bulbs can short easy . (glue inside fails)
Jan 02, 2014 | 1996 Toyota Corolla
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
LED light blinking 6 times and TV won't turn on
When you turn on the power button listen to the back of the TV, you should hear a motor with a high pitch spin up (the color wheel) and then the lamp should attempt to fire. The lamp should make a sparking sound and if it does your lamp is most likely defective. The part number for the lamp is on a sticker on the sode that will say "Lamp Code" on it and will be something like BP96-****
Aug 01, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
I have the ATK125A go kart and it will not go in reverse and is in 3rd gear and will not come out of 3rd. What can i do?
I have a atk125a go kart and it won't start... Gets fire and gas.. It will crank over and over but won't run. Had the cdi checked and it was good. No fire to the kill switch.. Please help i'm about to pull my hair out. Please e-mail me at with answers....
Dec 28, 2010 | Sport & Outdoor - Others
Hi, I have a Christie RoadRunner L6 Projector. When I turn it on the lamp light turns red and it does nothing. This unit does have dual lamps and a lamp replacement lamp light as well. I figured if it was...
I have a Christie RoadRunner L8 that fires up,lamps turn on and about 5 seconds after the lamps fire up it shuts down and both the warning temp. and ready lights flash at the same time. It seems to me it must be a sensor that tells it to shut down thinking that the machine is too hot-all the fans work and all of the filters are clean and it is moving serious air any clue and if so where do I start to look for such items? Thanks in advance Kirk
Aug 16, 2010 | Christie RoadRunner L8 Multimedia...
I have replaced the lamp 2 times ....think it needs a 3rd tv is almost 6yrs old .. but now it will not even turn on ! will a new bulb turn tv back on ?
did you check the power supply board and also did you check the ballast our the digital board those could be the problems that you 6 year tv could have
Dec 15, 2009 | Samsung - Projection TV replacement lamp...
Brake switch fuse keeps blowing
replace your brake pressure switch on the master cylinder and that should take care of your problem.
Jun 04, 2009 | 1997 Ford F150 Regular Cab
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
