Question about Mongoose Butterfly Summer 12" Girl's Bike
My Mongoose "Gavel" BMX bike's rear wheel catches when I coast.
I already tried greasing the chain and wheel base, but I think that I have a similar problem. I think the tire needs to be loosened.
    Problem Solver:
  • 11 Answers
Has the bike been in an accident recently? you can flip it over and spin the back wheel to make sure that wheel is "on center". if the wheel is not bent then u can just unloosen the back wheel then re-align to the center and tighten.
Posted on Jul 29, 2010
  • 31 Answers
Try buying a new back wheel or sprocket?
Posted on Jul 23, 2009
When my son is coasting on his Scan R40 Mongoose bike he peddles in reverse and there is no normal clicking sound from the chain running over the sprockets, basically he wants that sound and this bike is...
That clicking is not caused by the chain. Some of the new freewheels are made to be silent. If he wants that sound he'll have to change the freewheel.
Jul 27, 2014 | Mongoose 20" Scan R40 BMX Bike
I cannot get my chain to stop coming off. How do I keep the chain from slipping off?
Loosen the nut that holds the back wheel and pull it back until the chain is tight and then retighten the nut. If when the chain is tight, the wheel is not on the rear frame, you need to take a link out of the chain.
Jun 25, 2014 | Mongoose 20" Mode 90 Boys Freestyle Bike
Huffy boys bike makes clicking noise
does it make the "clicking" noise when coasting, pedaling or both? If it is only when pedaling, check to make sure the cranks are not rubbing on a chain guard or hitting the frame, if not then the chain is probably too tight and it is the gear cog teeth meshing with the tight chain. Loosen the rear axle nuts and slide the rear wheel forward slightly, this should take care of it. If the noise happens while coasting then one of the wheels could be rubbing on the frame intermittently, or the hub bearings could be too tight (also making it difficult for small legs to pedal) and the bearings are crushed and flattening making the "clicking" noise as they are being ground up.
Apr 21, 2014 | Huffy Pro Thunder Boys 16-Inch BMX Bike
Who do I put the rear wheel back on my mongoose bike
raise the back of the bike and put the wheel between the rear stays place the chain on the freewheel, and pull the wheel back and
then just tighten the wheel nuts.
Jul 26, 2013 | Mongoose 20-Inch Gravity Games BMX...
Wheel does not turn when peadalled
needs a new sprocket on the wheel the teeth inside are worn
Oct 12, 2009 | Mongoose 20-Inch Gravity Games BMX...
New mongoose 20'' bmx. trying to adjust the brakes???
undew the screew at the back of the breakes and turn them round slightly so the wheel in midlde then tighten back up should stay in midle then just not put on straight thats all mate
Jun 18, 2009 | Mongoose Menace Street Dirt BMX Bicycle
Weird noise on my bmx bike
It sounds like you have cracked or broken one or both sealed cartridge bearings if thats what your bike has. If it has ball bearings in races they might be broken. Try loosening your rear wheel enough to take the chain off and then turn your crank. See if theres a funny noise or if it feels a little weird when its turning. If you broke a pedal bearing you should be able to tell just by carefully turning each pedal with your fingers and seeing what it feels like. In any case unless you have the tools to repair it you will have to take it in and get it repaired.
Mar 26, 2009 | Mongoose 20-Inch Gravity Games BMX...
Chain and Wheels
thank you for using Fixya. the issue you are experiencing is pretty much your free wheel. If it is new, it may have been installed the other way around or the clip in the assembly that serves as a spring for the chainwheel to lock out has been worn out.
Best if you will be able to remove the rear wheel and then check the whole rear hub assembly starting with the freewheel and the axle.
Dec 25, 2008 | Mongoose 20-Inch Gravity Games BMX...
Mongoose Butterfly Summer 12" Girl's Bike Logo
387 people viewed this question
Top Mongoose Cycling Experts
M.R.
M.R.
Level 1 Expert
WTF Chuck.....
WTF Chuck.....
Roger Paull III
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
