Question about Health & Beauty
Dd E. m M ? Does 24s have a fuse
Is there any configuration needed in S6720-30C-EI-24S-AC or S2700 to make these two switches communicate.
S6720-30C-EI-24S-AC use the 10GE port, but Huawei S2700 only have GE port. So before you connect these two switched, you need to check the SFP module, to match the speed
May 25, 2018 | Computers & Internet
Driver side brake light and turn signal not wwoking
I truly hate to state the obvious, and please forgive me for doing so, but HAVE YOU VERIFIED THAT THE LIGHT BULB IS GOOD? There is really VERY LITTLE to the lighting circuit!
Apr 18, 2015 | Forest River 2014 Solera 24S
Does the S5700 Interface Support 100M Optical Modules?
Fixed optical interfaces on the S5700EI, S5700SI, S5710LI, and S5700HI support 100M optical modules, while interfaces on extended front cards do not support 100M optical modules.
In the S5700LI series, only the S5700-28X-LI-24S-AC, S5701-28X-LI-24S-AC, S5700-52XLI- 48CS-AC, and S5700-28X-LI-24S-DC support 100M optical modules on their GE interfaces.
The S5710EI series switches support 100M optical modules only on their combo interfaces.
When a GE optical interface of the S5700 works at 1000 Mbit/s, it can only use a 1000M optical module. When the interface works at 100 Mbit/s, it can use either a 100M optical module or a 1000M optical module.
Hope can help you!
S5700 28C PWR SI Price Buy Huawei S5700 28C PWR switch Huanetwork com
Jun 04, 2014 | Computers & Internet
My sunquest pro 14 Se came on bulbs lit and shut off and will not come back on
Have a trained technician to check voltage going to bed and for blown fuse on back of bed. You may have a circuit breaker tripped, but I would bet that you have checked that.
Feb 02, 2013 | Wolff Sunvision Pro 24S Tanning Bed
Sunquest 24s wont do nothing
Have a trained technician to check for blown fuse on back of bed and then for burned out wiring in top and/or bottom of bed. Voltage going to bed may also be a cause. These beds are sensitive to wrong voltages.
Dec 21, 2012 | Wolff Sunvision Pro 24S Tanning Bed
I have a sunvision 24 tanning bed and it isn't coming on what do i do
Have a trained technician to: Check main breaker, check that bed is getting power to it, check for bad fuse on back of bed, check for burned out wiring inside of bed at main relay, check that the timer is good.
Aug 28, 2012 | Wolff Sunvision Pro 24S Tanning Bed
Health & Beauty Logo
14 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
