Question about Retail Supplies
Program tax for pcr350 - Retail Supplies
How to program tax into only one department. I have entered the tax according to instructions but it automatically puts tax on all department keys.
You set the rate in the tax rate program then you set each department as taxed or no tax. If it is affecting all depts, you need to look up department programming and set tax (usually tax1 to 0 or off) in each dept
Sep 28, 2017 | Retail Supplies
How to program two non cumulative taxes on a Casio PCR-T2000A?
Firstly, change the rates for each tax in the tax rate setting tables of your manual. Then you need to turn on tax rate 1 and 2 for departments that need both. This is done in the department programming tables. Tax setting can be quite involved so follow the tables carefully.If you need a programming manual, One of the users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T2000_users_and_programming_manual.html
Dec 31, 2012 | Casio Parts Cash Register PC Desktop
Sharp cash register xe a41s tax programming
The two main programs to edit are the tax rate program and the department program. have a look at these tables in the manual and set your tax.
If you need an XE-A41S manual, there is one here:
http://the-checkout-tech.com/manuals/cashregisters/Sharp_XE-A41S_programming_manual.html
Aug 01, 2012 | Sharp XE-A402 Electronic Cash Register
How do you change the tax #2 ??? tax #1 is 5% and tax #2 is 7,5% but i want to change tax #2 for 8,5%, how should i proceed??
i have cash reg. gold 2100 , and i programed the cash reg for (7.5 % to 8.5% ), by changing the 1508030 tax shift 2 to 1509030 tax shift 2 while the key is on program position.
the steps from beginning :
first: put the key on prog position.
2nd: enter 1505000 then press tax shift 1 ( 5%)
3rd : enter 1509030 then press tax shift 2 ( 8.5 %)
4th : enter 037000000 dep 1 ( tax able )
5th : enter 037000000 dep 2 ( tax able )
6th: enter 037000000 dep 3 ( tax able )
7th: press # / no sale .
put the key to reg position and try it . good luck and happy new year.
p.s. for no tax dept dont enter any thing .
Jan 01, 2011 | Casio Parts Cash Register PC Desktop
Programming tax on a casio pcr-t2100
Key to Program enter 3 subtotal 1 tax pgm (tax rate with decimal) cash tend subtotal.
ie 7.35%
3subtotal1 tax pgm 7.35 cash tend subtotal
Oct 12, 2009 | Casio Parts Cash Register PC Desktop
I want to program tax on the non tax button , any help , thx
Download the manual from Casio's website for the specific model and follow the instructions to re-program tax. See Program Tax in the Index. Page 87 I think
Sep 03, 2009 | Casio Parts Cash Register PC Desktop
How to program tax on a casio te 8700f register
Hi.
I have never heard of an 8700. I have info on the 8000 and 8500 so it may be similar to one of these. If it has never been programmed to use tax before, then I will need to know how your tax system operates. Do you use add-on, or add-in tax, how many rates? Are all PLUs taxed, or just some?
Mark
Jan 27, 2009 | Casio Parts Cash Register PC Desktop
How to program tax rate for te-2200
Hi. If you bought it new then your dealer should have set all of the system options for you so it is strange that the tax is not programmed. Normally you would only need to set the rate when your tax rate changes. Has it been calculating tax at all? Did it come from your dealer with a standard program in it?
Nov 26, 2008 | Casio Parts Cash Register PC Desktop
Casio tk1300
I'm in Australia and only going on the program manual for your area, it states that canadian tax is tax on tax? if this is true then you probably entered a code for add on or add in tax and thereby changed it all.
you need the following
tax table address
1 125
2 225
3 325
4 425
rounding off codes
rounding off to 2 decimal places is 50
rounding up to 2 decimal places is 90
cut off to 2 decimal places is 00
tax system code
tax table with out tax rate 01
tax table with tax rate and add on rate 02
add in tax rate 03
Canadian tax-on-tax rate 04
starting point
to get the starting point you multiply by 100 and subtract 1
eg 50 cents = 0.50 X 100 - 1 = 50 - 1 = 49
eg $4 = 4.00 x 100 -1 = 399
to program the tables go through these steps
go to program 3
tax table address eg 125
subtotal
tax rate
ca/amt tend
starting point eg 0.50 = 49
ca/amt tend
rounding eg 50
tax system eg 04
ca/amt tend
ca/amt tend
here you have 2 choices,
press ca/amt tend to go to the next tax table ie 225 and start over by entering the tax rate and go through the procedure again
or
press subtotal to finalise the tax table you are on
Hope this helps,
Adam
Apr 18, 2008 | Casio Parts Cash Register PC Desktop
Retail Supplies Logo
352 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
