Question about Cell Phones
How do I turn on the speaker? - Cell Phones
    Top Expert:
  • Cell Phones Master
  • 12,962 Answers
The instruction manual that came with your phone will tell you the menu to use to achieve this. If no manual go to web site for download.
Posted on Dec 25, 2016
It`s showing overload
There are a number of causes....but most of the time something in he speaker section is shorted. Turn off the stereo...Remove all connected speakers from the back...turn it back on. Is the error message still there? If so its internal...if not turn off again and attach one speaker at a time, turning the stereo off to add each speaker. until error. You could have a shorted speaker or wire or too many speakers.
May 11, 2016 | Audio Players & Recorders
How do I pair speaker with phone
turn both phone bluetooth and speaker bluetooth off. then turn them back on. the speaker's light should be flashing indicating its searching for a device to pair with. as its flashing make sure your phones bluetooth is visible and searching. they will pair and your phone will tell you and the speakers light should quit flashiing and just remain on.
Oct 20, 2014 | Audio Players & Recorders
Gli sound systems am-1000
test this God bless you
The speakers are not connected properly. Check the speaker connections. The Mute function is activated. Turn off the Mute function. The volume is turned all the way down. Turn up the volume. Neither set of speakers is selected (if unit has A/B buttons to select sets of speakers). Press either A or B to select a set of speakers. Both sets of speakers are selected, but only one set is connected (if unit has A/B buttons to select sets of speakers). Press the appropriate button to deselect the speaker outputs which are not connected. The receiver is set to TAPE MONITOR (if applicable). Turn off TAPE MONITOR mode. Headphones are plugged into the main unit. Unplug the headphones. The source selector is set to the wrong source. Select the proper source. The impedance of the speakers is less than the rating for the system. Use speakers with the correct impedance rating.
Jul 11, 2013 | Audio Players & Recorders
Dell speaker connection color code needed
  • *Turn off your Dell laptop.
    *Connect speakers to the speaker control box. The speaker control box varies depending on the speaker system you have. Two-speaker systems will have a female jack on the back of one speaker that you plug the other into the second speaker. If your system has a sub-woofer, all of the other speakers will plug into it. The connecting cords are color-coded to the jacks on the back of the control box.
    *Plug an audio cable into the "Audio-In" port on the back of the control box. If the audio cable is color-coded, it will be green.
    *Plug the other end of the audio cable into the headphone jack on your laptop.
    *Plug the speakers' power cord into a surge protector to protect your system from power surges. *Plug the surge protector into a wall outlet.
    *Turn on your speakers and set the volume at a medium level. Be prepared to turn the volume up or down after you turn your laptop on.
    *Turn on your laptop and confirm that sound is coming from your speakers.
    Thanks for rating
    Good luck
  • Jan 25, 2011 | Dell Dimension 4600 PC Desktop
    My speaker button does not turn on
    What do you mean by does not turn on? Does it mean the whole speakers are not turning on?
    If it is, try to see if your speakers are connected to the wall plug.
    Dec 27, 2010 | Logitech Z-2200 Computer Speakers
    Want to install exterior speakers
    Go to menu, use ch. keys and click audio, use vol. keys to go to sub-menu, when sub-menu appears, use ch. key and click down to the tv speakers under heading "speakers", turn them "off". On left side in the back are the audio plugins, the top two under the s-video plugin, red on top, white next down are the two audio speakers rca jacks. Plug your external speakers, like the ones that you'd buy for a computer, in those two. The manual does not say if you plug speakers in these jacks the tv's builtin speakers will be cut off, but this tv I got was being used for a computer monitor and the tv's speakers were turned off from the menu, so I guess plugging in external speakers does not turn off the tv's speakers and would interfer with the external speakers. I suppose you could try it both ways and see, leave the tv's speakers "on" and plug in externals and see if they are turned off automatically.
    Jun 04, 2010 | Westinghouse LTV-19w6 Television
    SXG490 displays
    if overload warning displays only when you activate speakers "a",,, please check your wiring and speakers
    for that channel, first remove both A speakers turn it on, if its okey plug one speaker and try again if okey remove it and try the other one, when you see which one is it check the wire and the speaker ( every time you hook the speaker turn it off before that) overload means something is shorting and that protects the unit to prevent furter damage
    Dec 19, 2009 | Audio Players & Recorders
    Denon AVR-3802
    I have repaired many of these Denon receivers over the last few years.
    Since the headphones work, that means if you dis-connect the speakers it will turn on and not go into protect (when power cuts off a few seconds after turning the unit on).
    The most likely problem is a bad speaker. to find out which speaker is causing the problem, do this.
    Start out with just one speaker connected and then turn on the unit. If it turns on and plays music, you know that speaker is good.
    Now turn the unit off again and add another speaker and keep the first speaker connected. Once again, if the unit plays, that speaker is also good.
    Keep doing this same procedure one speaker at a time. As soon as you connect a speaker and then try to turn on the unit and it goes into protect, the speaker you just connected is bad.
    To confirm that this speaker is the bad speaker, dis-connect all speakers and only plug the suspected bad speaker into a speaker jack that worked with one of the other speakers.
    If the unit still goes into protect you know then that you have found the bad speaker.
    If the unit still goes into protect, that speaker is bad and you will need to take it in for repair or replace it.
    make sure you use 8 ohm speakers. if i remember correctly these Denons can use 6 ohm speakers, but those are harder to find and most home speakers are 8 ohms.
    If the unit does not go into protect and that suspected bad speaker plays in one of the other speaker jacks, what you really have is a bad channel in the amplifier, the channel that the suspected bad speaker was previously connected to.
    If you find out you have a bad channel, you will need to take it in to an repair center. Preferably an authorized Denon service center. There are not very many of those around. I work at the only authorized Denon service center in the entire state of Michigan.
    If I can be of more assistance, don't hesitate to ask. And a good rating is always appreciated. :)
    Jun 22, 2008 | Denon AVR-3802 Receiver
    first you have to test separatly your speakers outputs
    disconnect all wires speaker and speakers, turn on your reciever and look if you still have the same problem «CHECK SPEAKER WIRES alert» if yes you have to go to a specialist to fix it... if no test one line after one line with and without speaker connected until the problem reappear to locate the bad line or bad speaker.
    Apr 26, 2008 | Yamaha HTR-5650 Receiver
    Denon avr-886 VERY FRUSTRATED
    Read the manual. You've either got crossed speaker wires, it's overheating, or it's a more serious problem. The same just started happening to mine, so I'm taking it in.
    Oct 03, 2007 | Denon AVR-886 Receiver
    Cell Phones Logo
    21 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
