Question about Cell Phones
How to set up my lgk4 phone - Cell Phones
Unlock Lgk4 forgot screen lock password
You must do a factory reset to bypass a missing password.
Nov 16, 2016 | Cell Phones
I have forgotten my unlock code to lg revere
This is copied directly from the manual - check out #5 at the bottom.
Hope it helps!
7.7 Security
The Security menu allows you to
secure the phone electronically.
1. Open the flip and press
[MENU]
2. Press Settings & Tools.
3. Press Phone Settings.
4. Press Security.
5. Enter the four-digit lock code.
The lock code is the last 4 digits
of your mobile phone number if
it is set. The lock code is the last
4 digits of your MEID if your
mobile phone number is not set.
Aug 02, 2012 | LG Revere MobiPhone - Black Verizon...
I want change language
Turn your cell phone on, and press the menu button to begin viewing the menu options of your phone.
Scroll through the menu options of your phone until you come to a settings option. Every cell phone has a different basic set up, but they all have "settings" areas, where the basic phone settings are located. One you have found the settings option, select it. The settings option will open a list of basic cell phone functions. Some cell phones have larger groups that are then broken further into smaller ones, and other phones have a bunch of small individual settings options.
Look for the option under settings that says system, display, display info, or language, and choose it. Whichever of these options your cell phone has, the outcome will be the same, so don't be discouraged if your cell phone has a slightly different set up than other cell phones.
Choose your desired cell phone language from the list and choose it, if your cell phone had a language option directly under settings. If not, then look for the language option under the system, display, or display/info options, and then choose your language from the list it provides.
Turn your phone off and then back on again, just to ensure that the new language change did take effect, and will remain. Your language settings should now be changed, and you should be viewing all functions of your cell phone in your newly chosen language
Sep 02, 2011 | Nokia 3410 Cellular Phone
Change language from german to english
    • 1 Turn your cell phone on, and press the menu button to begin viewing the menu options of your phone.
    • 2 Scroll through the menu options of your phone until you come to a settings option. Every cell phone has a different basic set up, but they all have "settings" areas, where the basic phone settings are located. One you have found the settings option, select it. The settings option will open a list of basic cell phone functions. Some cell phones have larger groups that are then broken further into smaller ones, and other phones have a bunch of small individual settings options.
    • 3 Look for the option under settings that says system, display, display info, or language, and choose it. Whichever of these options your cell phone has, the outcome will be the same, so don't be discouraged if your cell phone has a slightly different set up than other cell phones.
    • 4 Choose your desired cell phone language from the list and choose it, if your cell phone had a language option directly under settings. If not, then look for the language option under the system, display, or display/info options, and then choose your language from the list it provides.
    • 5 Turn your phone off and then back on again, just to ensure that the new language change did take effect, and will remain. Your language settings should now be changed, and you should be viewing all functions of your cell phone in your newly chosen language.
May 14, 2011 | Alcatel Cell Phones
I can't configure my phone w760i using sun cellular network,if i brouse the internet and sending picture it always notify me please contact service provider
To subscribe to packet data you need to contact your service provider through phone or go directly to their office.
They will send you the settings for your model. Please save the settings to your phone and set it has a default settings. Then you can start using the internet in your phone.
To get GPRS/MMS setting, you need to contact your service provider through phone or go directly to their office.
They will send you the settings for your model. You will receive service settings in the special text message called as smart message. Please save the settings to your phone and set it has default settings. Then you can start using the GPRS/MMS in your phone.
Thank You
Mar 09, 2011 | Sony Ericsson K750i Cellular Phone
Am a sony e w660i user , i cant able to receive internet settings
If your phone misses the Internet settings at purchase, you can easily download the settings directly from your phone. If your phone can´t download the settings, contact your network operator.
To run Settings download:
Go to Settings > Setup wizard > Settings download and press "Select"
Note:
The first time you start your phone or insert a new SIM card, the Settings download is triggered from the start-up wizard.
You can run Settings download as many times as you like from the Settings menu.
Feb 12, 2011 | Sony Ericsson W660i Mobile Phone
Reset settings my phone
Hello
1. Power the phone on. The phone should go through the basic start-up and come to rest on the main screen.
2. Press the "Menu" button and find the "Settings" option, then "Reset Settings." You may have a "Restore Factory Settings" option here, or a more extensive menu that lets you choose what to reset, such as sound settings, display settings, phone settings or all.
3. Reset the phone by choosing "All" or "Restore Factory Settings." Press the "Yes" button when the phone asks you to confirm that you want to reset it.
4. Power cycle the phone, and when it comes back on you will be able to reconfigure your settings correctly.
THANK YOU
Jan 27, 2011 | Samsung SGH-X530 Cellular Phone
MY PHONE IS LOCK AND I CANNOT UNLOCK IT. WHAT CAN I DO?
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.samsung.com/us/consumer/mobile/mobile-phones/t-mobile-phones/SGH-T929ZKATMB/index.idx?pagetype=prd_detail&tab=support
Page 165 from your manual:
Reset Settings
From this menu you can reset your phone and sound settings to the default settings or perform a Master reset.
Reset settings
1. From Idle mode, touch Menu ➔ Settings ➔Reset settings ➔Reset settings.
2. Touch the check box next to each of the following that you want to reset
• All: Phone, Display, and Sound settings are returned to default values.
• Sound profiles: only sound settings are returned to default values.
• Display settings: only display settings are returned to default values.
• Phone settings: only phone settings are returned to default values.
3. Touch Reset.
Master reset
From this menu you can reset your phone and sound settings to the factory default settings.
1. From Idle mode, touch Menu ➔ Settings ➔ Reset settings.
2. Touch Master reset, enter your password, then select Yes to confirm.
The phone resets to the factory default settings automatically and when finished displays the Main menu.
Hope this helps, let me know if I can do anything else for you.
JimmyC
Oct 13, 2009 | Samsung Memoir SGH-T929 Cell Phone
Gprs n wap settings
Wap/gprs settings are to be requested from your service provider. Call your service provider's customer care and ask them to send wap settings to your mobile phone or visit your provider's website and look for the wap settings.
The master reset code for Nokia 3110c is *#7780# or *#7370#
May 12, 2008 | Nokia 3110 Cellular Phone
Cell Phones Logo
57 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
