Question about Exercise & Fitness
Treadmill lost power while in use. screen went blank. noticed a squeak from front of unit.
  • 6,694 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
Posted on Dec 26, 2016
How do I lubricate the c 1800s nordictrack
the only lubrication that needs done is between the walking belt and the deck. if a roller is squeaking either front or rear you can try using wd40 on the bearings on either side
Oct 21, 2014 | Nordic Track Nordictrack C 1800s Treadmill...
Nordictrak T5.7 treadmill squeaks while walking
please LUBE the deck belt and roller bearing very important
if the problem persist after you did. Is time to change the deck belt.
God bless you
Jan 08, 2013 | Exercise & Fitness
Irun treadmill not working- blank screen, belt not running but power light on
1) adjust the REED swtich, clean, and tigh the wires connector.
2) After you did the adjustmente RUN the software calibration for diagnose, troubleshooting, and fix it.
see the diagram attached.
Jul 03, 2012 | Reebok treadmill i-run s
My proform 740cs has a squeak in the front left when i step onto the treadmill, even if off. I have tightened all screws, nuts, etc.
Dear sIR:
yOU HAve LUBE the treadmill, had been producing enough friction for to shut down and protecting the electrnoic system.
2) Lube the rollers bearing very well.
3) Test the voltage motor, if there are the motor need repair or replace.
4) Tes the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
May 13, 2012 | Proform 740cs/745cs Treadmill Walking Belt...
I have a norty track C2500 an the screen went blank
I suggest checking your power plug then check or reset the circuit breaker on the treadmill next to the cord if that ok and the unit is still dead. Unplug unit the remove motor shroud and if you own a multi meter start checking the AC all the way to the lower board and see where the Ac is missing.
If the Voltage is good to the board then check DC Out put going the console wire harness should have 5v or 12v DC depending on model if missing then replace lower board if present, then check the continuity of wire harness if bad replace harness. If good upper console needs to be replaced
May 25, 2010 | Nordic Track Exercise & Fitness
We have an L7 or L8 treadmill. About 2 years old.
Unplug unit remove motor shroud then plug in unit hit start it and listen to where the sound is originating could be the drive belt or if you are walking on it then it could be the running deck post needs to be lubricated
Apr 16, 2010 | Exercise & Fitness
Epic550 treadmill shutdown unexpectedly and display is blank.
Check the upright wiring harness on the right side. If the harness was routed incorrectly or care was not take during installation, the harness is pinched/cut/damaged when the right upright is bolted on. This is the main issue I encounter on this style treadmill when it will not work after assembly. Will require a new upright harness if damaged. If it is under warranty, call and have them replace it. It is covered
Jan 14, 2010 | Epic View 550 Treadmill
Squeaking when i run on nordic track 5100r
My treadmill (American Motion Fitness) squeaks when only when  it warms up. I spray CRC oil onto the front roller bolts which bolt it to the swivel housing and onto the bolts which bolt the swivel housing onto the main frame also onto the rubber bushings which allow the front roller to bounce every time my foot hits the deck. I seem to have to do this 1 per week but it is easy to get at and takes 2 minutes. cheers johnO
Apr 29, 2009 | Nordic Track Nordictrack Apex 4100i...
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
