Question about Exercise & Fitness
My freespirit 30444 screen turned black and treadmill lost all power. Unit will not power up.
Unit was in use at the time. There was and audible squeak coming from the front of the unit.
  • 7 Answers
SOURCE: Sound Interference coming throught the Amplifier
On many occasions high pitch interference is a result of bad wiring and grounding problems. Check to make sure that you followed the manufacturer's instructions concerning grounding and installation of the amp, and if possible try and install it at another location in your house, using other electricity sockets. If the problem is solved by relocating the system, you might be looking at wiring problems (audio equipment can be very sensitive to that), if changing anything in the installation process solved the problem then the problem was probably due to bad grounding and "loose" electricity. Try making the installation as "clean" as possible, avoid tangled wires and stressing a single socket with too many electric appliances. If the problem persists, and you are still under warranty, I suggest contacting your local Yamaha dealer. If you're out of warranty I suggest locating a professional repair person.
Posted on Jan 19, 2006
SOURCE: HP Media Vault - Power on / fan on / front panel indicators off
I read a bunch of material found on the web. Primarily this led me to believe that the Lynix flash OS has some issues (to say the least). After carefully testing out the mom board voltages I decided that there was probably a software boot issue.
I read this at
"The MV1 has a hard reset which severs the tie to the script that calls any of the installed software." The material on this site also indicated that the stored files would not be affected by a hard reset. So what the heck... nothing to lose. I unplugged the power, pressed the reset button and then applied power. Held the reset button for > 5 seconds. Held my breath for 30 seconds and the disk light started to flash on the front indicator panel. After a minute or two of that, the OK light came on. I pressed the power button on the front panel and the it responded. Another miracle? Hmmm. The MV shut down. I connected to the LAN and powered back on. Every thing worked fine.
I guess... there was a space issue / startup parameter corruption / enemy electron in the mix that was passed over with the hard reset at start up. Since there is on access to the OS boot process, (or source code) this is pure speculation. Although, it is reasonable speculation. Chao!
Posted on Dec 01, 2008
  • 827 Answers
SOURCE: the treadmill keeps stopping Freespirit Model 12230520.0
Hey there,
If your treadmill has an optical speed sensor and hasn't been cleaned for a while, dust, dirt or lint may be obstructing the infared eye of the speed sensor. Try cleaning the treadmill.
Or maybe you need to replace the upper display, although, you may have a loose wiring harness that would cause the same problems. Open the motor case and verify the wiring harness is plugged into the lower board snugly. Also, remove the upper console and verify the harness is plugged into the back of the console snugly as well.
Definitely, inspect the components and try and isolate the source of the problem yourself first, before contacting a dealer for parts, as they can cost a fortune..
Good Luck!
Chris (ziraffa)
Posted on Dec 26, 2008
  • 19 Answers
SOURCE: my freespirit treadmill showsL5 on nthe display then quits
If calibration doesn't work replace controller.
Posted on May 14, 2010
Looking for service manual for freespirit model 30444
If you wish to get some details about treadmill repair ; visit the site linked here. Pull up older posts.
Dec 29, 2016 | Exercise & Fitness
How to enter into calibration mode for treadmill Freespirit model 122 30521..
Of you wish to get some details about treadmill repair service mode and calibration then check the following link
Jan 15, 2016 | Nautilus Exercise & Fitness
A proximity sensor is telling you the belt is incorrectly aligned. Probably too loose. Bolts on end of shafts control belt tension. Turn in if loose, out if too tight.
Sep 03, 2014 | Proform Freespirit 814 Treadmill Drive...
Free spirit treadmills 30444
please indicate what kind of problem do you have. God bless you
Sep 20, 2013 | Exercise & Fitness
Freespirit treadmill
Turn treadmill off. Disconnect drive motor wires from lower control board (Mtr + and Mtr -)
terminals. Power up in OLS mode (FAST & START). Bring displayed speed up to 99.
Measure across the Mtr + and Mtr - terminals with your voltmeter (DCVolts). You should
measure at least 90 vdc on a 110V treadmill and 180 vdc on a 220V treadmill.
If you are not getting dc volts out of the lower board, replace it.
If you are measuring the proper dc voltage out, replace the drive motor.
see my personal TIPS for motor help. God bless you 1232c4bc-7349-41aa-9120-7d58645cb442.gifc11b620c-0d7d-410d-9958-64f3636d4ac5.jpg
Jun 05, 2013 | Exercise & Fitness
Freespirit Treadmill
Did you try it before you bought it and it was working. when you move the unit and pluged it into the wall outlet was it on? if yes then you may have damaged the lower board. If you can not get that part then the treadmill has died. Is it a Bowflex or a Free spirit.
Nov 21, 2008 | Bowflex Treadmill Series 7
Exercise & Fitness Logo
29 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
