Question about Samsung Kitchen Ranges
Our new Samsung range has a blinking hourglass on the right side of control panel. What does it mean?
4 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: Control panel Roper gas range replace or buy new range?
4337979 Control-Clock/Oven
Retails for $206.90 easy to replace good luck..
Posted on Sep 29, 2008
mc1bean
  • 3053 Answers
SOURCE: control panel number 4
Hello, There has been a couple times, Frigidaire was sending out the wrong control board in the correct box ( believe it or not it happened to me 2x ).. finally i had to call ELECTROLUX directly and had them send me the board direct to customer.. i believe that the 4 is because there is a wiring issue with one of the microswitches where the damper motor is and it will not allow the damper / control board to recognize "open" position ..I don't know how old your fridge, but in this case you should get a tech out with some testing equipment. Thanks Mike
Posted on Oct 23, 2011
SD Tech
  • 14553 Answers
SOURCE: samsung lcd tv can't find a source, buttons on remote control don't respond, nor buttons on the control panel on the right side of the TV device
consult the owner manual or call Samsung---this set likely has a lockout feature that locks both the remote and the keyboard out.
You might also want to research this by taking the model number and Google key words "remote lockout" etc.
Posted on Jun 02, 2012
What does The Hourglass symbol mean on a Samsung front load washer
The hourglass symbol usually means the machine is "Delayed" This might be because of a breakage or issue inside the machine. If this is not the case, check the user instruction manual
Oct 03, 2016 | Samsung Washing Machines
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
What does blinking temp bar lights mean on RS261 side by side. No response from display
It is telling you the temperature is out of range. Put a thermometer in it and it should be below 40F 4.5C and above 32F 0C.
Nov 13, 2014 | Samsung Refrigerators
Samsung Range control panel won't turn on.
Check the voltage at the ac cord. Make sure you have 240 there. Sounds like your missing one leg there
Mar 24, 2014 | Samsung NE595R0ABBB 5.9 cu. ft. Large...
Locked light blinks but oven is not locked
This does not necessarily mean the DOOR is locked but that the control panel may be in a "locked" mode. This prevents children from playing with controls. Look closely at the touchpad for one selection that shows a tiny padlock under or on it. When found, push and hold for 5 seconds. You should hear a beep which will confirm the unlocking of the control panel.
Nov 19, 2012 | GE Profile PGB918 Kitchen Range
What does the blinking lights mean when it flashes "F" then "02"?
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch
May 23, 2011 | Kenmore 42926
I had a flash on my tv and now it doesn't work but there is a blinking hourglass now blinking on it. What does that mean?It is a 46" gateway flat screen.
U mean now,u turn on the tv,u just a flash of picture only few sec. but u still have sound?This problems mean,u have a dead board call the LCD inverter board.Take ur tv aparts,replaced this LCD inverter board u will get ur picture back.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
May 14, 2010 | Gateway PLSM46TV 46 in. Television
Garage door indicator light blinks 5 times
this probably means you have a bad photo eye if you happen to have to doors side by side may be picking up on other sides photo eye just switch sides from left to right, however if the lights are coming on but does not mean that photo eye is not bad it has a small circuit board inside of it...
Apr 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Kitchen Ranges Logo
563 people viewed this question
Top Samsung Kitchen Ranges Experts
Oloyede Monsuru
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
