Question about Sharp Audio Players & Recorders
Can't find the lens cover on a Sharp CD-BA1200 multi player
2 Suggested Answers
mccluskey1
  • 8302 Answers
SOURCE: Where do I find the laser lens on a Sharb CD-BA1200 cd multi player
are you on about the laser disc lens that reads the cd for it to play?
Method 1 Cleaning a CD Player
  1. Confirm there is no CD in the player. ...
  2. Blow away dust with a handheld air bulb. ...
  3. Remove the lens cover. ...
  4. Select a lint-free cleaner. ...
  5. Wipe a small amount of high-strength isopropyl alcohol onto the lens. ...
  6. Let dry before replacing the cover. ...
  7. Try a lens cleaner disc.
More items...
How to Clean a CD Player: 11 Steps - wikiHow
Posted on Dec 25, 2016
How do I clean the lens in my sharp cd player?
You can buy a commercial lens cleaning disc.
Alternatively you can get Servisol Video 40 spray. Take the top cover off the player. Make certain it has no power applied. Find the lens and spray it with the Servisol. Let it dry. You can also wipe the lens with a cotton bud, which is sprayed with Servisol. It must be dry and clean before you attempt to play it.
Nov 25, 2017 | Sharp Audio Players & Recorders
More items...
Dec 25, 2016 | Audio Players & Recorders
CD player will not recognise or play disc
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it not recognize or play disc.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Good luck.
Apr 05, 2011 | Sharp Multi-System Mini Component System...
The player is not playing the cd is keep on saying reading
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Jan 25, 2011 | RCA DRC500N Multi-disc DVD Player
I have had my Panasonic DVD-F87 Multi-disc DVD Player for over three years and within the last 4 months, it stopped playing DVD's. It plays CDS and CDRs' but it will not play a DVD at all (used to play...
Hello jwbabyj hi, 3 years of good listening to music on your player is rather good for its life, no device doesn't last forever, this failure is due to use, dust, temperature, shock, fluctuating power source and other external devices, which will make you player eventually give up. My solutions suggest the following:
  1. Clean your player lens, there are after market lens cleaners, buy one. and use it to clean the player lens.
  2. You may need to remove the top cover to have access to the lens for manual cleaning if the lens cleaner will not work out. Get one clean ear bud, and dampen one side with warm water, rub this in circular motion to the lens, 3 to 5 revolutions will do, use the other dry side to dry off the lens. replace the cover and test. do this several times until the player works.
  3. If still, this does not work, remove the cover and see if the lens glows visible light, to do this eject the tray, do not place any CD, then close, look at the lens and see if it emits visible light. No light bad lens. needs lens replacement. bring it for service.
  4. Check for worn out belts, does your player spindle spins? no spinning spindle bad player. needs spindle replacement.
  5. If 3 and 4 are likely, better buy a new one.
Aug 11, 2010 | Panasonic DVD-F87 Multi-disc DVD Player
Hi my cd player will play for a couple of tracks then start jumping have cleaned disk but to no availehow can i clean laser on a multi disk
multi-disk or single disc player has only one (1) lens (reader), so you can use those commercially available cd player lens cleaner. ( a disc with tiny brushes in it.)
Apr 30, 2010 | 2004 Land Rover FreeLander
Every time u play multi cd player message comes reading and take long time to play
lens is dirty and having trouble reading the disks. get a lens cleaner disk from any electronics store.
Jan 14, 2010 | Bose Wave music system Multi-CD Changer...
CD Player returns NO DISK code
looks like the OPTICAL LEN part D.O.A. on you , I suggest to replace the OP LEN , AND SHOULD BE ABLE TO PLAY. hope this helps
Apr 19, 2008 | Sharp CD-BA150 Shelf System
52 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
