WHEN THE SYSTEM UPDATED I GET THAT ERROR MESSAGE " AMAZON SYSTEM RECOVERY .
IT STATES THAT IT WILL REBOOT IN A FEW MINUTES OR UNPLUG IT FOR A HARD REBOOT BUT IT DOES NOT SOLVE THE ISSUE. IT IS ON THE AMAZON FIRE TV STICK WITH ALEXA
  • 105 Answers
SOURCE: error message: water tap closed .
check water inlet valve clean of rubbish from water inlet hose
otherwise water inlet valve maybe faulty
Posted on Jan 02, 2008
  • 7 Answers
SOURCE: update problem with symantec antivirus
Close the antivirus program and reopen it. When it isclosed, the icon yellow for norton will not appear on bottom right hand side along with volume icon etc. You may also restart the computer to see id that helps. Right click the Norton icon and see id it says ENABLE AUTOPROTECT or DISABLE AUTOPROTECT. Try enabling.Try the same update after a while. If that does not work, try reinstalling Norton. I get 100s of viruses from 100s of friends and all sorts of things happen to me anti virus etc
but I am told that pretty normal
Posted on Dec 13, 2008
leecom72
  • 4806 Answers
SOURCE: savedump.exe error
Hi there
Savedump.exe is located in the folder C:\Windows\System32. The file is a Windows core system file. The program has no visible window. savedump.exe is a Microsoft signed file. Therefore the technical security rating is 4% dangerous.
Some malware camouflage themselves as savedump.exe, particularly if they are located in c:\windows or c:\windows\system32 folder. Thus check the savedump.exe process on your pc whether it is pest. I recommend Security Task Manager for verifying your computer's security.
If you want to get the full potential of 64bit processor then you will have install XP X64 and yes i'm sure SP3 will install.
Good luck and thanks for using Fixya!!
Posted on Feb 11, 2009
SOURCE: PS3 bricked with Major Error Red Screen
i just dont know
Posted on Mar 12, 2009
  • 700 Answers
SOURCE: non-system or disk error is displaying on screen
Set your first boot device to run first in cdrom in your bios settings. To be able to see the cdrom.
Posted on May 03, 2009
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Jan 21, 2015 | Tablets & eReaders
Help to reboot my tablet
Hi, you need to perform a factory reset, follow these instructions:
Dec 31, 2014 | Tablets & eReaders
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
Oct 27, 2014 | Tablets & eReaders
Android System Recovery
Obvious question is what the tablet had been doing during its' last use.
Was something newly installed, was system or apps updated, etc. ?
Were all the APPs and or system shut down properly ?
Did update or installation recommend restarting system, prior to use ? Were multiple installations / updates performed ?
Your device appears to be in a recovery boot-loop.
As stupid as this may sound ...
Is the power adapter connected ? Let battery charge for at least 30 minutes and try again.
If battery is low, it may not complete the reset. - you should have seen something on the screen, denoting " wipe and reset " procedure and completion - prior to (#1) Rebooting device
Per your post, you have already (#4) wiped the data and instructed the device to reset to factory settings, then (#1) Reboot system.
That is the generally accepted reset method
This problem is not all that uncommon, it generally results when attempting reset, internal boot commands error for what ever reason. ( can not find the factory restore / recovery file set ).
This problem is more common when "fixes ", Specialty " Roots " or "mods" have been installed by the user - making changes to the boot program and commands OR when manufacturer files have been deleted / moved from system access. - Common suggestion is to work backwards through the mod processes and / or attempt to re-install mod or follow the special mod recovery method.
Without having available the proper ROM " flash " update / installation file(s), and you may " brick " the device.
I recommend you go to manufacturer site and check for available ROM files, reset / reinstallation processes ( memory card method ? )
You state the tablet is less than six months old. You may want to contact manufacturer for possible warranty service.
They will most likely ask the referenced obvious questions, to better understand the cause / nature of the device failure and recommend the best immediate possible solution.
This may not be what you seek, I hope it will provide better direction.
Apr 20, 2014 | Hannspree SN10T1 101 Tablet
What does it mean when android robot is laying on its back
I am giving you an example with an Motorola Tablet. I'd try clearing your cache partition, you can get to the android recovery with your buttons.
As you're going through the options don't do the factory data reset, look for wipe cache partition then follow the instructions to reboot.
Hope this helps!!! Let me know if you need more help
-Nadeem
Dec 25, 2012 | Ematic 7" eglide Pro Tablet
My HP e9120f gave me the following error message the other day. "reboot and select proper boot device..." My first thought was my hard drive was bad. I could turn off the computer and after a...
You might have another part that has gone bad. Check the RAM and see if it gives you any problems.
There is a program call mem test that you can burn to a CD and test your memory. But if your no longer able to get to the bios:
you def had a hardware problem.
May 04, 2011 | HP DT PAVILION ELITE E9120f DESKTOP PC
Was using system and then it just powered down. When started back up it stated that there was a system error and the options were to restart normally or to do a system recovery (recommended). Would only...
Hello.
From your description, sounds like a hard drive error: problem with recovery, hard drive message.
So, I'd recommend a replacement hard drive.
Hope this helps.
Oct 21, 2010 | Toshiba Portege M800 Notebook
I can not put a desired event on recording thru"create timer"scre
aparfenov
The receiver hard drive is comparable to a computer hard drive. When a problem is detected with the hard drive, the receiver will give an error message stating a problem has been detected. Depending on the severity of the problem, sometimes it will show that unplugging the receiver for 1 minute will resolve the issue. Other times, a message will state that the hard drives needs to be reformatted, which will erase all content on the hard drive. It sounds like this is what happened to your recordings. If unplugging the receiver did not resolve the issue, we may need to replace the receiver. Please call 1-800-333-3474 and speak to a Technical Support agent.
Ray Calo
DISH Network
Apr 25, 2010 | DISH Network ViP622 DVR DTV Receiver /...
System shuts down after surfing the internet
Regarding the error code, all you need to do is update your driver. You can do this by downloading the most up to date driver from motorola here.
Unfortunately, it seems like this might be two seperate issues.
Sometimes machines, especially laptops but it will happen to desktops as well, will shutdown when they are overheated in an attempt to prevent damage to the physical hardware. Judging by the "after about 15 minutes" comment, I think this might have something to do with it as that 15 minute window would give a non-functioning fan or unventilated laptop enough time to overheat your machine.
If the driver update does not stop the random rebooting and you do not think the machine is hot when it reboots, do this:
right-click My Computer and choose Properties; click the Advanced tab. In Vista, click the Start button, type System, Properties, Advanced, and press Enter. Click Continue if prompted by User Account Control.
In all versions, click the Settings button under 'Startup and Recovery'. Uncheck the Automatically restart box, and click OK twice. The next time the problem occurs, instead of rebooting you will likely see a text screen reporting a system error. Report back with what error it gives you.
Nov 30, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Error message: HD521-2W
this error is basically a fatal error. you will endd up needing to replace your hard drive soon but if you dont like doing a recovery every few days and loosing your information all the time replace the hard drive
Mar 30, 2008 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
