Question about Humax Televison & Video
I have a Humax 9150T which shows AV preferences as s-video for TV scart. It will not let me change to RGB which is applicable to the TV scart input I have to my Tv. So pic is all grey
techman
  • 3130 Answers
SOURCE: b/w picture
sounds like this set is in the UK??? or somewhere out of the states. If it working good on the tuner or telex box , the equipment your plugging into the AV inputs are not compadible to the tv set or there is a setting in the TV menu to change the format to pal
Posted on Aug 13, 2006
snakehead
  • 1074 Answers
SOURCE: Can't change Proline TV / Video combo to scart
visit www.partstore.com to purchase a originald remote for your set if they do not have it they can get it for you.good luck
Posted on Apr 08, 2007
SOURCE: CNNECTING DMREZ27EB FREEVIEWDVD RECORDER, TO MY TV 2 SCARTS, AND MY PANASONIC VCR VIDEO RECORDER
I CONNECTED SCART TO TV 1 TO DVD FREEVIEW SCART 1, THEN I VCR SCART IN/OUT TODVD FREEVIEW RECORDER SCART 2, THEN RF CABLE FROM FREEVIEW RECORDER OUT TO VCR RF IN ,VCR RF CABLE OUT TO TV RF IN. RF SLOT IN ON FREEVIEW LEFT EMPTY THEN CHANGED TV TO AV 2 WHEN USING TO RECORD /PLAY EITHER VCR OR/ FREEVIEW DVD . I DO HOPE THIS HELPS SOMEONE. IT TOOK ME A WHILE TO SORT OUT REGARDS R. ELLIOTT.
Posted on Feb 23, 2008
Benimur
  • 6966 Answers
SOURCE: I want to setup my
Based on your query "...which jack...put the green cable ...", I would suggest that you replace that green cable with a 3.5mm Stereo Phone Male to Twin RCA Male as shown below.
19ba6b8.jpg. The stereo phone would match the green INput ((Front) of the Logitech X-540 while the twin RCA (white & red) would match the RCA AUDIO OUTput of the LG 37LC2D.
Of course hooking it up this way would not fully utilize the 5.1 features of the X-540 (Rear and Sub/Center) but the TV sound will come out of the front speakers.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 09, 2008
SOURCE: I have an Onn 15''
The LCD should have a Source button.This will select the AV input.Using the right arrow instead of "OK" button should help select your input.
Posted on Mar 20, 2009
KEEP GETTING MESSAGE ON TV (RGB ON TV SCART HAS BEEN ENABLED)
trouble shooting common problems when using RGB ...
https://www.retrogamingcables.co.uk/trouble-shooting-guide-for-rgb-sca...
No video or sound on tv when using RGB SCART cable. Check that the SCART socket you have plugged the SCART cable into is an RGB enabled port (this is ... Some TVsets display an 'RGB' message in the top right of the screen for a short ...
SCART - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/SCART
WikipediaThe signals carried by SCART include both composite and RGB (with composite ... A VCR will often have two SCART sockets, to connect it to the TV ("up", ... SCART enables a device to command the TV to very quickly switch between signals, ... The box can instead ask the TV to stop displaying the normal signal and ...
How to use your TV as a computer monitor for gaming, videos
www.cnet.com > Home Entertainment
CNETJan 26, 2012 - Many modern video cards have an HDMI output. ... The trick, of course, is finding a TV with RGB-PC inputs. ... You can also send him a message on Twitter: @TechWriterGeoff. ... (Or just enable game/graphic mode) ... As yet I've been unable to find anything online that lists TVs that do or don't work with PCs ...
Scart fully RGB enabled? ' AVForums
Feb 09, 2016 | Televison & Video
My youview has taken over my humax channels
Put BT box into standby. This is probably due to the scart connection. Try to connect both boxes via HDMI if possible.
Aug 23, 2014 | Humax Televison & Video
I have an rca tv that im trying to hook up to a dvd player and I can't get a signal or channel to work. I don't have a remote but the menu button works. what channel should it be on to play dvds
depend on tv input; if it's only one rca input mean is composite video; if are 3 rca input mean rgb video. so from dvd you need a scart to composite or rgb. on tv usually is AV or AUX channell. try to find a universal remote to select properly the channel. bye
May 23, 2014 | Televison & Video
Have a red wii. plays but no color help......plz
Hi.
Check all the leads from the Wii to the TV and make sure they are not loose or broken. Also check the regional settings in the settings menu and make sure its set to your area.
If your TV has component inputs make sure you have a Wii component cable or you could buy a Wii RGB Scart cable if you only have a spare scart input. If you turn on the Wii press menu on your TV and alter the AV settings. For example, change the setting to composite opposed to RGB. Also check your Wii settings and change them to be in parallel with the TV settings.
Regards.
May 31, 2011 | Nintendo Wii Console
What cable do I need to set up the HD and where do I plug it in? All the ones I lookes at have a rectangular end and I don't see one on the like that on the TV. I am using the 2 scart sockets for cable...
Any of these will work.
ANTENNA IN: UHF/VHF 75 ohm Din type (If in HD Broadcast)
EXT 1: SCART (AV Input/Output, RGB Input, TV Output)
EXT 2: SCART (AV Input/Output, Y/C Input, AV Link)
EXT 3: S-VIDEO (Y/C Input), RCA pin (AV Input)
EXT 4: RCA pin (Vomponant Input)
PC INPUT: D-sub 15 pin (ANALOG RGB), 3.5mm Javk (Audio Input)
Service Manual can be found here: http://www.givemefile.net/smanuals/lcd_tvs/sharp/file/45437.html
Feb 06, 2011 | Sharp Aquos LC-26GA5E 26 in. HDTV-Ready...
Can you please tell me how to connect my Humax 9200T PVR to my Onkyo TX-SR608. The Humax does NOT have HDMI connections and the manual does not mention the connection of a PVR. The Humax Manual is of no...
You will need to purchase a scart to HDMI converter - available in the UK for about £40.
If you Google 'Scart to HDMI converter' you should find several options, which will be cheaper if you are in the US!
Unfortunately the Humax box you have only supports Scart A/V I/O, which is of course now obsolete.
Jan 17, 2011 | Onkyo TX-SR608 Receiver
How to connect an LG26LE3300 TV to a Humax PVR-9200T and to an Inventive DVD video player? These worked fine with my old TV using scart cables but not with the LG.
You will see the colored jacks on tv. There should be a print by them that says out. Match the colors from the jacks on the tv to the same colored ones on the Humax. The ones on the Humax should say input or a/v or dvd, or phono. From the dvd player, match the colors from here to the tv. The tv should have another set of 3 colored rca jacks that say imput on them.
From DVD Player out to tv in From tv out to Humax in/av/dvd/ ect.
Yellow is video Red is Audio Right Channel White is Audio Left Channel
Jan 14, 2011 | LG Televison & Video
How to connect a humax foxsat-hd to a panasonic dmr 75eb recorder,to a panasonic th42px60b plasma tv,also will i get better result using component cable instead of scart lead. please can you...
You plug the humax into the panasonic dvd recorder and then from the outputs of the dvd recorder plug it into the panasonic plasma inputs
Is component video better than RGB? Well, yes and no, RGB provides the widest bandwidth and is the best choice for connecting audio visual devices like a Freeview box, digibox or Sky+ box to your TV, home cinema or home theatre system. DVD is however different, to reduce the amount of storage required DVDs are recorded using component video, it is therefore better to connect a DVD player via a component video cable to your TV, plasma or LCD TV etc.
Thanks if you have any questions please do not hesitate to ask
Dec 02, 2008 | Televison & Video
Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Jan 13, 2008 | Daewoo DV-6T955B DVD Player/VCR
Televison & Video Logo
55 people viewed this question
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Tony
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
