Question about Midland Radio Communications
Midland gxt 756 new batteries but display is too dim to see? No parts broken or loose connections.
    Master:
  • Midland Master
  • 517 Answers
Well, there is nothing to repair. Even if you wanted to replace the LED's you would need to open up the radio and figure it out. There are no repair manuals or parts other than batteries available for the consumer grade radios.
Posted on Dec 27, 2016
Benimur
  • 6966 Answers
SOURCE: Midland gxt-850 gets HOT!
It is very possible that the terminal of the positive end of the bottom battery is shorting to the battery's body hence the heating up. If this is the case, then when you charge the radio, excessive current is flowing since the battery set has one shorted. Again this would cause heat buildup specially on the bottom battery and the charging terminals.
A possible solution is to check the bottom battery's positive terminal and ensure that it only contacts with the positive terminal of the battery and does not touch the battery body (which is negative).
Alternately (and perhaps more to your advantage), seek replacement of the defective unit considering it is new and therefore should be under warranty.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 06, 2007
randy54156
  • 55 Answers
SOURCE: midland gxt 500 wont stop vibrating
Stop shaking it
Posted on Nov 05, 2008
  • 157 Answers
SOURCE: midland radio battery pack constant vibrate
Hello pjbracht, I just responed to a duplicate of your problem. If they are new, return the battiers and confirm they are "by the book" replacements. If so ask for replacemrnts with a higher mAhr. It is not correct for vibration from a battery pack, lead, NiCad, Ni-MH, period.
Posted on Nov 07, 2008
Neto
  • 123 Answers
SOURCE: programming problem
http://www.midlandradio.com/owners_manuals.asp
Try this site
Good luck
Posted on Jan 23, 2009
BillB-SA
  • 2761 Answers
SOURCE: is the midland gxt 650 compatable with the g12
All type-accepted GMRS radios operate on the same frequencies and use the same type of transmissions. Channel numbers are the same on most models, but check the channel/frequency chart in the radio's operating manual to be sure.
Bill B
Posted on Jun 02, 2010
Can I get a manual for Midland GTX895
Here you go, and it is GXT not GTX :>)
http://midland-new.voltagekc.com/wp-content/uploads/2013/04/GXT860-Owners-Manual1.pdf
Oct 01, 2015 | Midland Radio Communications
Midland radio manuals
Download your manual from here: http://www.manualslib.com/manual/103191/Midland-Gxt-850.html
Aug 12, 2014 | Midland Radio Communications
How do you change battery in Midland GTX450
Do you mean the GXT450 model, if so this manual is for the 300 upto the 450 and explains how to remove the batteries or battery pack.
http://www.manualslib.com/manual/103192/Midland-Gxt300.html?page=6#manual
Hope this helps
Jul 14, 2014 | HQRP Battery Replacement Fits Midland...
Needing a manual for the GXT 756.
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. If you require some other manual, the file doesn't work, or this isn't what you are looking for PLEASE reply to my answer here and I will correct it for you. Here is the manual / guide please give it a few minutes the file is quite large:
The GXT 756 is a variation of the GXT 750, which is covered in this manual here....
http://www.buytwowayradios.com/Products/Midland/manuals/GXT-710-manual.pdf
Oct 16, 2010 | Midland GXT450VP4 (22 Channels) 2-Way...
Hello and Good day, Can you please help me get the manual for the GXT 400 X-Tra Talk? Thanks Emileo
just click on this link.. its a pdf file....
www.buytwowayradios.com/Products/Midland/manuals/GXT-300om.pdf
Jun 22, 2010 | Midland X-TRA TALK GXT400 (7 Channels)...
Midland GXT 550 two way radio has a constant RX read out on display as though it is constantly receiving.
my 550 got wet wos leftout in the rain now after three mounths it shows a low battery
Dec 12, 2009 | Midland Two Way Radio
Midland radio battery pack constant vibrate
Nov 01, 2008 | Midland Radio Communications
Dec 06, 2007 | Radio Communications
Radio Communications Logo
56 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
