Question about Bose Car Audio & Video
My 93 camaro z28, stereo wiring is all jacked up.i dont have 12v for my memory.the factory wire harness is cut off how do i wire it to my aftermarket stereo
  • 1,596 Answers
Use A test Light to Locate KEY OFF Power for Memoey, And the Same for KEY ON POWER For Radio Power Lead. there ARE EXTRA of Both @ Fuse BOX. Speakers are Colored Alike In Pairs Of 2 Look for 4 Pair for 4 Channel Set up. OR REWIRE SPEAKERS all together as this is the Most Effective Way to Wire Speakers Anyway. I Hope this Sheds Some Light on your Problem and Helps you Wire it Correctly Feel FREE to REPLY With ANY QUESTIONS.
Posted on Jul 21, 2009
Just had the factory stereo taken out and an aftermarket one put in, had a buddy do it and he cut the factory wiring harness off that's runs into the factory stereo. Is there any possible fix?
Hey, you would be better off to look for your yr/make/model car at a scrap yard and get them to cut plug off with longer wires, then require them together, had to do it with my truck. Hope this helps
Apr 12, 2013 | Car Audio & Video
I need awireing diagram for a premiun sound (jbl) stereo with cd player for a 93 thunderbird
you should get a wiring harness to save you the trouble, however i just put in a kenwood in a 1997 thunderbird, if you cut the black wiring cover all the speaker wires are wrapped together and the other wires will be 12v constant acc, ground, etc. here is a diagram Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Orange/Blue
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire : Orange/Green
Left Front Speaker Negative Wire : Black/White
Right Front Speaker Positive Wire : White/Green
Right Front Speaker Negative Wire : Black/White
Car Audio Rear Speakers Size: 5x 7 speakers
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire : Pink/Green
Left Rear Speaker Negative Wire : Pink/Blue
Right Rear Speaker Positive Wire : Pink/Blue
Right Rear Speaker Negative Wire : Green/Orange
Feb 03, 2013 | 1993 Ford Thunderbird
1995 camaro z28 audio problems
Hi Jamie, Here's an old trick which you may find useful. Take a run down flashlight cell and confirm the wiring to the speakers by holding the earthing line of the speaker cable to the negative and flash the positive side with the feed to the speaker one at a time. With each swipe you will hear a thump from each speaker as you connect and disconnect. In that way you can confirm the cables are the ones you are connecting. Color coding is not always the same. Use a voltage test meter to confirm the constant power and ignition power and don't forget to earth the set once all other connections have been made, Withour an earth it won't work, but you know that anyway. Regards John
Dec 14, 2012 | 1995 Chevrolet Camaro
82 camaro z28 radio wiring
I hope you didn,t cut off your original factory radio harness, The easist way is to buy a wireing harness adapter kit.That hooks up to the wires on your new deck, End has plugs on it that plug into your factory radio harness. They can be braught at most places that sell end install car audio equipment for $15to $25 at the most.
Oct 21, 2012 | Pioneer MVH-P8200BT - Bluetooth/MP3/iPod...
What is the wire color code for a2001 malibu stereo. i would like to put an after market stero in?
if you havent taken the factory stereo out of the vehicle yet, if were you i would go to an auto store and buy wiring harness that plugs into your factory harness, that gives you all the colors to match up with your aftermarket... that way nothing gets cut on or messed up... and with the electical stuff linked to the stereo system, trust me you dont want a headache like that... a harness kit only cost like 15 bucks, plus if you ever wanted to get rid of the vehicle you could take your aftermarket stereo out, and plug the factory one right back in... hope this helps
Dec 10, 2010 | 2001 Chevrolet Malibu
I want to install an aftermarket stereo in my 06 GMC Sierra. Do you have the wiring diagram for the factory stereo harness?
go to walmart or bestbuy and get the wiring adapter so you dont have to cut any wires. they are color coded
Oct 22, 2009 | 2006 GMC Sierra
Need a stereo wiring diagram to reinstall factory stereo in my 93 toyota windom
You shouldn't need a wiring diagram, your factory plug should still be in behind the aftermarket stereo harness, unplug the aftermarket harness and your factory plug plugs directly into the factory harness.... hope this helps..
Sep 21, 2009 | Car Audio & Video
I need to know what color are for what on my radio wire harness
Not for sure if I can help.Someone forgot the golden rule.NEVER CUT THE WIRING HARNESS.I dont have the wiring scematics in front of me but the older models had RED for power,BLACK for ground,and the wiring going to the spreakers should be an off color running together going to the speakers.Probably has a six speaker system.Hope I helped.
Feb 03, 2009 | 1994 Chevrolet Camaro
1995 camaro wiring problems
PAINLESS WIRING makes aftermarket harnesses, check them out
Jan 28, 2009 | 1995 Chevrolet Camaro
When my daughter turns her car audio off, we loose preset stations.
Two questions to narrow this down - one, is it an aftermarket stereo, or a factory one? Two, with the key out of the car, can the stereo be turned on?
If it's aftermarket and it powers on when the key is off, then it's likely two wires are reversed in the harness behind the deck - the constant 12v wire and the switched 12v wire. The constant one is the yellow one, which always supplies power to the deck, keeping power there for the preset memory and the tone settings. The ignition-switched one is so that when the key is turned off, the stereo shuts off (this is the red wire on the harness). If these were reversed, the stereo would always be able to be turned on, and power to the memory settings would be lost when the key is turned off.
Sep 10, 2008 | Car Audio & Video
Car Audio & Video Logo
242 people viewed this question
Top Bose Car Audio & Video Experts
xxxxxx xxx
Tina Robinson
_ST_
Are you a Bose Car Audio and Video Expert? Answer questions, earn points and help others
