Question about Rancilio Coffee Makers & Espresso Machines
When I run water through my Rancilio Silva it comes out milky. Why?
I always run water through the Rancilio Silva before I make the first coffee of the day. The first couple of shots has a coffee stain, and then it clears up. This morning, it came through milky and continues to do so. What is the problem?
    Scholar:
    New Friend:
  • 78 Answers
Rinse the machine with Baking Soda solution (2 to 4 quarts).
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Posted on Dec 30, 2016
SOURCE:
Hi I have a Ranchilio Silva machine all of a sudden the water smells burnt and taste of coffee is yuk, any thoghts
  • Make sure your using filtered water
  • After you steam, turn of the steaming switch and hit the water switch and let it go until a steady stream of water comes out then switch it off, this refills the boiler
  • Try to descale it or backflush it, with Jo Glo or Full Circle.
good luck!
Jul 11, 2011 | Rancilio Silvia Espresso Machine
Rancilio Silva, after working well for three years, does not heat water when powered on. Suspect heating element bad. But is there a step I can take prior to replacing elements. Also, where can I get...
Remove the 4 screws on the top panel. Make sure machine is not connected to power. Check the thermostats on the boiler, there should be 3 of them, push in on the small red pin in the middle of them one of them should click in. Now fill up your tank plug machine in and turn on.
Oct 20, 2010 | Rancilio Silvia Espresso Machine
The steamer on our raniciolo silva does not work: the top light does not go out and no steam comes out
More than likley its your steam thremostat. Replace it and you should be good to go. Its on top of the boiler and the one that doesn't have the red dot on it.
Aug 28, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia stopped heating up.
Hi
Check to see if it will heat in the steam position. If it does, then you have a bad brew thermostat, and just need to replace that. Its the one with the red dot. If not, run some water through the wand and see if it is milky? If its milky you have a blown heating element. You can also do an ohms check in the element. There should a reading between the element terminals of 12 to 16 ohms. If you have no reading, your going to have to replace the boiler.
Oct 26, 2009 | Briel Coffee Machine Multi-Pro...
5 year old Rancilio Silva with no heating of water
Hi
Do an ohms check on the element. With an ohms meter check the reading between the elements. The reading should be between 12 and 16 ohms for a 110v machine and 50 to 60 for a 220v machine. If you have no reading or a higher reading you have a bad element.
Replace the boiler
Jul 24, 2009 | Rancilio Silvia Espresso Machine
Rancilio Silva - coffee lost its punch
Try backwashing the group with purocaff.
Are you using coffee ground at the store or do you grind just before use?
How fresh is the coffee less than a month or more?
If more than a month(whole beans) it is no longer useful.
If more than a 3 days(ground), that is stale also. It will be very diffucult to get good espresso from that(not impossible, but difficult).
If using store ground, it cannot be ground older than a week(coffee loses flavor and taste minutes after being ground). Try getting less coffee more often and adjust the grind setting that you use. If you have always used setting 3 on the store grinder try 2.5.
If grinding at home adjust the settings on the grinder to a slightly coarser grind and fill the portafilter slightly over the top of the basket, now tamp to the indent(fill line) in the basket. that should be sufficient to pull a great shot.
May 17, 2009 | Rancilio Silvia Espresso Machine
Iam looking for a less expensive grinder to use with my Rancilio Silva. Is there one?
My local coffee specialist suggested a sunbeam conical cafe series grinder. He sells a lot of the Rancilio Sylvia machines and recommends the sunbeam to go with them. Retails at $219. Just bought one and very pleased with it.
May 06, 2009 | Rancilio Silvia Espresso Machine
Super hot water out of the group head on my Rancilio Sylvia
My Rancilio Silva is not making the water or steam hot anymore. Is it fairly easy to replace the heating element?
Dec 29, 2008 | Rancilio Silvia Espresso Machine
Coffee Makers & Espresso Machines Logo
41 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
