How do I ret the flame, 501 error - Office Equipment & Supplies
Tip
Clarion M301RC-RET Manual Download
Download Clarion M301RC-RET Marine Remote-Mounted Control Panel Manual
Have you misplaced your Clarion M301RC-RET Marine Remote-Mounted Control Panel Owners Manual / Installation Guide?
Would you like a digital, searchable, pdf version of the Clarion M301RC-RET Marine Remote-Mounted Control Panel Installation Manual / Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
____________________________________
on May 03, 2010 | Televison & Video
HOW DO I SOLVE ERROR CODES EDC 00637-03, FER 03279-04, RETS 04029-04, RETS 04013-10, RETS 04001-10
Don't you have a manual in your truck? I can't find a manual here, so unless someone with the same car comes home and sees your question, this one will be difficult to solve.
Jan 14, 2015 | Toys
What will cause disc error on the motorola dcp 501
Either a dirty laser, faulty tracking mechanism, or a weak laser(aging) will cause unit to mistrack. When this happens the mechanisms are replaceable and not repairable.
Mar 30, 2014 | Motorola DCP-501 Receiver
Reliant 501 Natural Gas won't stay lit
Reliance water heater?
Thermocouple is good if the pilot stays lit continuously.
501 is older model. Unknown if this unit has FVIR protection and sealed combustion chamber or open air intake on front of unit.
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
With FVIR protection:
Get more fresh air to the unit.
Clean the flame arrestor screen.
Test and replace the thermocouple:
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
Inspect and clean burner and combustion parts
Test gas pressure, bleed air out of gas line.
Replace gas control valve.
Test draft air by lighting match and see if smoke is pulled into the vent pipe at draft hood on top of tank.
Aug 20, 2012 | Water Heaters
How to create an object of VSI-Fax like in winfax
For VB
Private Sub Form_Load()
Dim sendObject As Object
Dim ret As Integer
Set sendObject = CreateObject("Winfax.SDKSend")
ret = sendObject.SetSubject("TEST!!!")
If (ret = 1) Then
MsgBox ("SetSubject Failed")
End
End If
ret = sendObject.SetKeywords("Test")
If (ret = 1) Then
MsgBox ("SetKeywords Failed")
End
End If
ret = sendObject.SetResolution(0)
If (ret = 1) Then
MsgBox ("SetResolution Failed")
End
End If
ret = sendObject.SetQuickCover(1)
If (ret = 1) Then
MsgBox ("SetQuickCover Failed")
End
End If
ret = sendObject.SetCoverText("This is a Test.")
If (ret = 1) Then
MsgBox ("SetCOverText Failed")
End
End If
ret = sendObject.SetUseCover(1)
If (ret = 1) Then
MsgBox ("SetUseCover Failed")
End
End If
ret = sendObject.ShowCallProgress(1)
If (ret = 1) Then
MsgBox ("ShowCallProgress Failed")
End
End If
ret = sendObject.SetTo("Somebody")
If (ret = 1) Then
MsgBox ("SetTo Failed")
End
End If
ret = sendObject.SetNumber("#######") 'My fax number
If (ret = 1) Then
MsgBox ("SetNumber Failed")
End
End If
ret = sendObject.SetAreaCode("###") 'My area code
If (ret = 1) Then
MsgBox ("SetAreaCode Failed")
End
End If
ret = sendObject.SetPriority(1)
If (ret = 1) Then
MsgBox ("SetPriority Failed")
End
End If
ret = sendObject.AddRecipient()
If (ret = 1) Then
MsgBox ("AddRecipient Failed")
End
End If
ret = sendObject.LeaveRunning()
If (ret = 1) Then
MsgBox ("LeaveRunning Failed")
End
End If
ret = sendObject.GetRecipientCount() 'this shows 1
MsgBox ("Recipient Count: " & ret) 'recipient
ret = sendObject.Send(1)
If (ret = 1) Then
MsgBox ("Send Failed")
End
End If
End Sub
If u like that Appreciate me by giving vote.
And try to be little specific while u ask question, that means, if u want code on any object ask for which language u r in need of?
Oct 19, 2009 | Esker VSI-FAX 4.x (25301) for Unix
Visual basic 6.0
Use a compare (instr) command to search the sentence for punctution and spaces. Increment a variable for each word found, resetting the search string and retaining the start position of each find.
Feb 27, 2008 | Computers & Internet
Crosley gas oven will not heat up
That's my mom!!! Go Sheila!!! Hehe.. -RET-
Aug 08, 2007 | Maytag CWG3100A Gas Single Oven
21 people viewed this question
k24674
jasbo
jasbo
