It always draining when spin but when finish washing ,it will not drain.
    President:
  • 3,074 Answers
Clogged Pump or Hose: I had a penny get to the inlet of the pump, so small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed. I Hope this helped MERRY CHRISTMAS, Tim
Posted on Dec 25, 2016
  • 135 Answers
SOURCE: bosch washing machine won't drain and the door won't open.
Sounds like you have a blocked pump.To empty the machine manually lower the drain hose into a bowl or bucket.Once emptied the door should open.On most modern machines there will be a filter behind the kick plate at bottom front of machine, Check this for any foreign objects then try a spin before putting on again.If problem persists come for further options.
Posted on Nov 22, 2008
  • 127 Answers
SOURCE: Washing machine will not drain all the water. If
there is always a little water left in the drum assembly when done pumping. however it is usually well below the level of the clothes basket/drum so that there is none contacting the clothes when at rest.
if you can actually visibly see water within the clothes basket/drum when the cycle is complete, then check below.
have you lengthened the drain hose beyond the standard length to reach to your taller than normal sewer/drain inlet??? if so then you're getting more water returning to the unit when the pump shuts off and if the extra hose is long enough then theres enough water returning to your tub so that the basket sits in water at rest..
if so you'll need to install a check valve to keep the additional water from going backwards into your unit. some of these units have one built into the drain hose where it connects to the pump.. i tried looking yours up via the model # listed on the 1st page but got nowhere with that number.
you could also have a restriction in your pump or drain assembly that may be slowing things down some.. can't be of more help without proper model # though..
hope this helps,
best of luck,
ttfn
Posted on Oct 25, 2009
  • 942 Answers
SOURCE: washing machine drains, wont spin, making clicking
If your washer won't spin, check these: It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Jan 30, 2010
  • 4 Answers
SOURCE: washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Posted on Mar 20, 2010
  • 3 Answers
SOURCE: hoover optima hnf6167 7kg washing
My washing machine completes its cycle but is leaking water from the left hand side on to the floor, Why is this???
Posted on Apr 25, 2010
Zanussi aquacycle 1200.After a wash has finished and i empty washing, reload again,it wont start and none of the lights come on.eventially it works ok again after a good 5-10 mins.
you have probably done no harm. try selecting spin and drain again to ensure the water has drained properly.
Machine starting on its own after 5 minutes or so is usually the door lock failing, again not caused by your actions.
Sep 05, 2016 | Zanussi Washing Machines
My Whirlpool washing machine will not spin or agitate. The water drains out but does not always spin. If you turn the tank it tightens up and then spins properly.
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. Or
http://www.youtube.com/watch?v=TB_W6sPdzkM
Pl click if helped
Apr 10, 2013 | Washing Machines
My whirlpool machine does not spin properly and there is always water left after the spin cycle, when its turned on it will stop after spin cycle like its finished but there is still a lot of water left in...
hi, it sounds like one of two possibilties, will try and help out. The first thing to check is whether the water/drain pump is actually working fine, i think it blocked. Secondly the pump may also be overheating and malfunctioning during the cyle, run it without clothes and check the flow of the drain during the drain/spin cycle and take it from there.
Jun 14, 2011 | Whirlpool Washing Machines
Kenmore 80 series Model # 110.23832100\r\nthe washer fills up agitates, when finished washing it stops pauses a while then starts to spin, you can hear the water going out put it is like it can't pick up...
Hi
If the washer is not draining then it is due to a clogged drain pump, drain filter or a kinked drain hose. Clean the drain hose, inspect if the drain hose is plugged. Also check the connection to the drain pump and make sure wiring is fine. Check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Apr 07, 2011 | Kenmore Washing Machines
Not draining when wash finished
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Smelly drain and wont spin properly
check filter may need pump then flush through on hot wash.
Jun 29, 2009 | Washing Machines
Whirlpool Ultima Wash II Intermittent Rinse/Spin
Hi, the water not drain , the drain pump was stuck , causes are the small linen and other foriegn materials are bind the pump infeller , pump connot completely turn . so drain stuck need to clean , also the drain hose have sedimentation of soap and dust.
Feb 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
