Question about Kitchen Ranges
? Does 24s tanning bed have a fuse 0
Wolf systems
SOURCE: tanning bed setup
HI a bought a tanning bed last night from a tanning salon it was hooked threw a phone line or something like that my hubby brought it home and hooked it up here .now i cant get it to work ,will i ever see it work and how can i get it to work for me.
Posted on May 28, 2008
  • 293 Answers
SOURCE: how do i locate the
The fuse on this bed should be on a compartment on the bottom end of the bed, there is a little plastic drawer, and a fuse screw inside that.
Thanks
Posted on Jun 05, 2011
Gophering
  • 187 Answers
SOURCE: i need a manual for a sunual 3200 tanning bed ,i
Try this link...
www.freemanualsonline.com
Kind regards!
Posted on Sep 13, 2011
emissionwiz
  • 78267 Answers
SOURCE: need a manual for esb 16 tanning bed free
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory installed systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Posted on Oct 11, 2012
  • 60 Answers
SOURCE: Is tanning on a tanning bed just like tanning outside in the sun?
No - it's very different as outside, various objects block the direct rays of the sun and allow you to be outside in the sun for a lot longer. Tanning beds are very instense. You should not be on the bed for longer than 10-12 minutes for your first sessions and be very careful about adding extra time.
Posted on Feb 18, 2013
Sunvision facial tanning bulb buzzing and flicker's and won't light
It is not the socket. If the bulb is installed correctly, there is a starter on the ballast that needs to be replaced.
May 07, 2014 | Wolff Sunvision Pro 24S Tanning Bed
My sunquest pro 14 Se came on bulbs lit and shut off and will not come back on
Have a trained technician to check voltage going to bed and for blown fuse on back of bed. You may have a circuit breaker tripped, but I would bet that you have checked that.
Feb 02, 2013 | Wolff Sunvision Pro 24S Tanning Bed
Sunquest 24s wont do nothing
Have a trained technician to check for blown fuse on back of bed and then for burned out wiring in top and/or bottom of bed. Voltage going to bed may also be a cause. These beds are sensitive to wrong voltages.
Dec 21, 2012 | Wolff Sunvision Pro 24S Tanning Bed
How to repair a tannin bed model H-24RSB
Have a trained technician to check for wrong voltage going to bed. Then for burned out components and wiring inside the bed. Turn power off to bed before doing this.
Nov 15, 2012 | Wolff Sunvision Pro 24S Tanning Bed
What does the end of the cords look like on a sunvision 24 tanning bed
It should be like a big black power cord with a plug on one end.
Aug 28, 2012 | Wolff Sunvision Pro 24S Tanning Bed
I have a sunvision 24 tanning bed and it isn't coming on what do i do
Have a trained technician to: Check main breaker, check that bed is getting power to it, check for bad fuse on back of bed, check for burned out wiring inside of bed at main relay, check that the timer is good.
Need info on changing fan motor on sunvision tanning bed
Sunquest repair manuel -
https://docs.google.com/viewer?a=v&q=cache:RHuta0rhh0UJ:www.wolfftanningbed.com/files/Sunvision%2520Pro%252024S%2520Tanning%2520Manual.pdf+&hl=en&gl=us&pid=bl&srcid=ADGEESiOZAyvaJoGk2XbMLNiN6HBrbcakHM2K0Ueegni817TYN8RJZmcoxwgkvEhbTnez0fQXKeYfAagL-vGcQOZe-_Lz1A8lISeW2omXte5lo7_wf0N6Ksg9heMx9RvHP7NvzHekFW_&sig=AHIEtbTIgYvCR-poN4KvkaVWUdCqD8mjDA&pli=1
Feb 05, 2012 | Wolff Sunvision Pro 24S Tanning Bed
Kitchen Ranges Logo
29 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
