Bought a new kmix and can't lift the head. Can't see anything about it in instructions. Little lever at the back seems useless. Kmx5 model
3 Suggested Answers
smartr10U
  • 1305 Answers
SOURCE: how do i lift head?
I am pretty sure that the model K5ss has a fixed head that cannot be tilted...
The bowl just moves up and down..
K
Posted on Jul 23, 2009
  • 517 Answers
SOURCE: I have a Viking Model 6690 and I cannot lift the
Good day!!!
for the meantime please read this link by clicking it for any Idea on how to lift the presser bar lever..
I'll come back for a better solution...Thank you!!!
http://www.tpub.com/content/aviation/10330/css/10330_72.htm
Posted on Aug 02, 2011
My dough hook is stuck in my K mix kmx50.
yes the dough hook is a firm fit on those
Instruction Book KMX50, KMX59 English - Kenwood
www.kenwoodworld.com/.../Instruction-Manuals/kMix.../kMix.../18362iss2%20KMX..
Apr 29, 2017 | Kenwood Kmix Kmx50 Stand Mixer, White
Printhead on DCP-540CN needs cleaning
there is a solution in the user manual that you got with your printer
Jun 17, 2013 | Brother DCP Office Equipment & Supplies
The entire faucet is lifting off and spraying water at the joint when the lever is activated and water is being used,do I need to call a plumber to repair this. It seems that the faucet cannot be screwed...
No you do not need a plumber,
below under the sink, there are two valves, One for Hot ,One for Cold.
Turn them to the right.make sure they are turn all the way with a little pressure at the end. Now the kitchen has no water.
With a wrench ot pliers remove the water hoses, There may be a little water left in the hose so don't panic.
Now this may be a little harder.
Put yourself all the way under the sink,with you on your back.
Do you see the taps. There may be a fitting with screws. remove screws and fitting. You should be able to remove the whole Tap.
With you new tap... Follow their instruction.
When you are putting the hoses back on.. make sure they are slightly snug.
We don't want it to leak again.
Turn you water back on and slowly turn on your taps.
Aug 05, 2010 | Rohl A3608LMAPC Single Lever Country...
Tappan stove model # 30-3053-23-02. How do I remove the stove top?
For Tappan stove model 30-3053-23-02.
Each burner (4) is mounted to the stove top with three 4.5mm hex screws. All 12 screws must be removed, which is easier said than done. In my case, of the 12, 6 heads snapped off. The other 6 heads had to be drilled out. The metal is very hard (tempered from long exposure to high heat?), so use a carbide/diamond high-speed drill bit (1/8" or 3/16").
The front corners of the stove top are each held by a clip. After removal of the burner mount screws (or heads at least), lift straight up on each front corner of the stove top to release the top from the clip. An alternate method is to use a screwdriver as a lever to pry the corner off the clip. Once released from the clips, the front pulls up, while the back is "hinged" (like lifting an auto hood). Using a stubby phillips screwdriver, unscrew one of the back hinges. At this point, the stove top can be lifted off.
If you are fortunate, the burners were unmounted by simply removing the screws. But if they broke off or had to be drilled out, it seems the best thing to do is just purchase new burner assemblies ($20-$30 each). In either case, also buy new screws specifically for mounting the burners.
Dec 22, 2009 | Kitchen Ranges
I need to lift the head a little. the wire whip
Hi LEDAVETORI, you don’t provide the model number or say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, which would helpful, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number and select a file listed under Owners Manuals and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance.
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn scre3e30899.jpgw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
If you find the adjustment screw missing, you’ll need to replace it. But now you’ll need
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 18, 2009 | Food Mixers
Cannon MP510 printer has Error, - The type of print head
I solved this on mine by removing and reinstalling the print head.
1. Remove and set aside the ink cartidges (don't make a mess)
2. lift the gray print head lock lever that is to the left of where the ink cartridges go.
3. Lift out the print head out without touching the ink ports inside, the contacts on the back, or the print nozzles on the bottom. The print head is the grey thing with circular ink ports that seat the ink cartridges. there are good pictures in the PDF of the Easy Setup Instructions available on the Canon Printer website. Look under the printer, then support, then downloads: http://gdlp01.c-wss.com/gds/0900002776/mp510_esi_us_v2.pdf .
4. Put the print head back in, lock the lever, reinstall the cartridges in the roper positions. And voila!
If this doesn't work you may actually need a new print head.
Oct 08, 2009 | Canon PIXMA MP510 All-In-One InkJet...
I can't find out how to tilt the motor head on the K45SS model Kitchenaid mixer. The user guide indicates there is a lever to tilt it but there is not one to be found. Help!
On my kitchenaid stand mixer, the lock lever to lift the head is located on the opposite side of the speed control. If there is no lever there, check to see if there is a spot that looks like there should be a lever there, if there is, but the lever is missing, you might have ended up with a mixer with a manufacturing error. In that case, your only option is to take it back to the store where you bought it.
Dec 23, 2008 | KitchenAid K45SS Classic Stand Mixer
Canon MultiPass F20 - "Wrong Cartridge error msg" - not new but hardly used
Take both cartridges out and then you will see a grey lever in the front of the assembly that holds the two cartridges in it.
If you lift that lever up it will allow you to remove the print head assembly.
Soak that in some hot water, use a straw to help blow out any remaining ink residue in the holes that the ink flows throw and once it is dry again put it back in and see if the error goes away.
I'm just running a head cleaning, nozzle cleaning etc. now but I appear to be back in business.
Mar 27, 2007 | Canon MultiPASS F20 All-In-One InkJet...
jasbo
jasbo
