Question about Radio Communications
About my icom ic 2100 no transmital but linear ic & drive is good. is their any other parts that may cause this trouble? tnx & regards...
    Habit-Forming:
  • 9 Answers
First thing to try is to read the DC voltage with the PTT pressed on Pin 2 of the RF amplifier "brick". It should be somewhere around 6 volts. If it's way high or zero, it's likely that yours is one of the victims of a design flaw wherein Q19 on the underside of the main board (and right next to Pin 2 of the RFPA module) fails. It usually fails due to heat. It's a well-enough problem that, were you to send it in to Icom for repair, it would likely be repaired and have an undocumented heat sink panel affixed to its back. For awhile, an internal memo at Icom service instructed techs to make the repair and blame the failure on high antenna system SWR, and then charge the customer big $$ for it. Incidentally, when the radios come back, they now have that little heat sink installed on the replacement transistor.
I've had 6 of these radios come across my service bench for that very problem. It's a pretty easy fix once you know to look for it.
BTW, it's also possible that one of the PIN diodes in the T/R switch has failed open, but not nearly as likely as Q19.
I've also found the stock chassis heatsink fin area to be insufficient to dissipating the heat from even medium power operation, so for my own radios (I've got 4 of these in service) I have put quiet 12 vdc muffin fans on the heat sinks to help keep the radios running cool. Many users believe the relatively massive heatsink area of the outer chassis is enough to dissipate the heat produced by the final PA block, but any time I can't stand to rest my hand against a heat sink because of its temperature, I have to wonder just how badly the components producing that heat are suffering, so I opt for the fan.
HTH es 73,
Barney KL7HNY
Posted on Jan 01, 2017
Cannot transmitt
The Icom 756 Pro is a very expensive radio. If you bought one and it's not transmitting I really recommend taking it back. It could be anything from the mic, power supply, final transistors, board, anything really. It's going to need to be scoped and looked at in person.
Jun 30, 2016 | Icom Transceiver Ic-756proii
Icom ic-m35, no transmitting
Contact the Icom service center. Their main web-page is www.icom.com. From there you can select your geographic area and service (commercial, marine, amateur, etc).
Aug 17, 2013 | Icom IC-M36 VHF Marine Radio
My icom 706 mk2g transmits on VHF uhf but not on HF whats the possible problem
My icom 706mk2g does no give me hf power on the hf bands but on uhf is working wel.
On the s meter the last blok is turn on.
Reseiver is working wel.
Wat can it be?? Transistor Finals broken???
The two srfj?
May 19, 2013 | Icom IC-706MKIIG
My icom ic v8 is weak on receiving...pls help
Is it week because the incoming signal is coming from further away or is it coming from down the street . Maybe the problem is on the other end,the incoming signal is not strong enough.Lots of reasons.
Jun 04, 2012 | Icom Ic V80 Vhf Handheld Two Way Radio...
Icom IC-M34 transmit correct but do not receive if sql is above 0
Sound like a speaker problem, dosconnect the speaker and check it with a meter, it should read 8 ohm. Good luck.
Mar 13, 2011 | ICOM Informatique Floating Hand Held Vhf...
IC w32a has been apart about 3 times to re solder the power plug ,this time I put it back together and the the 2m band wont transmit but for a second then off.Nearby radio will pick up the brief...
Thanks for letting me post a question.
After taking it apart again I found a pin on the lower board socket that got bent over on reassembly........
May 13, 2008 | ICOM Informatique BP-180M,...
Radio Communications Logo
76 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
