Question about Sony Computers & Internet
Sony prs-700 frozen. No response to hard or soft resets. Shows usb connected to pc but no drives visible on pc when attached. The reader is charged and boots stalling on the opening page
  • 69 Answers
SOURCE: My Hp ipaq h1940 pocket pc is frozen on the hp
check HP support for a rom update for your model. the h1940 had some problems you are having.hope this helps
Posted on Jan 19, 2010
  • 11 Answers
SOURCE: I have a sony e-reader prs-600. I plug in the
Please turn OFF the Reader and press the Reset button using a sharp pointed object to reset it.
Next, please connect the Reader directly to a different USB port of the Computer using the supplied USB cable.
Now, please allow the Reader to charge for 2-3 hours and check if it charges. This should resolve the issue.
However, if the issue persists, please try connecting the Reader to a different Computer to confirm if the issue is with the Reader itself.
If the Reader is charging with a different Computer, there might be an issue with the iMac, else, with the Reader.
Note: please ensure to connect the Reader directly to the Computer using the supplied USB cable.
Posted on Mar 01, 2010
SOURCE: MY SONY POCKET IS FROZEN ON CAN NOT TURN OFF NONE
Go to this link on from Sony e-support
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C1008849&fes=true&mdl=PRS300
mine was frozen and I could not turn it off - so I did a SOFT reset (just pressed the reset button with the end of a paperclip) with the reader ON (even though instructions say to turn off I didn't cause this was impossible to do), then slid the power button to reactivate - the yellow light came on, waited a few minutes -and it said opening book - and now all is fine
good luck, hope it works for you!!
Posted on Jun 05, 2010
SOURCE: My Sony reader prs-600 is frozen. The reset button
Try holding the reset for 5-10 seconds, then flip the power switch quickly, three times. If this doesn't work, check the light next to the power switch. If it is flashing yellow, follow the same process. It might take up to three tries.
Posted on Jul 27, 2010
SOURCE: Sony PRS 300 reader STUCK, FROZEN, 184 books on it!
did you use the usb to recharge it? maybe you've connected the usb to the ebook but it didn't recharge. The battery will drain if you just connect it to the computer but didn't recharge (bad contact between the book and usb, mine does that). try to recharge it, make sure the light beside the on/off button is on (red), let it sit for few hours that it should be fine
Posted on Aug 12, 2010
Sony E-reader PRS-T2 wo'n't charge
Use a mobilephone charger, not a cable for PC; then update the firmware.
Nov 13, 2013 | Sony Computers & Internet
Tip
Sony Reader Frozen
This solution applies for issues with Sony Reader Frozen in any model. PRS500, PRS505, PRS700, PRS600, PRS300, PRS900, PRS350, PRS650 and PRS950.<br /><br />1. Connect the reader to the AC Adapter (If available). If not, then connect the Reader via USB to the computer<br /><br />2. Hit the reset button for 3 seconds.<br />Location of RESET button:<br /><br />On the back = PRS500 - PRS505 - PRS 700<br />At the bottom: All the other models<br /><br />3. The red steady light should come on, if not, try the reset again while the unit is connected<br /><br />4. Allow the reader to charge for 40 Minutes (on PC make sure the computer does not go into sleep mode.<br /><br />5. Disconnect the reader and see if operational.<br /><br />GoodLuck!<br /><br />eBookBoy<br />
on Jul 11, 2011 | Computers & Internet
Tip
Sony ebook Reader is Frozen, Not charging
The Sony Reader used a special type of display; the LCD can retain an image without having power. It takes power while changing the pages. In most of the cases, if the power is fully discharged, the LCD will keep the last image that was displayed it makes an impression that the Reader is frozen. However, the Actual thing is, the screen retains the last image on the screen and there is no power to change the pages. These type of situations can be resolved by charging the Reader sufficiently.
Each step in my solution is a possible resolution. Hence I suggest thatyou perform each step and check the operation.
  1. Charge the battery fully by connecting to a computer or by using a compatible AC Adaptor. It may take a few minutes (up to 15 minutes) to displaythe charging symbol if the Reader is fully drained in its last use.
  2. Once the reader is charged fully (at least 45 minutes), slide the power button to turn ON.
  3. Perform a softreset. We can perform a soft reset by pressing the reset button on the Reader.
  4. After the RESET button has been pressed, slide the POWER switch to activate the Reader device again. If the Indicator light nextto the power button on the Reader device is yellow, the unit is attempting to start up. If this is the case, allow it a few moments to complete startup.
  5. If the Reader is still not charging up properly, connect the Reader to computer or AC Adaptorand then press the reset button.
  6. Disconnect the Reader device from the computer (if applicable) and then slide the POWER switch to activate the Readerdevice. Check if the Indicator light next to the powerswitch on the Reader device is yellow (indicating it is turning on) and if the unit is responding.
    If the unit isstill frozen, connect it again to the computer or AC adapter and while connected,check if the Indicator light next to the power switch on the Reader device is red. If this light is red , allow the Reader device tocharge for one hour sothere is sufficient charge for troubleshooting.
    If the issue persists, perform a hard reset to resolve the issue. Please follow the steps to perform a hard reset:
    Under certain circumstances, moisture condensation can occur. Moisture condensation can becaused by moving the Reader device between temperature extremes or if theReader device has come in direct contact with moisture. If you suspect moistureas the cause, allow the Reader device to sit for a few hours before attempting to turn it back on.
Reader is frozen, PRS650 frozen, image stayed in PRS650, Help to reset PRS 650. RESET PRS650. how to reset PRS-650. Hard reset PRS650. How to perform a hard reset for PRS 650. PRS650 freeze, PRS-650 frozen.PRS-650 is not charging, does not turn on PRS 650, PRS650 is not turning ON. PRS-650 does not charge.
on Jan 12, 2011 | Audio Players & Recorders
I let my reader PRS-300 connected to pc all night to charge the battery, but now it doesn't turn on...what i can do??? and i tried to connect to pc again to see what happened, but not even the red...
Hi vailzamorta!
You can try to do a "Soft Reset" on the Reader. Do not worry, this will not affect your ebooks =)
1. Disconnect the reader from the computer
2. Hit the Reset button at the bottom of the unit for 3 seconds with a paper clip
3. Slide the power switch at the top of the eReader
4. The screen will blink and show opening book.... allow the reader to load
Just in case here are some other steps to try in case this does not make any difference
http://digialreader.freeforums.org/solution-for-frozen-sony-reader-t10.html
GoodLuck!
eBookBoy
Jul 26, 2011 | Sony Reader Pocket PRS-300
My sony ereader prs-650 is stuck on sleep mode and it wont do anything ,, it wont charge when connected to the computer
Each step in my solution is a possible resolution. Hence I suggest that you perform each step and check the operation.
Charge the battery fully by connecting to a computer or by using a compatible AC Adaptor. It may take a few minutes (up to 15 minutes) to display the charging symbol if the Reader is fully drained in its last use.
Perform a soft reset. We can perform a soft reset by pressing the reset button on the Reader.
After the RESET button has been pressed, slide the POWER switch to activate the Reader device again. If the Indicator light next to the power button on the Reader device is yellow, the unit is attempting to start up. If this is the case, allow it a few moments to complete startup.
If the Reader is still not charging up properly, connect the Reader to computer or AC Adaptor and then press the reset button.
Disconnect the Reader device from the computer (if applicable) and then slide the POWER switch to activate the Reader device. Check if the Indicator light next to the power switch on the Reader device is yellow (indicating it is turning on) and if the unit is responding
If the unit is still frozen, connect it again to the computer or AC adapter and while connected, check if the Indicator light next to the power switch on the Reader device is red . If this light is red , allow the Reader device to charge for one hour so there is sufficient charge for troubleshooting.
Under certain circumstances, moisture condensation can occur. Moisture condensation can be caused by moving the Reader device between temperature extremes or if the Reader device has come in direct contact with moisture. If you suspect moisture as the cause, allow the Reader device to sit for a few hours before attempting to turn it back on
Jan 12, 2011 | Sony Reader Touch PRS-600
Aug 02, 2010 | Sony Reader Touch PRS-600
I was reading my 600 Sony Reader when all of a sudden there was nothing on the screen. I attached it to my computer but the light has never come on and there is absolutely nothing on the screen.
It seems that the Reader is frozen.
Slide the Power Switch to the OFF position and press the reset button, located at the base of the Reader, using a sharp pointed object. This may resolve the issue.
However, if the issue persists, connect the Reader directly to the USB port of the Computer using the supplied USB cable and charge it for 3-4 hours.
After charging the Reader, try resetting it again.
If the issue still persists, the Reader may require service.
Mar 02, 2010 | Sony Reader Touch PRS-600
Sony PSR 300 e-reader frozen screen
since you've tried charging the reader using a non-compatible charger, there might be some internal malfunction occurred in the reader. however, i suggest that you try charging it by connecting it toi the computer. as the yellow ligjht is is blinking, it seems that there is no chrage in the reader. so try charging it by connecting it toi the computer.keep it connected for at least 4 hours. it should resolve the issue.
Jan 28, 2010 | Sony E-reader Portable E-book MP3 Player
I purchased a used Sony PRS 700. It is locked in
If the Demo mode is appearing on the Reader and you're not able to do anything in the Reader, it seems that there is an internal issue occurred with the Reader. However, since you've already performed soft reset and hard reset with the Reader, the service of the Reader is the only available options. The PRS700 Reader is covered under the Sony exchange program. This exchange is for the same or comparable model. Please follow the below mentioned link to get it repaired or exchanged from Sony:
http://eservice.sony.com
Jan 12, 2010 | Sony E-reader Portable E-book MP3 Player
Sony PRS-600 permanently 'Restarting' so I can't use it. What can be done?
Please check whether the Reader is fully charged. Connect the Reader to the Computer and keep it connected at least 4 hours to get it fully charged. If the issue still persists, perform a soft reset. To soft reset the Reader, press the RESET button using a sharp-pointed object. That should resolve the issue.
Jan 07, 2010 | Sony Reader Touch PRS-600
Computers & Internet Logo
82 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
