My behringer fca 1616 inputs and outputs not working. When I pray a sound in the computer the the output monitoring lights show that the port is working but when I Jack in the powered speaker no sound
Benimur
  • 6966 Answers
SOURCE: crt computer monitor model 6332-03n
Hi, you can try lowering the screen resolution, the color quality and the screen refresh rates. Work from there and observe each setting/increment. soon as the monitor quits, press escape to revert to previous setting. I get the impression that you are familiar with electronics, the problem is your monitor horz. freq is playing catch up and eventually fails. Lowering your PC setting then might do the trick. To lower the settings, right click on desktop, properties, settings tab & advance button - Monitor. Hope this be of some help. Good luck
Posted on Apr 24, 2007
starmaxx
  • 57 Answers
SOURCE: I have acer al1715 that wont play sound from its
Plug jack carefull betwen monitor and pc and must work ok, put jacks to monitor on Audio In! If this help's you, rate me. Thanks
Posted on Sep 14, 2009
ag66339
  • 127 Answers
SOURCE: BenQ E2200HD monitor won't output sound
You do not have the necessary drivers installed. Go to the manufacturers website and download and install the recommended drivers.
Posted on Sep 22, 2009
SOURCE: The built-in speakers on my HP w2408h do not work.
hello bill.. i have a 190 B and not getting sound... checked all sound generating electronics as well.. i wonder are the internal speakers 'gone'? in mine i.e...??
Posted on Oct 26, 2009
budmrtn
  • 11361 Answers
SOURCE: My monitor's blue power light is flashing but
There are two places to look for the problems, the backlight inverter board and the power supply, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 26, 2009
How to connect a sound card behringer FCA 1616 firepower into a comptuter
Install all necessary audio drivers on your PC.
Connect the unit to AC power.
Connect the unit to your pc via either USB 2.0 or firewire serial bus.
Press and hold the DIGITAL SELECT button while powering the unit on to switch the bus mode from firewire to usb and vice versa.
Feb 18, 2015 | Behringer Computers & Internet
When I plug-in my vp1220f floor monitors in to the monitor mix on the pmp 2000 i get no sound or little sounds
If you are referring to the "monitor" output , this is a Pre-amp output which connects to a power amp or speakers that have built-in power amps. The Monitor output is a high impedance output. This output will not drive speakers directly.
Jun 02, 2014 | Behringer PMP-2000 Powered Mixer
Behringer No Input Signal
Mic level in the windows control might be muted or off. The sound functions are a control panel iterm Or in Macs it is a CDEV.
Also check to make sure the program has that input enabled as well.
and make sure you start out with fresh batteries, double check where you have things plugged in, so you are not plugged into the worng port plug on the computer
Feb 06, 2012 | Behringer Ucg102 Guitar To USB Interface
Need to connect to a sound blaster live sound card for recording using sonar as recording program. hace had it in storage for sometime and can't remember what went where
This particular mixer offers a usb (2 channel connection) that can be simply plugged into the computer usb 2.0. These channels should be available in Sonar from the channel Input/output drop boxes. You may need to restart Sonar, the mixer or both for them to be recognized. You may also need to run the Wav Profiler in Sonar. Typically the Wave Profiler is found in the Options>Audio menu but may be different on each edition of Sonar. The above info is for Sonar 7.
If you are wanting to record several channels at once then I would recommend connecting your Mixer's Direct Outputs from each channel to a corresponding input of the soundblaster if your soundblaster supports multiple channels. And then use the usb outbut from the Sonar to monitor the computer playback of your master stereo channel. Or, you may connect the soundblaster outputs to unused channels of the mixer or to the tape return or auxilary inputs to monitor the computer playback on the mixer.
Alternately you can send the signal to your soundblaster via the buss outputs. This will limit the number of simaltanious output channels to the number of busses on the mixer, but you can send any mixer channel to any buss without unplugging the instruments or mics.
Here's the link to the page where you can download the free pdf manual for this mixer. Page 14 explains the output connections and has diagrams.
http://www.behringer.com/EN/Products/2442FX.aspx
Oct 09, 2010 | Behringer XENYX 2442FX Mixer
I'm using garageband and for some reason it won't record on my computer all the time it has worked previously , but i can't get it to record in the moniter input
It is not clear what your configuration is. The monitor OUTPUTS are monaural. For recording you should be using the MAINS OUTPUTS and those NEED to use the the MAIN1 IF you are using TRS balanced lines, else if you record with unbalanced cables you need to use the MAIN2 outputs...
Monitor outputs are intended for stage monitors and vary ONLY with the monitor controls at each channel and the monitor sliders and do NOT vary with the sliders.
Aug 27, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I am trying to connect a Sceptre monitor
Will the monitor work on another computer? Will the computer work with a different monitor? Are you connecting the vga port to vga output on the video card or the dvi input to the dvi output on the card. You may need a video card with hdmi output.
Jul 17, 2010 | Sceptre X24WG-NAGA Monitor
Fca 202 sound card driver not working with xp64
it won't work beacuse on windows xp64bit only 64-bit kernel mode drivers are supported.....
Apr 14, 2010 | Behringer FCA202 - FireWire Audio...
Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
Mar 13, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I noticed that my monitor has an additional port to connect another monitor to but for some reason its not recognizing the monitor
Is that a port for an additional monitor or is it simply an alternative method of connecting the monitor to the PC. My monitor has a vga input along with a dvi input and a hdmi input. These are all inputs not outputs.. Unless the port is specifically labeled as an additional monitor output, the chances are its an input.. You may have to use proprietry software to make any additional outputs available.. if the monitor is a Samsung, go to the samsung website and search for the monitor model. or read the manual..
Nov 02, 2009 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
