Question about Sony Televison & Video
Sony bravia quit working after I heard a spark come from the back
    Top Expert:
  • Sony Master
  • 75,452 Answers
Blown up fuse. Might have a reason. The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Posted on Dec 25, 2016
What does 4-blink error code indicate?
These may help - the first just tell what it is and which ICs maybe the problem (quite technical)
Solved Sony Bravia Blinking Code
Bravia KDL46EX720 Red LED blinks 4 times and TV wont turn on What is the...
or, in the last resort you could try Sony support, either to get a service manual, or to ask a technician. Don't be fobbed with an expensive answer as in one the examples above.
Support for LCD TV BRAVIA Sony
18.November.2015
Nov 14, 2015 | Sony KDL-46EX720 BRAVIA 46 Class LED 3D...
Sony Bravia LCD tv model KDL40S4100 won't hold settings.
What you've heard is right. This is a main system control memory IC fault itself.
Jun 19, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I purchased an Sony Bravia LCD 26 inch of KLV S200A series 3 years back. The LCD has now started developing problems like automatically the power goes off when any particular channel is being viewed and...
You have intermitant problems which may be caused by contact resistance or circuit overheating.After it cooled down the tv starts again. Leave TV on standby at all times.
Jan 03, 2011 | Sony BRAVIA KLV26S200 26 in. LCD TV
Sony bravia kdl-46z4100 is 18 months old. TV speakers quit working. can they be replaced easily, or does a repairman have to be called.
Try the tv unplug,replug it back an hour later.The tv now,resetting back to factory setting.Go to tv Menu.Goto AUDIO setting,go down to reset,the Tuner board is now resetting.The tv should have sound now.Not than,the Tuner board have problems.Not the speakers,yes call the repairman.It'll cost half the price of a new tv.
Sep 07, 2010 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Lighting strikes
check inside /glass fuse/if not power supply might be damaged/uk ohm supplies and repairs
May 01, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My Sony Bravia KDL-40D3000 no longer responds to the IR remote. I also have a 46 inch Bravia, and the remote does work with it. The front panel controls work okay. The remote worked for about 2 years, then...
Had the same problem. The infrared receiver quit working. Could not use the factory remote or the cable remote. Simple fix- I just cleaned the infrared receiver. Both remotes now working.
Mar 27, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Buzzing/fizzing noise from back of sony flat screen tv
Below is an image of rear side of your TV, Sony KDL-40W5500
Top right corner is marked there and possible cause of noise seems back light inverter board, there are high voltage going to CCFL inside LCD panel and seems high voltage leakage causing that buzzing/ fuzzing noise.
Replace back light inverter board upon voltage leakage confirmation.
Thanks.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
No sound in Sony Bravia
If the sound is not heard during tuner (channel) but is when using an AV input (DVD) then it is likely the Second Audio Program (SAP) has been engaged. Some SONYs simply have a button on the remote to toggle through choices, SAP is used primarily for second language transmission of audio. Either move to a PBS station or some other channel that specifies SAP programmimg or turn the choice (MTS in some SONY menus) back to "main" by either a remote button or in the audio menu.
Good luck.
Jun 28, 2009 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Four blinking red lights.
Either on of the backlight inverter boards is bad or a backlight has failed inside the panel.
Oct 11, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony BRAVIA KDL-40S2000 40 in changing from HD to digital channels
40X2000, both PS3 and DVD player are using a HDMI input and both flicker and loose signal fully, have to turn TV of then back on to get signal back. Sony say they have never heard this problem and replaced board. NOTHING fixed, still same problem.
Mar 09, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
24 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
