Question about Saeco Coffee Makers & Espresso Machines
Can i use CLR to descale Saeco Vienna Plus? - Saeco Coffee Makers & Espresso Machines
EsWorld
  • 1618 Answers
SOURCE: How do I turn off
After performing the descale, use the menu buttons to get to descale and set to reset.
Posted on Apr 06, 2009
  • 1089 Answers
SOURCE: instructions on descaling a Saeco Vienna Superautomatica
. Remember, it is better to descale more often than not enough.
  1. To decalcify your boiler, remove your water tank and fill it with hot water (100 to 120 degrees). Open a pack of decalcifier and mix into the water tank. Once it is dissolved, place the tank back on the machine, and then turn the machine on.
  2. If you just open the steam knob and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes. Longer is better. It is very important that the machine does not remain on to heat the boiler anymore than necessary.
  3. Repeat step #2 for your machine. Do this until you have consumed the entire water tank of solution (approximately four to five cycles). (I do it at night before I go to bed and let the last cycle set in the boiler till morning.)
  4. Remove water tank and rinse it with fresh water.
  5. Refill water tank with fresh water and place it back on the machine.
Repeat step #2 to rinse the machine, only this time use the entire water tank at one time, and there is no need to let it set.
Posted on May 30, 2009
SOURCE: how do I descale my Saeco Vienna Deluxe?
Purchase the Saeco descaler. Mix solution accordingly. Pour into water tank. Run a cappucino cup full of water through the wand. Wait about 20 minute and repeat. Do this until all the water is gone in the tank. (Don't run all the water at once!). Rinse water tank well. FIll with clean water and run through the wand. I do this twice just to be sure I have gotten all the chemical out.
Posted on Aug 22, 2009
  • 1089 Answers
SOURCE: descale
2. Open the steam knob and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes. Longer is better. It is very important that the machine does not remain on to heat the boiler anymore than necessary.
4. Remove water tank and rinse it with fresh water. Now open the knob and run the whole tank at one time to rinse.
Done
Posted on Dec 24, 2009
SOURCE: My Vienna Deluxe super automatic Saeco is needing
just run that amount thru, that's only about a cup full, ya could water it down by even 25% still be OK.
Posted on Jan 26, 2010
Talea giro plus / Descaling with vinegar
There are a couple of things I am thinking for this:
If the espresso machine is not spraying the hot steam like it should it says in the manual to take apart the steam apparatus and clean with hot water then to run hot water through the device after each use to clean.
Furthermore, have you seen those CLR commercials? I am sure white vinegar would be fine to put through the machine. As far as the ratio is concerned use a low concentrate to start out like 1 to 3 then increase until desired results occur.
I hope this helps!
Nov 06, 2012 | Saeco Talea Giro Espresso Machine
What is the proper method to descale?
Yes, you should empty the bean hopper and put the solution in the tank and run it through.
Nov 09, 2007 | Saeco Vienna De Luxe Espresso Machine
Vienna machine very scaled up can you help?
Use acetic acid based descaler. Can be bought at dealers, online, pharmacies, or from Saeco direct.
Aug 22, 2011 | Saeco Vienna SuperAutomatica Coffee...
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
I need the mannual of the "Saeco Vienna digital" coffe machine.
Press the menu button then using the up/down arrows keys select descale, then place a large container under the wand and slowly open the knob, follow instructions on screen when it says finished close knob, clean tank and fill with fresh water then open knob to rinse.
Oct 04, 2009 | Saeco Vienna Digital Coffee Maker,...
How do I descale my Saeco Vienna Deluxe?
Aug 15, 2009 | Saeco Vienna De Luxe Espresso Machine
No water output even after manual prime
Water line is clogged you will have to open machine and find where the line is clogged.
Mar 23, 2009 | Saeco Vienna SuperAutomatica Coffee...
Saeco odeo giro and the red squiggly light
This is the descaling indicator.
If it flashing your machine needs descaling.
Feb 22, 2009 | Saeco Vienna De Luxe Espresso Machine
How do I turn off the "descale now" warning on my Saeco Vienna Deluxe espresso machine?
Dec 05, 2008 | Saeco Vienna Digital Coffee Maker,...
Coffee Makers & Espresso Machines Logo
41 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
