Question about Garden
I need information on replacing the wear bar on the front of my Kubota t2724 snow blower. Can't seem to get it to come off after grinding the welds on the front edge and bolts off.
  • 70 Answers
SOURCE: where is toro 31820 auger shear bolt?
Shearbolt is located at #54 in this diagram.
https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=19462&control=SetCommunity&CommunityID=214&PageID=238#drawingDiagramPage
part#322-9
It may be hard to spot on the auger shaft as it may have sheared flush with the holes so look close. You may also need to remove the part of the bolt remaning inside the shaft.
Posted on Dec 22, 2008
  • 92 Answers
SOURCE: 1985 Chevy Monte Carlo, need body info.
the complete nose up to the front doors are bolted on.the only thing that gets a little tricky is the lower radiator support. just take youre time and it can be all disassembled and rebolted with out too much trouble.
good luck chris
Posted on Mar 15, 2009
  • 14 Answers
SOURCE: Duet GHW9150P inner SS drum is actually loose but
go buy new washer the drum bearings have gone and it really is not worth repairing . it can be repaired but always found that it never lasts long once done.
Posted on Jul 07, 2009
rockitman187
  • 2559 Answers
SOURCE: I have a 2004 S60R with just over 75k on the
Have a 4 wheel alignment done and have them check the wheel bearings.
Posted on Aug 02, 2009
Thermo King
  • 593 Answers
SOURCE: I was replacing the rear sway bar bushings on my
You can try to drill out the broken bolts, or you can use heat, if you can grasp the bit of bolt poking out the back side of the plate. Get the bolt tips red hot with a torch or as hot as you can. Grab the parts of the bolt with a vise grip pliers and try and turn it out. If this does not work, you will have to drill a small starter hole in the bolt to weaken them and allow it to shrink a-bit and turn out.
Posted on Feb 08, 2010
Kubota rtv x1100c with snowblower. Third day of use and getting very loud grinding noise from the auger area of snowblower. The snowblower fan is wearing on the tube it sits in.
check for loose shaft bearing allowing our of alignment
check for something jammed in the end ( toy, rake metal rod etc
Jan 01, 2018 | Kubota Garden
How to replace front auger cable on a snow blower
This picture is from an MTD but it should be the same.
Feb 16, 2016 | Garden
I have an MTD single-stage snow blower that I replace the other the cable and the belt and under a load it's still not throwing snow
There should be 2 holes on the handle that engages the auger belt, use the top hole as it will increase the belt tension.
Check the condition of the rubber auger's rubber paddles as they are subject to wear and should be replaced if any signs of excessive
wear is present.
Jan 31, 2016 | Craftsman 21" 179cc* Single Stage...
Looking to purchase or download a owners-service manual(s) for Kubota F5210B snow blower
go google and type in -workshop manual for kubota f5210b snow blower --- and there will be a page for manuals or may be a pdf version down load
if there is a pdf version down load check the number of pages as it could be around 200 pages
contact your kubota service center as they may have a workshop manual on cd for sale
Dec 06, 2015 | Garden
How do I stop the shute on my dual stage snow blower from moving on its own while blowing snow
There are clamps holding the chute to the impeller housing on the underside. These can often wear and loosen with time. I would first check these for wear and tightness. Tighten if loose or replace if excessively worn.
Feb 16, 2015 | Craftsman 30 In 357cc* Dual-Stage...
Front end grinding noise in Ford f150. It isn't
You may have wheel bearing issues or if you have a 4x4 the u-joints on the front axle may be needing some attention. I would start by inspecting both for signs of wear and replace them if necessary. This is pretty straight forward mechanical work but get a repair book for your specific truck and read up on both procedures before starting. I use Chilton for my vehicles and it seems to be one of the best with to the point information.
Good luck.
Feb 23, 2012 | 1992 Ford F150 SuperCab
Craftsman single-stage snow thrower hard to push
You can adjust the guides on the side of the blower so that it rides on those. If they are set to low you will see the problem you have now. If they sit to low for a long period of time you can wear out the blade on the bottom.
Dec 22, 2009 | Toro Blowers Rake and Vac - Electric...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
